Suggested carriages and effector for Haydn magnetic arms for Kossel Mini? September 01, 2017 08:48PM |
Re: Suggested carriages and effector for Haydn magnetic arms for Kossel Mini? September 02, 2017 03:44AM |
Re: Suggested carriages and effector for Haydn magnetic arms for Kossel Mini? September 02, 2017 09:29AM |
o_lampe
What about the Smart PCB effector?
The carrier-plates use the 20x20mm pattern, so it should work with wheeled carriers too?
Re: Suggested carriages and effector for Haydn magnetic arms for Kossel Mini? September 02, 2017 01:23PM |
Re: Suggested carriages and effector for Haydn magnetic arms for Kossel Mini? September 02, 2017 05:23PM |
Re: Suggested carriages and effector for Haydn magnetic arms for Kossel Mini? September 03, 2017 07:17AM |
JohnOCFII
o_lampe
That was my original plan, but the designers pointed out to me that it it quite a bit larger than the effector on the Kossel Mini, and that would cause me to lose build area. Rod spacing is 10mm wider, so the rough calculation would be a loss of 20mm of diameter. On a bed that is barely 170mm in diameter, that is a pretty large loss. I'm already losing some build area on side of the bed due to my current parts cooling fan arrangement (although that can be improved).
It's a shame. I was really looking forward to trying it.
John
Re: Suggested carriages and effector for Haydn magnetic arms for Kossel Mini? September 03, 2017 01:41PM |
JohnOCFII
number40fan
Do you live in the states? If so, I could probably make you some out of plexiglass cut on a laser machine.
Yes, I live in Minnesota. That's an interesting idea!
Re: Suggested carriages and effector for Haydn magnetic arms for Kossel Mini? September 03, 2017 11:23PM |
number40fan
If you can get me some specifics, I'll see what I can do.
Re: Suggested carriages and effector for Haydn magnetic arms for Kossel Mini? September 04, 2017 02:33AM |
Re: Suggested carriages and effector for Haydn magnetic arms for Kossel Mini? March 18, 2018 10:21AM |
