hello fellows,
i have finished my rostock robot from mechanical side and trying for 3 days now to calibrate it. the problem i am facing is,
that i can not find a accaptable way to get the z-"lift" and the correct size in x & y under one hat.
i am using repetier firmware and a traxxas ball rostock
my config-file looks like that for example:
#define DELTA_DIAGONAL_ROD 230.0 // mm
/** \brief Number of segments to generate for delta conversions per second of move
#define DELTA_SEGMENTS_PER_SECOND_PRINT 200 // Move accurate setting for print moves
#define DELTA_SEGMENTS_PER_SECOND_MOVE 70 // Less accurate setting for other moves
/** \brief Horizontal offset of the universal joints on the end effector (moving platform).
#define END_EFFECTOR_HORIZONTAL_OFFSET 33
/** \brief Horizontal offset of the universal joints on the vertical carriages.
#define CARRIAGE_HORIZONTAL_OFFSET 22
/** \brief Printer radius in mm, measured from the center of the print area to the vertical smooth rod.
#define PRINTER_RADIUS 140
/** \brief Horizontal distance bridged by the diagonal push rod when the end effector is in the center. It is pretty close to 50% of the push rod length (250 mm).
#define DELTA_RADIUS (PRINTER_RADIUS-END_EFFECTOR_HORIZONTAL_OFFSET-CARRIAGE_HORIZONTAL_OFFSET)
in a few posts one can find this guide
http://minow.blogspot.com.au/ for calibrating a rostock.
the strange thing here according to mine rostock is:
when i get the z lift correct my x-y dimensions are way off what they should be . if i change the rod lengths after setting the printer radius i get a z-lift again.... so both variables effect z-lift..
what i am doing wrong? can the push-rods be too long? i am using a bit smaller baseplate so the smoth-rod radius is a bit smaller than it should be, but can this effect the geometrie like this?
thanks a lot
