How to correctly measure arm length? April 25, 2016 09:01PM |
Re: How to correctly measure arm length? April 25, 2016 09:18PM |
Re: How to correctly measure arm length? April 25, 2016 09:34PM |
Re: How to correctly measure arm length? April 26, 2016 04:34AM |
Re: How to correctly measure arm length? April 26, 2016 05:31AM |
Re: How to correctly measure arm length? April 26, 2016 05:52AM |
Re: How to correctly measure arm length? April 26, 2016 08:00AM |
I wire cut a gauge for mine. The two measurement faces are about as parallel as machined faces are going to get. I built in adjustments to the arms and then set them to the jig. It would be the same principle as setting a mic to a dimension and adjusting the rod to fit. For this type of jig the faces need to be very parallel which is not easy to achieve with hand tools. After setting with this jig which I keep at home with my machine I checked a few with a mic (we have mic' sat work out to about a meter) and they were within a few .0001" of each other.Quote
Simon0362
Interested to hear how everybody 'accurately' measures the arm length to a 1/10 mm...My arms are ~330mm in length and most of my really accurate equipment is only capable of measuring to 12"/300mm...
Part way through a Kossel XL from Builda3DPrinter so this is about to become a critical issue!
Simon
Re: How to correctly measure arm length? April 26, 2016 08:42AM |
GroupB
its nothing virtual.. its how you measure the arm length... its always been a measure pivot to pivot whatever you use magnetic,rc car joint or any others form of joint
Re: How to correctly measure arm length? April 27, 2016 01:27AM |
Re: How to correctly measure arm length? April 27, 2016 06:08AM |
Re: How to correctly measure arm length? April 27, 2016 09:15AM |
hercek
Only if your bed si so big that your print head can get significantly behind the line connecting two virtual tower positions. Most delta printer do not have this property. Therfore for most printers, the calibration procedure will drift and will not find the proper arm length and delta radius. Of course you could optimize only arm length and not delta radius (tower positions) but that would mean that you can precisely measure delta radius which is much harder than measuring arm length.
[forums.reprap.org]
Re: How to correctly measure arm length? April 27, 2016 09:52AM |
Re: How to correctly measure arm length? April 27, 2016 08:55PM |
Re: How to correctly measure arm length? April 28, 2016 06:07AM |
Re: How to correctly measure arm length? April 28, 2016 12:38PM |
