Large Delta Build help needed. May 24, 2018 03:34PM |
Re: Large Delta Build help needed. May 24, 2018 04:56PM |
Re: Large Delta Build help needed. May 24, 2018 05:09PM |
Re: Large Delta Build help needed. May 24, 2018 10:05PM |
Re: Large Delta Build help needed. May 25, 2018 02:38AM |
GreekPilot
Wow, that was fast and helpful.
ok some questions
0. I guess u mean 8 mm solid rods? I dont think i can find 3030s around here and i am not sure if they would be stiff enough
8. do i need an extra board for that or it goes straight on the duet?
The rest is clear,
Thank you dc42
Re: Large Delta Build help needed. May 25, 2018 02:57AM |
Re: Large Delta Build help needed. May 25, 2018 12:31PM |
Re: Large Delta Build help needed. May 25, 2018 03:27PM |
Re: Large Delta Build help needed. May 25, 2018 04:12PM |
Re: Large Delta Build help needed. May 25, 2018 04:26PM |
Re: Large Delta Build help needed. May 25, 2018 04:29PM |
Re: Large Delta Build help needed. May 25, 2018 04:36PM |
Re: Large Delta Build help needed. May 25, 2018 05:36PM |
cwaa
I have something similar under construction. I don't understand the recommendation for 24v power supply over a 12v.
Re: Large Delta Build help needed. May 25, 2018 08:12PM |
Re: Large Delta Build help needed. May 30, 2018 02:30AM |
Re: Large Delta Build help needed. May 30, 2018 03:42AM |
Re: Large Delta Build help needed. May 30, 2018 03:59AM |
Re: Large Delta Build help needed. May 30, 2018 04:13AM |
Re: Large Delta Build help needed. May 30, 2018 05:45AM |
Re: Large Delta Build help needed. May 30, 2018 06:46AM |
Re: Large Delta Build help needed. May 30, 2018 10:01AM |
Re: Large Delta Build help needed. June 15, 2018 06:45PM |
Re: Large Delta Build help needed. June 16, 2018 01:57AM |
I quite like the new approach going around with the hylite folded material that looks really light, but its very new so maybe it does everything claimed or maybe not.
