Bed size calc based on Arm length April 07, 2016 02:23AM |
Re: Bed size calc based on Arm length April 07, 2016 03:26AM |
Re: Bed size calc based on Arm length April 07, 2016 04:05AM |
dc42
Here is a simple approximation. If the arms are vertical when the head is as close as it can get to a tower, then cos(angle_at_max_distance) = print_diameter/arm_length. Putting in your figures of 500 and 520mm gives the angle as 16 degrees. So for you to get 500mm with not less than 20 degrees angle, the arms would have to go well past the vertical when the head is close to a tower. So I suspect your figures are wrong.
In most carriage designs I have seen, the joints on the carriages are in line with or behind the belts, and this means that the rods are not quite vertical when the effector is as close to a tower as it can get. This reduces the print diameter.
Re: Bed size calc based on Arm length April 07, 2016 06:26PM |
Re: Bed size calc based on Arm length April 07, 2016 06:48PM |
Re: Bed size calc based on Arm length April 07, 2016 06:57PM |
Re: Bed size calc based on Arm length April 07, 2016 08:19PM |
Re: Bed size calc based on Arm length April 09, 2016 03:58AM |
