smart effector - Error: G30: Z probe 0 not found
Posted by 7ambrion
July 01, 2020 05:36PM
Hi. I need some help here. What i do wrong?
I have duetwifi with last firmware and just get smart effector... cant get z probe work ))
config
; General preferences
G90														; Absolute_cordinats
M83														; Relative_extrusion
M550 P"DeltaZ"											; Printer_"name" (http://printer_name)
M665 R105 L288.08 B80 H203.35							; R=delta_radius L=diagonal_rod B=printable_radius H=homed_height
M666 X0 Y0 Z0											; Endstop_correction
M208 S1 Z0					 							; S1=delta Z=Z_min(mm)
; Network
M552 S1													; network S0/1=off/on
M586 P0 S1                                              ; enable HTTP
M586 P1 S0                                              ; disable FTP
M586 P2 S0                                              ; disable Telnet
; Drives
M569 P0 S1												; P=driver_nr S0/1=revers/norm
M569 P1 S1												; P=driver_nr S0/1=revers/norm
M569 P2 S1												; P=driver_nr S0/1=revers/norm
M569 P3 S1												; P=driver_nr S0/1=revers/norm
M584 X0 Y1 Z2 E3										; Driver_mapping
M350 X16 Y16 Z16 E16 I1                                 ; set microstepping with interpolation
M92 X160.00 Y160.00 Z160.00 E150.00						; Steps_per_mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00				; Speed_change(mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00				; Speed_max(mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00				; Acceleration(mm/s^2)
M906 X1500 Y1500 Z1500 E1500 I0							; Peak_current(mA) I=Power_after_timeout(%)
M84 S90													; S=timeout(seconds)
; Axis Limits
M208 Z0 S1                                              ; set minimum Z
; Endstops
M574 X2 S1 P"xstop"										; X=0/1/2=none/low/high_end S1/2/3/4=microswitch("!"inverts)/Z_probe/stall_detection_stops_all_motors/stall_detection
M574 Y2 S1 P"ystop"										; X=0/1/2=none/low/high_end S1/2/3/4=microswitch("!"inverts)/Z_probe/stall_detection_stops_all_motors/stall_detection
M574 Z2 S1 P"zstop"										; X=0/1/2=none/low/high_end S1/2/3/4=microswitch("!"inverts)/Z_probe/stall_detection_stops_all_motors/stall_detection
; Calibration
M558 P8 R0.4 F1200 H10 T6000							; Z-Probe			C=pin P=type R=Recovery_time F=probing_speed H=distance T=move_speed A=point_times S=tolerance(0.03mm)
G31 P100 X0 Y0 Z-0.1									; Options			P=trigger XY=offsett Z=trigger
M557 R80 S15											; Grid_Options		R=radius S=Space
; Bed
M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8	; Define_sensor		S=nr P=pin Y=type (TBC=Semitec_104GT-2) R=resistor
M950 H0 C"bedheat" Q10 T0								; Define_heater		H=nr C=pin Q=Hz T=temp_sensor_nr
M143 H0 S130											; Temp_limit		H=heater_nr S=max_temp
M307 H0 A858.4 C741.7 D4.2 V24.2 B0 S1.0				; Heater_options	H=heater_nr A=model_gain C=model_time_constant D=dead_time V=volts B0/1=PID/bang_bang S=max_PWM(1.0_max)
M140 H0                                                 ; map heated bed to heater 0
; HotEnd
M308 S1 P"spi.cs1" Y"rtd-max31865"						; Define_sensor		S=nr P=pin Y=type R=resistor F=Hz(50/60) W=wire(if_3)
M950 H1 C"e0heat" T1									; Define_heater		H=nr C=pin Q=Hz T=temp_sensor_nr
M143 H1 S300											; Temp_limit		H=heater_nr S=max_temp
M307 H1 A1029.2 C403.6 D6.7 V24.1 B0 S1.00				; Heater_options	H=heater_nr A=model_gain C=model_time_constant D=dead_time V=volts B0/1=PID/bang_bang S=max_PWM(1.0_max)
; Fans
M950 F0 C"fan0"											; Define_fan		F=nr C=pin Q=Hz
M106 P0 L0.5 X1.0 B5 H1 T50:100							; Fan_options		P=nr S=speed(1.0_max) L=min_speed X=max_speed B=max_speed_seconds_onstart H=temp_sensor_nr T=temp_on
; M950 F1 C"fan1" Q500										; Define_fan		F=nr C=pin Q=Hz
; M106 P1 S1 H-1											; Fan_options		P=nr S=speed(1.0_max) L=min_speed X=max_speed B=max_speed_seconds_onstart H=temp_sensor_nr T=temp_on
; Tools
M563 P0 S"e3d" D0 H1 F0									; Define_tool		P=nr S="name" D=extruder H=heater(s) F=fan(s)
G10 P0 Z0 R0 S0											; Tool_options		P=tool_nr XYZ=offset(mm) R=off_temp S=on_temp
; M563 P1 S"Volcano" D0 H1 F0:1								; Define_tool		P=nr S="name" D=extruder H=heater(s) F=fan(s)
; G10 P1 X0 Y0 Z0											; Tool_options		P=tool_nr XYZ=offset(mm) R=off_temp S=on_temp
; Custom settings are not defined
; Miscellaneous
M501                                                    ; load saved parameters from non-volatile memory
T0                                                      ; select first tool
bed
; works with G32
M561					; clear any bed transform
G28						; home the printer
; Probe the bed at 10 peripheral and 6 halfway points, and perform 6-factor auto compensation
G30 P0 X0 Y79.8 H0 Z-99999
G30 P1 X46.96 Y64.64 H0 Z-99999
G30 P2 X75.99 Y24.69 H0 Z-99999
G30 P3 X75.99 Y-24.69 H0 Z-99999
G30 P4 X46.96 Y-64.64 H0 Z-99999
G30 P5 X0 Y-79.9 H0 Z-99999
G30 P6 X-46.96 Y-64.64 H0 Z-99999
G30 P7 X-75.99 Y-24.69 H0 Z-99999
G30 P8 X-75.99 Y24.69 H0 Z-99999
G30 P9 X-46.96 Y64.64 H0 Z-99999
G30 P10 X0 Y39.9 H0 Z-99999
G30 P11 X34.55 Y19.95 H0 Z-99999
G30 P12 X34.55 Y-19.95 H0 Z-99999
G30 P13 X0 Y-39.9 H0 Z-99999
G30 P14 X-34.55 Y-19.95 H0 Z-99999
G30 P15 X-34.55 Y19.95 H0 Z-99999
G30 P16 X0 Y0 H0 Z-99999 S6
Edited 1 time(s). Last edit at 07/01/2020 05:40PM by 7ambrion.
Re: smart effector - Error: G30: Z probe 0 not found
July 02, 2020 01:39AM
Your M558 command is missing the pin name parameter.
July 02, 2020 04:18AM
thanks for quick anser, what i actually need to write there? looks like that it use both probe_mod and probe_in pins?
July 02, 2020 06:48AM
dc42 thanks, just tryed C"zprobe.in" and now it work )
July 03, 2020 03:35PM
That's ok if you never need to adjust the sensitivity. To adjust the sensitivity as well you need C"zprobe.in+zprobe.mod".
