Loss of accuracy and position. June 17, 2020 10:01PM |
Re: Loss of accuracy and position. June 18, 2020 02:51AM |
Re: Loss of accuracy and position. June 18, 2020 06:13AM |
Re: Loss of accuracy and position. June 18, 2020 12:51PM |
Re: Loss of accuracy and position. June 19, 2020 02:22AM |
Re: Loss of accuracy and position. June 19, 2020 09:11AM |
Re: Loss of accuracy and position. June 19, 2020 01:50PM |
Re: Loss of accuracy and position. June 19, 2020 10:36PM |
Re: Loss of accuracy and position. June 20, 2020 01:50AM |
Re: Loss of accuracy and position. June 20, 2020 09:59AM |
This is a feature of Marlin based delta firmwares. They print more slowly near bed edges since the firmware tries to keep constant carriage speed instead of constant hot end speed. You would need to switch to some other firmware, e.g. Repetier based or RepRap firmware.Quote
Scintilla
As I write, I am watching the printer run through a practice print and I notice that sometimes the print effector moves fairly slowly and smoothly and at other times it is quite abrupt and apparently non-linear in long print moves. It still prints reasonably well now so I'll try to do a full test print and see how it turns out...
Re: Loss of accuracy and position. June 20, 2020 10:03AM |
Just try to upload firmware again. Make sure you have selected the right board in arduino ide. Maybe try disconnect a reconnect usb cable. If that does not help then maybe your hardware is faulty.Quote
Scintilla
I tried to upload a sketch as usual and all I see in the Pronterface window is hash and symbols and I now have 'An error occurred while loading sketch' in Arduino.
Re: Loss of accuracy and position. June 20, 2020 11:11PM |
Re: Loss of accuracy and position. June 21, 2020 07:59PM |
Re: Loss of accuracy and position. June 22, 2020 01:31AM |
Re: Loss of accuracy and position. June 27, 2020 01:48AM |
Re: Loss of accuracy and position. June 27, 2020 02:18AM |
Re: Loss of accuracy and position. June 28, 2020 02:12AM |
