Delta slow speed - DEFAULT_MAX_FEEDRATE <= 65.0 mm/s May 16, 2017 06:53AM |
#define DEFAULT_AXIS_STEPS_PER_UNIT {376.47, 376.47, 376.47, 191.72} #define DEFAULT_MAX_FEEDRATE {100.0, 100.0, 100.0, 100.0} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {9000,9000,9000,9000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for retracts // The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously) #define DEFAULT_XYJERK 20.0 // (mm/sec) #define DEFAULT_ZJERK 20.0 // (mm/sec) #define DEFAULT_EJERK 20.0 // (mm/sec)
Re: Delta slow speed - DEFAULT_MAX_FEEDRATE <= 65.0 mm/s May 16, 2017 11:09AM |
Re: Delta slow speed - DEFAULT_MAX_FEEDRATE <= 65.0 mm/s May 16, 2017 11:14AM |
Re: Delta slow speed - DEFAULT_MAX_FEEDRATE <= 65.0 mm/s May 16, 2017 11:34AM |
#define LCD_UPDATE_INTERVAL 100and changed to 5000 ms (5s).
Re: Delta slow speed - DEFAULT_MAX_FEEDRATE <= 65.0 mm/s May 16, 2017 12:31PM |
Re: Delta slow speed - DEFAULT_MAX_FEEDRATE <= 65.0 mm/s May 20, 2017 02:04AM |
