Bigger Delta Rostock ?
Posted by penny2009
August 18, 2012 06:03PM
Hello together,
is it possible to built the Rostock bigger, as example 500x500 mm workspace?
I am planing to built it with other linear guide and aluarms with Igus.
Thanks
Re: Bigger Delta Rostock ?
August 19, 2012 02:14PM
it will be v tall 1m++?
August 23, 2012 11:37AM
yea thats the problem I see with this kind of design. For every length increase in the extruder arm... there is a twice increase in the height of the parallel delta robot.
Surely there is a way to solve this?
VDX
August 23, 2012 03:25PM
... the you'll need something like the ABB Flexpicker: [www.ics-robotics.co.uk]
Viktor
August 24, 2012 10:32AM
You might need to use telescopic arms, like this one does [www.youtube.com]
August 24, 2012 06:30PM
My vision for a SpideyBot is coming along nicely:
1.6m tall frame, easily enclosed for heated chamber, instead of HBP.
80/20 frame, 6X, 6mm, simple flat plates join it all together.
1.24m linear rail and block design, one per column. THK RSR15 size
NEMA23 steppers, belt drive
1m carbon fiber tubes, Goodwinds .6inch diameter
10mm rod ends from VXB
currently designing the head. considering a mechanism to raise/lower individual nozzles.
Bowden tube style or maybe NEMA 8, 16:1 reduction stepper (have two of them already)
Dave
open | download - delta1.jpg (112.8 KB)
open | download - delta2.jpg (156.6 KB)
open | download - delta3.jpg (264.9 KB)
August 24, 2012 07:00PM
With 1M arma and only 1.24M rails you'll be pretty restricted in the maximum height at the outside of the movement envelope.
August 24, 2012 07:17PM
The working volume upper surface is a rounded triangular dome shape.
I have 17 inches at the three columns in an arm down situation, with 24 inches at the center.
The frame height of 1.6m gives some extra height.
Dave
(edited to remove poor tone)
Edited 1 time(s). Last edit at 08/24/2012 08:13PM by davew_tx.
open | download - delta4.jpg (167.5 KB)
August 25, 2012 03:32PM
> one does
> [www.youtube.com]
I wonder if something like that could be done with RP rack+pinions?
August 25, 2012 11:09PM
The precision of Rack and Pinion might be an issue.
I wonder if its possible to using linear actualtors to replace the arms, while also leaving in the stepper motors. Essentally the system will now have 6 motors instead of 3.
The 'extendable arms' can be either motorized, or pnumatic, but motorized seems cheaper. Something like [www.physikinstrumente.com]
Correct me if I'm wrong, but the properties of "linear actulators" is that they tend to be slower, and not as precise as 'stepper motor+ belts".
But it does mean that the printer is now more space efficient. I would imagine that the lower part of the platform would just have a stationary arm length, while printing on the very top would consist of purely 'arm length' movement.
Benifit of above idea. Not much changes needed to the design hopefully.
Problem with the above idea is, increase arm mass, and increase cost, and slower printing time.
Second partial solution:
Make a secondary motorised platform to move like mendel 3d printer. Benifits: Not too hard to construct, and is able to build longer objects. Disadvantage: Not as stable, and loses printable width.
Edited 1 time(s). Last edit at 08/26/2012 01:24AM by mofosyne.
August 29, 2012 03:42PM
Why would R&P be imprecise, other than the fact that it's RP? R&P is more precise than belts.
August 29, 2012 07:48PM
@ Acumen:
For me, R&P, in a precision setup, would be expensive, and maybe noisy if running zero clearance or contact pressure to eliminate gear slop.
That would also put the stepper (heavy-ish for NEMA 23) on a moving member, which will possibly cause overruns at quick direction changes.
Running downhill, that stepper has to stop and oppose momentum and gravity.
I selected an XL belt, at 100" long for $14. Each pulley is $6. Done. $26 for 1200mm of motion control (not linearization).
I am not using a ton of belt tensions on my large gantry machine. It seems to move very precisely (by hand right now)
www.econobelts.com (not affiliated, but am a customer)
Dave
Edited 1 time(s). Last edit at 08/29/2012 08:14PM by davew_tx.
August 30, 2012 08:09AM
You have a distinct advantage using rack and pinions in a delta robot.
One of the problems with R & P is backlash, but in a delta this is helped by gravity assisting you because the racks are near vertical.
I think that a delta with telescopic arms is a good idea. Perhaps you could use a pantograph setup or a sarrus linkage to avoid using linear rails.
August 30, 2012 08:56AM
So, the way I see it, there are two requirements for each tower axis. block drive and 5DoF linearization.
R&P gives drive, but no linearization.
linear rail/blocks have no drive but 5 DoF.
round rod and LM8UU bearings give no drive and only 4DoF each, so two are needed per column. to remove rotation.
(other ways to do it other than two)
If you could drive one of the Sarrus arms directly (geared down?) with the stepper, the sarrus could give BOTH linearization and motion control.
Each column would need 4 arms and a block, which are easy constructions, cheap materials.
I think precision of the construction and joint slop would be a large challenge, because slop is multiplied as you go towards the extruder tip.
This would need some programming to help with the block speed versus stepper rpm. i.e. as the arms near the full extension move the block very little for the same rpm. maybe just use the arms in the middle section and forget about this issue.
"Servobelt" is a cool concept, with a directly mounted stepper. fast but not cheap, at $20k per meter.
might be able to use 80/20 and friction blocks (UHMW) and a printed up block. [www.youtube.com]
open | download - servo drive.jpg (18.9 KB)
September 01, 2012 01:23PM
I was actually thinking about combining the R&P and telescoping arms designs. Rather than using fluid actuators, it would simply be a piston-type design with the rack as the inner cylinder, and the outer cylinder having a small cutout near the end for the pinion to contact the rack. This would both allow for the space-efficient design of the telescoping rods, while allowing use of a rack without a moving motor (technically the motor would move a little, but not as much as if it were part of a carriage).
Anyone see any major issues with this idea?
My printer isn't running yet, but I will definitely try to RP this later in the month.
September 07, 2012 05:12PM
Have you guys seen Lego's linear actuators? The design behind them is essentially R&P, but done as a worm drive instead. A single unit does linear bearing and linear actuator.
[technic.lego.com]
Lego actuators themselves wouldn't work for this, but the design might work. I don't know if it's covered by patents or not.
September 12, 2012 09:32AM
Acumen, It sounds rather interesting of a concept to have a telescopic arm design, especially with Annirak's link above on lego linear actuators. The biggest concerns I could think of, is 'accuracy' of the gearing (especially if you are printing these arms yourself), and also printing speed. Secondary concerns is, how 'far' can it contract and extend. If the telescopic arms can only move two times it's shortest length, then that still would make for an oversized printer heightwise.
If you do choose a telescopic arm design, see if you can transfer rotational force via 'bowden cables'. It means you can locate the strong stepper motor elsewhere and keep the extendable arms light ( Which might help with speed).
