Kossel custom build problems with Z axis
Posted by Hozza
February 07, 2018 04:45AM
So I'm not new to 3D printing or custom building, but I am new to the world of deltas. About 18 months ago I started purchasing parts to build a Kossel and finally got it printing just after Christmas, however I'm less than happy with its performance especially with money I've spent on it.
The frame is built using Robotdigg corners and extrusions, I also got the rails and carriages from Robotdigg.
The electronics are running at 24v on a Duet 0.6 with the smart effector using rod from Haydn.
Stepper motors a 0.9° JK42HM40-1684
E3D Titan extruder in a bowden setup, I am planning on a Nimble extruder but I don't want to purchase that until I've all the issues ironed out.
So now the main issue:
The only way I can describe it is Z wobble, which I believe is the incorrect term on a delta, the print quality is improving while setting up the profile but something has to be wrong. The image attached is of 18mm x 18mm x 100mm and as you can see isn't straight.
I've run out of things to try so I'm hoping I can be pointed in the right direction.
Thanks
Paul
open | download - 20180207_093305.jpg (515.9 KB)
Re: Kossel custom build problems with Z axis
February 07, 2018 05:43AM
Maybe a pulley is not centered on its shaft.
February 07, 2018 09:40AM
Just checked them can't see anything wrong them.
February 07, 2018 10:15AM
It might be over extrusion. Some of the excess filament is pushed out at the side. Try 0.9 extrusion multiplier and are you printing with fan?
February 07, 2018 03:43PM
I had this issue, and it was one of the magball that was not properly fastened (the effector was loose). you need to check every bolt... And what is the length of your bowden tube ? may be it's too long ?
February 07, 2018 11:57PM
Vigilant
The line were slight over extrusion and yes I'm running a fan but I still have the wobble effect.
February 08, 2018 12:00AM
Archiclem
I've checked the magballs and hotend to make sure they are secure, found nothing there. My bowden tube is 600mm long.
open | download - 20180207_195243.jpg (554.5 KB)
February 08, 2018 08:33AM
A similar problem occurred before that was finally traced to the drive belts.
Skewed prints
HTH
February 09, 2018 02:45AM
Haydn apologized about the quality of his ball studs. They seem to be uneven. IDK exactly what he meant with that, but maybe it's worth the time to measure and eyeball them closely.
A ball that isn't round is the same as a rod changing length, depending on the mag-sleeves position. That would cause effector tilt in a reciprocating pattern.
February 09, 2018 04:50AM
ayudtee
Skewed prints
HTH
Made an interesting read, may have to strip out the belts and give them a good looking over.
Edited 1 time(s). Last edit at 02/09/2018 04:51AM by Hozza.
February 09, 2018 04:52AM
o_lampe
Well got to be worth a look while it's in bits lol
February 09, 2018 09:59AM
Is this all Haydn ball studs, or only older ones? I was not aware of such an issue
February 10, 2018 03:04AM
Origamib
I bought mine a month ago and in his build instructions he suggested to use 3/8 ball bearings to measure final rod length.
I then heard from DjDemonD, that's because the ball studs weren't even. Does it mean they are potato shaped or are they not the same diameter? IDK
February 10, 2018 03:34AM
Hi guys please read this thread:
[www.duet3d.com]
The issue was not all ball studs were exactly the same size.
I do need to correct a couple of things though...
1) we could not accurately determine if they were spherical, if you know how to do this let me know
2) it seemed that whilst there was a spread of sizes of ball stud, when I measured them (as best I could) and my rods and then reassembled my kossel XL printer so that each rod+2 balls set was as close in length to each other, and each pair of arms was comprised of the two best-matching pairs of rods/balls, the effect on improving my calibration deviation was not measurable. Over the central 100mm of the bed it managed 0.004mm and then 0.004mm after swapping everything around.
So if this problem is bothering you (and you can test for yourself), my advice would be to buy a pack of high grade (grade 50) 3/8th bearings and bond them to your carriage and effector, instead of using the ball studs. Don't buy stainless its not magnetic enough.
The variance in the ball studs we are talking about in the thread above is so small, if you printed your effector rather than having one machined, or made from a precision drilled PCB, you will be attaching the "dodgy" ball studs to a much "dodgier" effector! Even with the smart effector the holes are drilled slightly larger than 3mm to assist assembly, how much effort are we going to to ensure the ball stud is centralised in those holes before tightening?
Edited 3 time(s). Last edit at 02/10/2018 06:12AM by DjDemonD.
Simon Khoury
Published:Inventions
February 10, 2018 07:52AM
I took a handful of Delrin sleeves and some ball studs and tested continuity between ball and backside of the magnet. ( Yes, I finally got my 3 sets of mag-arm kits grinning smiley )
The result showed minor differences between them. Some had "solid" continuity when the ball stud and sleeve were straigth aligned, but no conductivity when angled.
Others had so_so continuity ( the multimeter made a screeching noise ) at several angles. To me the difference is academic.
BTW: My Smart Effectors holes are 2.9mm, which is a tight fit. thumbs up
February 10, 2018 07:53AM
Hmm mine were not that tight at all.
Simon Khoury
February 10, 2018 08:27AM
Well I've still been unable to find the root cause of my issue, so bloody frustrating or infuriating not sure which yet smiling smiley
Is it worth the effort of modding the Titan and make it a flying extruder?
I'm also going to be changing the motor pulley's to 16 tooth from 20, I believe I've read something about step calculations being more accurate on 0.9° step, plus I've noticed my idlers are 16 tooth.
February 10, 2018 12:06PM
Flying extruder is worth it. Reducing bowden to 20cm basically returns performance to direct extruder levels. But you have to print a little slower as the inertia of the flying extruder will show as added ringing to some degree.
Idler and drive pulleys should be the same diameter. Twist your belt that goes over the idler so it runs smooth side to the idler unless the idler is toothed. Using 16t improves resolution but its quite a small effect.
Edited 1 time(s). Last edit at 02/10/2018 12:08PM by DjDemonD.
Simon Khoury
