why is my H parameter in DC42 branch of Duet not doing anything? November 03, 2016 02:13AM |
Re: why is my H parameter in DC42 branch of Duet not doing anything? November 03, 2016 04:33AM |
Re: why is my H parameter in DC42 branch of Duet not doing anything? November 05, 2016 04:42PM |
; Auto calibration routine for delta printers ; Before running this, you should have set up your zprobe Z offset to suit your build, in the G31 command in config.g. M561 ; clear any bed transform, otherwise homing may be at the wrong height G31 X0 Y0 ; don't want any probe offset for this G28 ; home the printer ;*** Remove the following line if your Z probe does not need to be deployed ;M98 Pdeployprobe.g ; deploy the mechanical Z probe ; The first time the mechanical probe is used after deployment, it gives slightly different results. ; So do an extra dummy probe here. The value stored gets overwritten later. You can remove this if you use an IR probe. G30 P0 X0 Y0 Z-99999 ;H parameter gives the value that must be added to the G31 Z parameter to get the actual trigger height at that point. ;H = (trigger height measured at the point) - (trigger height at the bed center) ; Probe the bed and do 6- or 7-factor auto calibration ; OUTER RING G30 P0 X-100 Y40 Z-99999 H0 ; X-Z towers G30 P1 X-120 Y-70 Z-99999 H-0.05 ; X G30 P2 X-10 Y-150 Z-99999 H0 ; X-Y towers G30 P3 X125 Y-80 Z-99999 H0.1 ; Y G30 P4 X125 Y70 Z-99999 H-0.05 ; Y-Z towers G30 P5 X0 Y140 Z-99999 H-0.15 ; Z ; HALF-IN RING G30 P6 X0 Y70 Z-99999 H-0.15 ; half way to Z tower G30 P7 X-60 Y-35 Z-99999 H0 ; half way to X tower G30 P8 X68 Y-40 Z-99999 H0.1 ; half way at Y tower G30 P9 X0 Y0 Z-99999 S6 ; centre, and auto-calibrate 6 factors ;*** Remove the following line if your Z probe does not need to be retracted ;M98 Pretractprobe.g ; retract the mechanical Z probe G1 X0 Y0 Z250 F10000 ; get the head out of the way of the bed
Re: why is my H parameter in DC42 branch of Duet not doing anything? November 06, 2016 05:18AM |
Re: why is my H parameter in DC42 branch of Duet not doing anything? November 06, 2016 11:42AM |
Re: why is my H parameter in DC42 branch of Duet not doing anything? November 06, 2016 01:57PM |
Re: why is my H parameter in DC42 branch of Duet not doing anything? November 07, 2016 01:38PM |
