What is hanging on your effector? January 25, 2017 06:51AM |
Re: What is hanging on your effector? January 31, 2017 04:36PM |
Re: What is hanging on your effector? January 31, 2017 05:20PM |
Re: What is hanging on your effector? January 31, 2017 08:00PM |
Re: What is hanging on your effector? January 31, 2017 09:04PM |
Re: What is hanging on your effector? January 31, 2017 09:15PM |
Re: What is hanging on your effector? January 31, 2017 10:45PM |
Re: What is hanging on your effector? February 05, 2017 12:35PM |
DjDemonD
This will explain most of it [www.thingiverse.com]
But in a nutshell, with a delta especially unless its mechanically perfect the effector will tilt.This means any offset sensor no matter how sensitive and DC's sensor is sensitive, will give height errors as the effector tilts. Using the nozzle as the probe is optimum for a lot of reasons, thats where you print from, there are no offsets, the surface can be coated in whatever you want etc.. however prior to this sensor the options for nozzle based probing were to suspend the bed on force sensitive resistors and measure nozzle contact, or use piezo transducers under the bed. There is a design for an FSR hotend on thingiverse but its sprung to allow the hotend to move vertically and trigger the FSR. This generates a wobbly nozzle - not good! So I took the piezo under-bed work and modified it into a piezo hotend sensor. And its working great!
It works with duetwifi and I've been testing it on ramps today, working fine.
So it should work on smoothie also, I am waiting on a re-arm board, then I can get familiar with smoothieware also.
Re: What is hanging on your effector? February 05, 2017 12:45PM |
