FLSUN Delta (not mini) Setup August 15, 2019 11:49AM |
Re: FLSUN Delta (not mini) Setup August 23, 2019 10:28AM |
Re: FLSUN Delta (not mini) Setup August 23, 2019 11:04AM |
NAP1947
I had my FLSUN Delta working quite well for a beginner up to the point I warped the heated bed.
I replaced the thin aluminum bed with a plate of plate aluminum machined to 1/4” and same diameter as original, still heated.
Now I am trying to reset Marlin and Repetier to the new Delta Height of 306.9mm which was determined by using the -100, -1 and -0.1 Z control in Repetier.
I updated Marlin with this figure at #define DELTA_HEIGHT to the 306.9 number, saved it the uploaded it to Arduino successfully.
When I run G33 P1, the nozzle stops about 10mm above the bed and the printer LCD says I have an error, I reset the printer and home all with Repetier and the LCD tells me that the Z height is 295.
I have uploaded the Marlin code to the printer a number of times always with the same result.
I am unable to figure out where my mistake is.
I am using the FLSUN setup instructions from Github but using the figures measured on my larger printer.
I am using a Mac not Windows computer.
Can someone point me in a direction to solving this?
Re: FLSUN Delta (not mini) Setup August 23, 2019 12:18PM |
Re: FLSUN Delta (not mini) Setup September 06, 2019 12:46PM |
Re: FLSUN Delta (not mini) Setup September 07, 2019 03:56AM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: FLSUN Delta (not mini) Setup September 07, 2019 05:31AM |
Re: FLSUN Delta (not mini) Setup September 07, 2019 06:23AM |
Re: FLSUN Delta (not mini) Setup September 07, 2019 09:21AM |
Re: FLSUN Delta (not mini) Setup September 08, 2019 10:26AM |
Re: FLSUN Delta (not mini) Setup September 08, 2019 11:12AM |
Re: FLSUN Delta (not mini) Setup September 08, 2019 11:19AM |
Re: FLSUN Delta (not mini) Setup September 09, 2019 03:39AM |
Re: FLSUN Delta (not mini) Setup September 09, 2019 11:05AM |
Re: FLSUN Delta (not mini) Setup September 09, 2019 02:18PM |
Re: FLSUN Delta (not mini) Setup September 09, 2019 02:23PM |
Re: FLSUN Delta (not mini) Setup September 09, 2019 02:29PM |
Re: FLSUN Delta (not mini) Setup September 09, 2019 04:03PM |
Re: FLSUN Delta (not mini) Setup September 09, 2019 06:39PM |
Re: FLSUN Delta (not mini) Setup September 13, 2019 04:51PM |
Re: FLSUN Delta (not mini) Setup September 13, 2019 06:21PM |
Re: FLSUN Delta (not mini) Setup September 14, 2019 03:38AM |
Re: FLSUN Delta (not mini) Setup September 14, 2019 09:05AM |
Re: FLSUN Delta (not mini) Setup September 15, 2019 02:05PM |
Re: FLSUN Delta (not mini) Setup September 23, 2019 10:49AM |
Re: FLSUN Delta (not mini) Setup October 21, 2019 09:10AM |
