Underslung Delta Effector July 09, 2018 01:19PM |
Re: Underslung Delta Effector July 10, 2018 01:26AM |
Re: Underslung Delta Effector July 10, 2018 10:01AM |
Re: Underslung Delta Effector July 10, 2018 11:36AM |
Re: Underslung Delta Effector July 17, 2018 06:14AM |
Re: Underslung Delta Effector July 17, 2018 11:24AM |
Re: Underslung Delta Effector July 18, 2018 02:20AM |
Redemptioner
I would not suggest the mag balls unless you really want to make a lot of effector changes, they centre "ok" but they definitely do not print as clean or as accurate as solid rod ends especially at higher speeds (and speed is a big reason for getting a delta)....
Re: Underslung Delta Effector July 18, 2018 03:50AM |
Re: Underslung Delta Effector July 18, 2018 04:07AM |
Re: Underslung Delta Effector July 18, 2018 07:29AM |
Re: Underslung Delta Effector July 18, 2018 11:54AM |
Re: Underslung Delta Effector July 18, 2018 03:51PM |
Redemptioner
Sorry but that is simply not true, most people go to mag balls because they think they look cool and think of it as an "upgrade" and few change because they need to be able to change the effector out regularly (or think they do). Rod ends are far more stiff and have ZERO play in them compared to mag balls, people who have issues with rod ends do so because they use garbage rod ends (i.e. Traxxis branded). If you spent half the cost of a set of semi decent mag balls on decent rod ends you will end up with a printer significantly more constrained than mag balls. Just grab the effector on mag balls and wiggle it then compare the same to rod ends, it is night and day difference and keep in mind any movement on a delta effects every axis. Mag balls never centre "exactly" and also move ever so slightly on each movement (there is no way to stop the movement), this is easily measured and is obvious in prints when you setup 2 prints identical to each other on the different setups and run the print at a decent speed. Will 80% of users notice the difference, probably not, especially if they have come from cheap Chinese rod ends but it does not change the mechanical facts.
Redemptioner
A little bit of commonsense looking at how the 2 connections work should clearly bring you to the obvious issue with mag balls, they are only semi constrained...
Redemptioner
....and rely on a magnetic field that can vary to hold them in the same place.
Redemptioner
Mag balls also wear at a faster rate but you don't generally notice this wear due to the magnets removing the play and this results in print inaccuracies without an easy way of identifying it. Why do they wear faster, well that is because the magnets have to apply a significantly higher force on the joints in order to over come gravity as well as hold the joint in place well enough not to fall off during movements as well as being open to allow dust/print particles to enter the joint and acts as an abrasive. Rod ends wear much slower (assuming you are using decent ones) but when the do they start to introduce play, once they wear enough, which you can easily feel if you are doing proper maintenance. This then allows you to change them out before they start to cause inaccuracies assuming you do something about it, the rod ends also have a "wiper" to prevent particles getting into the joint. I only have one printer left with mag balls (out of 4) and that one is only on mag balls still because it needs to be able to swap in and out the laser heads, I have done this because these 4 printers run nearly 24/7 and when you do this you soon find the problem with mag balls when you are doing over 600 hours of print time a week.
Redemptioner
I point out though, there is nothing wrong with mag balls to hold effectors in place, they are just not as good as rod ends.
Re: Underslung Delta Effector July 18, 2018 06:10PM |
Re: Underslung Delta Effector July 18, 2018 09:43PM |
dc42
I can only assume that either you have no experience of magnetic joints, or you have only experienced ones that were not properly constructed. Properly made magnetic joints - such as the ones I have, made by Haydn Huntley (the variant with machined Delrin ends) - have zero play.
dc42
What do you mean by semi-constrained? They are as constrained as any other type of joint, until you apply sufficient force to separate the ball from the socket.
dc42
Redemptioner
Vary? How?
dc42
Good magnetic joints are (from my experience) much better than poor and mediocre rod ends. I can believe that good rod ends are better than badly-made magnetic joints. But you haven't convinced me that good rod ends (whatever they are) are better than good magnetic joints.
Barracuda72
Either the screw fits through the eye and has play or it does not fit
Barracuda72
was able to bring it up to 450mm/s with 5000mm/s acceleration without the effector causing problems before the extruder gave up
Re: Underslung Delta Effector July 19, 2018 01:19AM |
M_Xeno
Did you know that there is a radically different solution, which escapes most of the problems that affect magnets or rod ends?
A system very light, intrinsically accurate and insensitive to wear and tear ?
It's Zatsit's living hinge system... (shameless autopromotion)
www.zatsit.fr
Re: Underslung Delta Effector July 19, 2018 05:41AM |
Which is a rather pathetic speed and poor acceleration for a delta. It does not give much trust in magnetic joints.Quote
Barracuda72
I recently looked how fast my Delta with DIY Magnet rods ccan print and was able to bring it up to 450mm/s with 5000mm/s acceleration without the effector causing problems before the extruder gave up
Re: Underslung Delta Effector July 19, 2018 11:13AM |
Re: Underslung Delta Effector July 20, 2018 03:02AM |
Re: Underslung Delta Effector July 20, 2018 05:59AM |
Redemptioner
That simply is not true David, I have one of your effectors (well I had 2 but sold one) and you can indeed feel the movement if you grab it and give it a wiggle (also has flex in the PCB material which is need for the FSR to work but that is another issue), again I stress this probably is not enough to effect most users as they are never going to print fast enough or need the part accuracy high enough to care but it does not change the fact it is there. I won't get into it further as anyone who has a decent setup in both styles can see the difference, suffice to say you should have a chat with a mechanical engineer who has a background in joints they will confirm my position.
Redemptioner
They are only semi constrained because you are relying on a magnetic field to hold a ball in a semi-cup socket, so only about 30% of the joint is constrained "ish", and only from a small range of angles of load that aligns with the cup. A rod end is 100% constrained as the joint is captured on all axis, no matter the angle of the load it cannot move outside of the constraint.
Redemptioner
I will not go into all the fundamentals about magnets and especial spherical magnets or using magnets on a sphere, but I will point out a couple of issues. Firstly magnets are effected by heat, the stronger the magnet the more it is effected, the angle the magnet is at compare to its pole alignment and the alignment of the electrons in the ferric coupler means the strength of the bond changes as well.
Redemptioner
Add a little friction and momentum to the joint and you always have some movement (gets worse as abrasives get in between the mating surfaces).
Redemptioner
Each to there own but physics don't lie.
Re: Underslung Delta Effector July 20, 2018 02:48PM |
Magnetic joints have very poor holdingForce / weight ratio compared to ball rod ends. That is pretty solid physics.Quote
dc42
What physics would that be? IMO you have not demonstrated any physics that makes magnetic joints a poor choice, except at high temperatures.
Re: Underslung Delta Effector July 20, 2018 05:09PM |
hercek
dc42
hercek
How heavy is the magnet and the metal ball in Haydn's mag-arms?
Re: Underslung Delta Effector July 20, 2018 05:47PM |
Re: Underslung Delta Effector July 20, 2018 06:07PM |
Re: Underslung Delta Effector July 20, 2018 06:20PM |
Actually, I have only one argument for ball joints: holdingForce / weight ratio.Quote
Barracuda72
till now you have only 2 arguments that all need to use Ball end over Magnetic System
Re: Underslung Delta Effector July 21, 2018 04:08AM |
Re: Underslung Delta Effector July 21, 2018 03:03PM |
Re: Underslung Delta Effector July 21, 2018 05:31PM |
Re: Underslung Delta Effector July 22, 2018 03:27AM |
Ooooo, but it does matter how fast the rotor rotates. Helicopters do not tilt the whole main rotor when you move the collective stick. They only change the pitch of the blades and the pitch of any given blade will be different when the blade rotates rotates by 90° or 180°. The angle joints on helicopters do one full cycle every rotor revolution anytime the collective stick is not centred. And especially the competition pilots almost never have their collective stick c entered. Even sustained direct helicopter flight requires the stick to be not centred. Otherwise the helicopter would be slowing down.Quote
Barracuda72
It doesnt matter how fast the Rotors rotate..if you take a look at the Heli mechanic you can see that there not much movment in the ball joints..they just adjust the pitch and yaw of the rotor blades.
You are probably right. I cannot find the 6G reference now.Quote
Barracuda72
btw..6g acceleration? are you sure? that would be 58.800 mm/s² (1g is ~9800mm/s²) not sure if i should believe that
Ø5 mm rod diameter is plenty enough for 30 cm rods. Any rods thicker than that is a waste. Well it could be good to have maybe Ø 6-7 mm rods with thinner walls to keep the same overall weight. I even posted some computation about that on this forum: [reprap.org]Quote
Barracuda72
btw..your rods are much thinner and shorter than DC´s or mine..mine uses 6mm carbon rods and length is 380mm so sure your is much lighter...
Re: Underslung Delta Effector July 22, 2018 06:20AM |
Re: Underslung Delta Effector July 22, 2018 07:09AM |
Barracuda72
And still no Link to his Wonder Ball Joints.
