Rostock Mini Homing Fail
Posted by labmat
April 30, 2013 08:55PM
I am trying to commission my Rostock Mini but am having trouble with homing, the axes all slam into the endstops but fail to stop. I am running Marlin V1 for Kossel on a RAMPS 1.1 board and have the Signal and Ground or each axes MAX limit wired to the NC termanals of each microswitch. I have verified that endstoppullups are enabled in firmware and a quick continuity test shows that the switches are working. The only thing I do not know how to do is verify that the RAMPS board is reading the switches. Is there a way to monitor the switches in firmware?
Here is a video of my Rostock
Re: Rostock Mini Homing Fail
April 30, 2013 09:03PM
Send gcode M119 to get the current endstop status.
The MAX endstops are undefined for RAMPS 1.1, so you'll need to edit pins.h before you can read them
April 30, 2013 09:28PM
Is this correct? I have never edited a pins.h file before
* Arduino Mega pin assignment
#if MOTHERBOARD == 3 || MOTHERBOARD == 33 || MOTHERBOARD == 34
#define KNOWN_BOARD 1
//////////////////FIX THIS//////////////
#ifndef __AVR_ATmega1280__
 #ifndef __AVR_ATmega2560__
 #error Oops!  Make sure you have 'Arduino Mega' selected from the 'Tools -> Boards' menu.
 #endif
#endif
// uncomment one of the following lines for RAMPS v1.3 or v1.0, comment both for v1.2 or 1.1
// #define RAMPS_V_1_3
// #define RAMPS_V_1_0
#if MOTHERBOARD == 33 || MOTHERBOARD == 34
#define X_STEP_PIN         54
#define X_DIR_PIN          55
#define X_ENABLE_PIN       38
#define X_STOP_PIN          2
#define Y_STEP_PIN         60
#define Y_DIR_PIN          61
#define Y_ENABLE_PIN       56
#define Y_STOP_PIN         15
#define Z_STEP_PIN         46
#define Z_DIR_PIN          48
#define Z_ENABLE_PIN       62
#define Z_STOP_PIN         19
#define Z2_STEP_PIN        36
#define Z2_DIR_PIN         34
#define Z2_ENABLE_PIN      30
#define E0_STEP_PIN        26
#define E0_DIR_PIN         28
#define E0_ENABLE_PIN      24
#define E1_STEP_PIN        36
#define E1_DIR_PIN         34
#define E1_ENABLE_PIN      30
#define SDPOWER            -1
#define SDSS               53
#define LED_PIN            13
#define FAN_PIN            9 // (Sprinter config)
#else
#define FAN_PIN            4 // IO pin. Buffer needed
#endif
#define PS_ON_PIN          12
#ifdef REPRAP_DISCOUNT_SMART_CONTROLLER
#define KILL_PIN           41
#else
#define KILL_PIN           -1
#endif
#define HEATER_0_PIN       10   // EXTRUDER 1
#define HEATER_1_PIN       -1
#else
#define HEATER_1_PIN       9    // EXTRUDER 2 (FAN On Sprinter)
#endif
#define HEATER_2_PIN       -1
#define TEMP_0_PIN         13   // ANALOG NUMBERING
#define TEMP_1_PIN         15   // ANALOG NUMBERING
#define TEMP_2_PIN         -1   // ANALOG NUMBERING
#define HEATER_BED_PIN     8    // BED
#define TEMP_BED_PIN       14   // ANALOG NUMBERING
#ifdef ULTRA_LCD
  #ifdef NEWPANEL
     //encoder rotation values
    #define encrot0 0
    #define encrot1 2
    #define encrot2 3
    #define encrot3 1
    #define BLEN_A 0
    #define BLEN_B 1
    #define BLEN_C 2
    #define LCD_PINS_RS 16
    #define LCD_PINS_ENABLE 17
    #define LCD_PINS_D4 23
    #define LCD_PINS_D5 25
    #define LCD_PINS_D6 27
    #define LCD_PINS_D7 29
      #define BEEPER 37
      #define BTN_EN1 31
      #define BTN_EN2 33
      #define BTN_ENC 35
      #define SDCARDDETECT 49
    #else
      //arduino pin which triggers an piezzo beeper
      #define BEEPER 33	 // Beeper on AUX-4
      //buttons are directly attached using AUX-2
      #define BTN_EN1 37
      #define BTN_EN2 35
      #define BTN_ENC 31  //the click
      #define SDCARDDETECT -1  // Ramps does not use this port
    #endif
  #else //old style panel with shift register
    //arduino pin witch triggers an piezzo beeper
    #define BEEPER 33		No Beeper added
    //buttons are attached to a shift register
	// Not wired this yet
    //#define SHIFT_CLK 38
    //#define SHIFT_LD 42
    //#define SHIFT_OUT 40
    //#define SHIFT_EN 17
    #define encrot0 0
    #define encrot1 2
    #define encrot2 3
    #define encrot3 1
    //bits in the shift register that carry the buttons for:
    // left up center down right red
    #define BL_LE 7
    #define BL_UP 6
    #define BL_MI 5
    #define BL_DW 4
    #define BL_RI 3
    #define BL_ST 2
    #define BLEN_B 1
    #define BLEN_A 0
  #endif
#endif //ULTRA_LCD
#else // RAMPS_V_1_1 or RAMPS_V_1_2 as default (MOTHERBOARD == 3)
#define X_STEP_PIN         26
#define X_DIR_PIN          28
#define X_ENABLE_PIN       24
#define X_MIN_PIN           3
#define X_MAX_PIN           2
#define Y_STEP_PIN         38
#define Y_DIR_PIN          40
#define Y_ENABLE_PIN       36
#define Y_MIN_PIN          16
#define Y_MAX_PIN          17
#define Z_STEP_PIN         44
#define Z_DIR_PIN          46
#define Z_ENABLE_PIN       42
#define Z_MIN_PIN          18
#define Z_MAX_PIN          19
#define E0_STEP_PIN         32
#define E0_DIR_PIN          34
#define E0_ENABLE_PIN       30
#define SDPOWER            48
#define SDSS               53
#define LED_PIN            13
#define PS_ON_PIN          -1
#define KILL_PIN           -1
#ifdef RAMPS_V_1_0 // RAMPS_V_1_0
  #define HEATER_0_PIN     12    // RAMPS 1.0
  #define HEATER_BED_PIN   -1    // RAMPS 1.0
  #define FAN_PIN          11    // RAMPS 1.0
  #define HEATER_0_PIN     10    // RAMPS 1.1
  #define HEATER_BED_PIN    8    // RAMPS 1.1
  #define FAN_PIN           9    // RAMPS 1.1
#endif
#define TEMP_0_PIN          2    // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!!
#define TEMP_1_PIN          -1
#define TEMP_BED_PIN        1    // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!!
#endif// MOTHERBOARD == 33 || MOTHERBOARD == 34
// SPI for Max6675 Thermocouple
#ifndef SDSUPPORT
// these pins are defined in the SD library if building with SD support
  #define MAX_SCK_PIN          52
  #define MAX_MISO_PIN         50
  #define MAX_MOSI_PIN         51
  #define MAX6675_SS       53
#else
  #define MAX6675_SS       49
#endif
#endif//MOTHERBOARD == 3 || MOTHERBOARD == 33 || MOTHERBOARD == 34
With all switches triggered this is what Repitier reported
> 8:12:55 PM: N157 G119 *3
April 30, 2013 09:45PM
Ignore my Repetier results above I get different values everytime I run G119 no matter what I do so clearly I am doing something wrong.
April 30, 2013 10:23PM
Thats M119, not G119.
April 30, 2013 10:46PM
I'm such an idiot, I had the X & Y Endstops mixed up. She is homing like a champ now!
Also such a rookie mistake on the M119.
End Stops not triggered
< 9:36:02 PM: Reporting endstop status
< 9:36:02 PM: x_min: TRIGGERED
< 9:36:02 PM: x_max: open
< 9:36:02 PM: y_min: TRIGGERED
< 9:36:02 PM: y_max: open
< 9:36:02 PM: z_min: TRIGGERED
< 9:36:02 PM: z_max: open
End Stops triggered
< 9:36:25 PM: Reporting endstop status
< 9:36:25 PM: x_min: TRIGGERED
< 9:36:25 PM: x_max: TRIGGERED
< 9:36:25 PM: y_min: TRIGGERED
< 9:36:25 PM: y_max: TRIGGERED
< 9:36:25 PM: z_min: TRIGGERED
< 9:36:25 PM: z_max: TRIGGERED
I feel kinda dumb winking smiley
May 02, 2013 11:05PM
I thought I'd post this video of my first dry run after calibrating Z height and bed level.
June 17, 2013 11:00PM
Is that by chance raw output from the firmware to the host in response to the M119?
June 24, 2013 09:46AM
I believe so, this is what shows up in the log window of Repetier-Host.
