DUET3D rotary delta --> motor problems ? June 28, 2018 05:06AM |
Re: DUET3D rotary delta --> motor problems ? June 28, 2018 07:13AM |
Re: DUET3D rotary delta --> motor problems ? June 28, 2018 10:10AM |
Re: DUET3D rotary delta --> motor problems ? June 28, 2018 12:52PM |
Re: DUET3D rotary delta --> motor problems ? June 28, 2018 04:58PM |
Re: DUET3D rotary delta --> motor problems ? June 29, 2018 02:40AM |
Re: DUET3D rotary delta --> motor problems ? June 29, 2018 03:31AM |
Re: DUET3D rotary delta --> motor problems ? June 29, 2018 08:51AM |
Re: DUET3D rotary delta --> motor problems ? June 29, 2018 05:42PM |
Re: DUET3D rotary delta --> motor problems ? June 30, 2018 05:10AM |
It is. The stepper will hold with with torque 1.26 Nm at worst at the nearest full step boundary.Quote
Arnix
Isnt the board (any board) holding torque in between steps ?
Your current power supply should work at low speed. But maybe it is broken. You can verify it by connecting voltmeter to the power supply when it is loaded (the steppers are consuming current). If the power supply voltage is below 24 V in such a situation then it is broken. The point is that when the steppers are not moving then one stepper should take only around 250 mA from your power supply despite the fact that the current in the stepper phase will be 2 A. That is because you actually need only around 3 V to push 2 A through your stepper when it is not moving. The exact numbers depend on your stepper drivers.Quote
Arnix
The weight of the arm with this screwdriver is definitely under 350gram, so i guess that the main problem was as O_lampe stated, power supply ?
Re: DUET3D rotary delta --> motor problems ? June 30, 2018 10:38AM |
Re: DUET3D rotary delta --> motor problems ? July 01, 2018 02:18PM |
Re: DUET3D rotary delta --> motor problems ? July 03, 2018 03:38AM |
Re: DUET3D rotary delta --> motor problems ? July 03, 2018 04:07AM |
Re: DUET3D rotary delta --> motor problems ? July 09, 2018 04:59AM |
