Rostock Max V2 - Help with new mainboard settings September 10, 2020 01:47PM |
>>> M503 SENDING:M503 echo: G21 ; Units in mm (mm) echo: M149 C ; Units in Celsius echo:; Filament settings: Disabled echo: M200 S0 D1.75 echo:; Steps per unit: echo: M92 X80.00 Y80.00 Z80.00 E836.00 echo:; Maximum feedrates (units/s): echo: M203 X500.00 Y500.00 Z500.00 E25.00 echo:; Maximum Acceleration (units/s2): echo: M201 X9000.00 Y9000.00 Z9000.00 E10000.00 echo:; Acceleration (units/s2): P R T echo: M204 P3000.00 R3000.00 T3000.00 echo:; Advanced: B S T X Y Z E echo: M205 B20000.00 S0.00 T0.00 X10.00 Y10.00 Z10.00 E5.00 echo:; Endstop adjustment: echo: M666 X0.00 Y0.00 Z0.00 echo:; Delta settings: L R H S XYZ ABC echo: M665 L270.00 R135.20 H300.00 S200.00 X0.00 Y0.00 Z0.00 A0.00 B0.00 C0.00 echo:; Material heatup parameters: echo: M145 S0 H180 B70 F255 echo: M145 S1 H240 B100 F255 echo:; PID settings: echo: M301 P22.20 I1.08 D114.00 echo:; Stepper driver current: echo: M906 X800 Y800 Z800 echo: M906 T0 E800 echo:; Driver stepping mode: echo: M569 S1 X Y Z echo: M569 S1 T0 E
Re: Rostock Max V2 - Help with new mainboard settings September 10, 2020 09:09PM |
Re: Rostock Max V2 - Help with new mainboard settings September 11, 2020 11:07AM |
#define DELTA_PRINTABLE_RADIUS 290.0
#define DELTA_RADIUS 200 // (mm) Get this value from G33 auto calibrate
//=========================================================================== //============================== Delta Settings ============================= //=========================================================================== // Enable DELTA kinematics and most of the default configuration for Deltas #define DELTA #if ENABLED(DELTA) // Make delta curves from many straight lines (linear interpolation). // This is a trade-off between visible corners (not enough segments) // and processor overload (too many expensive sqrt calls). #define DELTA_SEGMENTS_PER_SECOND 200 // After homing move down to a height where XY movement is unconstrained //#define DELTA_HOME_TO_SAFE_ZONE // Delta calibration menu // uncomment to add three points calibration menu option. // See [minow.blogspot.com] #define DELTA_CALIBRATION_MENU // uncomment to add G33 Delta Auto-Calibration (Enable EEPROM_SETTINGS to store results) //#define DELTA_AUTO_CALIBRATION // NOTE NB all values for DELTA_* values MUST be floating point, so always have a decimal point in them #if ENABLED(DELTA_AUTO_CALIBRATION) // set the default number of probe points : n*n (1 -> 7) #define DELTA_CALIBRATION_DEFAULT_POINTS 4 #endif #if EITHER(DELTA_AUTO_CALIBRATION, DELTA_CALIBRATION_MENU) // Set the steprate for papertest probing #define PROBE_MANUALLY_STEP 0.05 // (mm) #endif // Print surface diameter/2 minus unreachable space (avoid collisions with vertical towers). #define DELTA_PRINTABLE_RADIUS 290.0 // (mm) // Center-to-center distance of the holes in the diagonal push rods. #define DELTA_DIAGONAL_ROD 270.0 // (mm) // Distance between bed and nozzle Z home position #define DELTA_HEIGHT 300.00 // (mm) Get this value from G33 auto calibrate #define DELTA_ENDSTOP_ADJ { 0.0, 0.0, 0.0 } // Get these values from G33 auto calibrate // Horizontal distance bridged by diagonal push rods when effector is centered. #define DELTA_RADIUS 200 // (mm) Get this value from G33 auto calibrate // Trim adjustments for individual towers // tower angle corrections for X and Y tower / rotate XYZ so Z tower angle = 0 // measured in degrees anticlockwise looking from above the printer #define DELTA_TOWER_ANGLE_TRIM { 0.0, 0.0, 0.0 } // Get these values from G33 auto calibrate // Delta radius and diagonal rod adjustments (mm) //#define DELTA_RADIUS_TRIM_TOWER { 0.0, 0.0, 0.0 } //#define DELTA_DIAGONAL_ROD_TRIM_TOWER { 0.0, 0.0, 0.0 } #endif
Re: Rostock Max V2 - Help with new mainboard settings September 11, 2020 11:53AM |
Re: Rostock Max V2 - Help with new mainboard settings September 12, 2020 06:59AM |
Re: Rostock Max V2 - Help with new mainboard settings September 12, 2020 07:57AM |
// Delta only homes to Z #define HOMING_FEEDRATE_Z (200*60)
Re: Rostock Max V2 - Help with new mainboard settings September 12, 2020 08:54AM |
#define HOMING_FEEDRATE_Z (10*60)
SENT: M119 READ: Reporting endstop status READ: x_max: TRIGGERED READ: y_max: open READ: z_max: open
Re: Rostock Max V2 - Help with new mainboard settings September 12, 2020 09:27AM |
Re: Rostock Max V2 - Help with new mainboard settings September 12, 2020 09:58AM |
Re: Rostock Max V2 - Help with new mainboard settings September 12, 2020 03:06PM |
Re: Rostock Max V2 - Help with new mainboard settings September 12, 2020 03:10PM |
Re: Rostock Max V2 - Help with new mainboard settings October 10, 2020 06:03AM |
RostockDude
Thank you kindly dear thehankinator!
I´ve gotten my old printer to work again with a new 32-bit mainboard. This makes me immensly happy!
Just a little support and helping attitude gave me the extra energy to keep pushing.
It all works fine now! I just have to calibrate everything in finner detail now!
All the best!
Re: Rostock Max V2 - Help with new mainboard settings January 28, 2023 09:47AM |
