Consistent Horizonal lines on the prints of a Delta printer September 02, 2020 04:36AM |
Re: Consistent Horizonal lines on the prints of a Delta printer September 02, 2020 07:43PM |
Re: Consistent Horizonal lines on the prints of a Delta printer September 03, 2020 03:04AM |
hercek
Most likely reason is wrong PID parameters for heat bed or hot end temperature maintenance. When temperature is fluctuating then also the distance between bed and hot end tip is changing. This change in distance has impact on the actual layer height of the layer currently printed. At the same flow speed that means wider or narrower wall leading to the pattern you see. Check whether the temperature fluctuates and whether its period is consistent with the period on the printed object.
Re: Consistent Horizonal lines on the prints of a Delta printer September 03, 2020 02:07PM |
Re: Consistent Horizonal lines on the prints of a Delta printer September 03, 2020 03:00PM |
Sorry for the delay.Quote
hercek
Probably not. 2 °C looks too low for it.
Is the length of the period of the pattern the same as the timing belt pitch? Maybe something with belt not matching pulleys well?
If your idler is not a toothed pulley then make sure the belt is turning around idler with its smooth side. Otherwise it would cause small errors with belt pitch period.
Might be also eccentric pulley on extruder. Possibly.
No more ideas.
Re: Consistent Horizonal lines on the prints of a Delta printer September 03, 2020 03:21PM |
Re: Consistent Horizonal lines on the prints of a Delta printer September 03, 2020 04:29PM |
hercek
I do not know DC42 idler pulley assembly.
If the scratch happens only during homing and cause some error only when a carriage is near the home position then it cannot cause the pattern on your print. You must look for a periodic error along the part height. Not a one time error near homing. The homing error may be there but it is a separate issue.
Re: Consistent Horizonal lines on the prints of a Delta printer September 04, 2020 02:34AM |
Re: Consistent Horizonal lines on the prints of a Delta printer September 04, 2020 04:45AM |
Re: Consistent Horizonal lines on the prints of a Delta printer September 05, 2020 05:58AM |
Thanks for your reply DC42.Quote
dc42
What is the pitch between the ripples? Is it consistent?
Re: Consistent Horizonal lines on the prints of a Delta printer September 05, 2020 06:44AM |
hercek
More extruded material means thicker walls. Less extruded material means thinner walls. An eccentric pulley on extruder will cause variation in the extruded amount of plastic with the period corresponding to one pulley rotation. If the cube walls are thin enough and filament thick enough then one extruder pulley rotation will correspond to more layers and it may correspond to the pattern you see. You can run the numbers to check whether this is possible.
Re: Consistent Horizonal lines on the prints of a Delta printer September 05, 2020 06:49AM |
Re: Consistent Horizonal lines on the prints of a Delta printer September 05, 2020 09:25AM |
dc42
The trick to printing small objects in PLA is to use lots of fan cooling and either print more than one at a time or reduce the print speed. Most slicers have a Minimum Layer Time parameter to slow down printing of small objects. Try increasing it.
Re: Consistent Horizonal lines on the prints of a Delta printer September 05, 2020 04:50PM |
Re: Consistent Horizonal lines on the prints of a Delta printer September 06, 2020 03:51PM |
hercek
I do not have an explanation how fixing a play leading to the carriage rotation can fix the problem with periodically changing wall thickness you presented in the first picture. Carriage rotation play leads to significant errors in the XY-direction. But the problem is that this play should lead to an error which has period of one layer. While the error in your picture has obviously period spread over more layers. And the error is very consistent.
If you would have a problem with retraction distance and timing relative to the layer time then again I would expect the period of the error to be one layer and not spread over multiple layers. You can verify whether it is connected to retraction/layer time ratio just by printing a bigger cube. That will change the layer time if you are not already at minimum layer time limit.
No experience with E3d hotends and their clogging. Anyway extruder periodic partial clogging/unclogging can lead to the error you have. My only doubt with this theory is again the nice periodicity of your error. My dirt cheap old style reprap hotend clogs only when there is some garbage in it (e.g. a piece of metal from a broken quick coupling).
May be you can run the numbers on the expansion of your hotend when its temperature changes by 2°C. I guessed it is too little to be significant but it was only a guess. Or ignore the computation run PID calibration to get the fluctuation below 0.5°C and try a test print again. Maybe your hotend temperature sensor has poor heat transfer connection with hotend? Is the fan rotating at the same speed while the test cube was printing? If fan speed changes with the same period as the error pattern together with the badly connected temperature sensor then we can get the problem in the test print.
Re: Consistent Horizonal lines on the prints of a Delta printer September 09, 2020 06:00PM |
Mj996
hercek
I know what you are talking about that doesn't make any sense to me either.
About layer time and retraction,I wasn't talking about that pattern.Actually my printer prints small object specially column , pillars ,etc with terrible quality(like the chimney of my printed benchy in the images above) and Some people recommended increasing layer time and tuning retraction to solve this.Those helped a lot but It isn't still satisfying.
Nozzle clogging problem was solved by replacing the old nozzle with a new one.
