Rostock Mini Homing Fail April 30, 2013 08:55PM |
Re: Rostock Mini Homing Fail April 30, 2013 09:03PM |
Re: Rostock Mini Homing Fail April 30, 2013 09:28PM |
/**************************************************************************************** * Arduino Mega pin assignment * ****************************************************************************************/ #if MOTHERBOARD == 3 || MOTHERBOARD == 33 || MOTHERBOARD == 34 #define KNOWN_BOARD 1 //////////////////FIX THIS////////////// #ifndef __AVR_ATmega1280__ #ifndef __AVR_ATmega2560__ #error Oops! Make sure you have 'Arduino Mega' selected from the 'Tools -> Boards' menu. #endif #endif // uncomment one of the following lines for RAMPS v1.3 or v1.0, comment both for v1.2 or 1.1 // #define RAMPS_V_1_3 // #define RAMPS_V_1_0 #if MOTHERBOARD == 33 || MOTHERBOARD == 34 #define X_STEP_PIN 54 #define X_DIR_PIN 55 #define X_ENABLE_PIN 38 #define X_STOP_PIN 2 #define Y_STEP_PIN 60 #define Y_DIR_PIN 61 #define Y_ENABLE_PIN 56 #define Y_STOP_PIN 15 #define Z_STEP_PIN 46 #define Z_DIR_PIN 48 #define Z_ENABLE_PIN 62 #define Z_STOP_PIN 19 #define Z2_STEP_PIN 36 #define Z2_DIR_PIN 34 #define Z2_ENABLE_PIN 30 #define E0_STEP_PIN 26 #define E0_DIR_PIN 28 #define E0_ENABLE_PIN 24 #define E1_STEP_PIN 36 #define E1_DIR_PIN 34 #define E1_ENABLE_PIN 30 #define SDPOWER -1 #define SDSS 53 #define LED_PIN 13 #if MOTHERBOARD == 33 #define FAN_PIN 9 // (Sprinter config) #else #define FAN_PIN 4 // IO pin. Buffer needed #endif #define PS_ON_PIN 12 #ifdef REPRAP_DISCOUNT_SMART_CONTROLLER #define KILL_PIN 41 #else #define KILL_PIN -1 #endif #define HEATER_0_PIN 10 // EXTRUDER 1 #if MOTHERBOARD == 33 #define HEATER_1_PIN -1 #else #define HEATER_1_PIN 9 // EXTRUDER 2 (FAN On Sprinter) #endif #define HEATER_2_PIN -1 #define TEMP_0_PIN 13 // ANALOG NUMBERING #define TEMP_1_PIN 15 // ANALOG NUMBERING #define TEMP_2_PIN -1 // ANALOG NUMBERING #define HEATER_BED_PIN 8 // BED #define TEMP_BED_PIN 14 // ANALOG NUMBERING #ifdef ULTRA_LCD #ifdef NEWPANEL //encoder rotation values #define encrot0 0 #define encrot1 2 #define encrot2 3 #define encrot3 1 #define BLEN_A 0 #define BLEN_B 1 #define BLEN_C 2 #define LCD_PINS_RS 16 #define LCD_PINS_ENABLE 17 #define LCD_PINS_D4 23 #define LCD_PINS_D5 25 #define LCD_PINS_D6 27 #define LCD_PINS_D7 29 #ifdef REPRAP_DISCOUNT_SMART_CONTROLLER #define BEEPER 37 #define BTN_EN1 31 #define BTN_EN2 33 #define BTN_ENC 35 #define SDCARDDETECT 49 #else //arduino pin which triggers an piezzo beeper #define BEEPER 33 // Beeper on AUX-4 //buttons are directly attached using AUX-2 #define BTN_EN1 37 #define BTN_EN2 35 #define BTN_ENC 31 //the click #define SDCARDDETECT -1 // Ramps does not use this port #endif #else //old style panel with shift register //arduino pin witch triggers an piezzo beeper #define BEEPER 33 No Beeper added //buttons are attached to a shift register // Not wired this yet //#define SHIFT_CLK 38 //#define SHIFT_LD 42 //#define SHIFT_OUT 40 //#define SHIFT_EN 17 #define LCD_PINS_RS 16 #define LCD_PINS_ENABLE 17 #define LCD_PINS_D4 23 #define LCD_PINS_D5 25 #define LCD_PINS_D6 27 #define LCD_PINS_D7 29 //encoder rotation values #define encrot0 0 #define encrot1 2 #define encrot2 3 #define encrot3 1 //bits in the shift register that carry the buttons for: // left up center down right red #define BL_LE 7 #define BL_UP 6 #define BL_MI 5 #define BL_DW 4 #define BL_RI 3 #define BL_ST 2 #define BLEN_B 1 #define BLEN_A 0 #endif #endif //ULTRA_LCD #else // RAMPS_V_1_1 or RAMPS_V_1_2 as default (MOTHERBOARD == 3) #define X_STEP_PIN 26 #define X_DIR_PIN 28 #define X_ENABLE_PIN 24 #define X_MIN_PIN 3 #define X_MAX_PIN 2 #define Y_STEP_PIN 38 #define Y_DIR_PIN 40 #define Y_ENABLE_PIN 36 #define Y_MIN_PIN 16 #define Y_MAX_PIN 17 #define Z_STEP_PIN 44 #define Z_DIR_PIN 46 #define Z_ENABLE_PIN 42 #define Z_MIN_PIN 18 #define Z_MAX_PIN 19 #define E0_STEP_PIN 32 #define E0_DIR_PIN 34 #define E0_ENABLE_PIN 30 #define SDPOWER 48 #define SDSS 53 #define LED_PIN 13 #define PS_ON_PIN -1 #define KILL_PIN -1 #ifdef RAMPS_V_1_0 // RAMPS_V_1_0 #define HEATER_0_PIN 12 // RAMPS 1.0 #define HEATER_BED_PIN -1 // RAMPS 1.0 #define FAN_PIN 11 // RAMPS 1.0 #else // RAMPS_V_1_1 or RAMPS_V_1_2 #define HEATER_0_PIN 10 // RAMPS 1.1 #define HEATER_BED_PIN 8 // RAMPS 1.1 #define FAN_PIN 9 // RAMPS 1.1 #endif #define HEATER_1_PIN -1 #define HEATER_2_PIN -1 #define TEMP_0_PIN 2 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!! #define TEMP_1_PIN -1 #define TEMP_2_PIN -1 #define TEMP_BED_PIN 1 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!! #endif// MOTHERBOARD == 33 || MOTHERBOARD == 34 // SPI for Max6675 Thermocouple #ifndef SDSUPPORT // these pins are defined in the SD library if building with SD support #define MAX_SCK_PIN 52 #define MAX_MISO_PIN 50 #define MAX_MOSI_PIN 51 #define MAX6675_SS 53 #else #define MAX6675_SS 49 #endif #endif//MOTHERBOARD == 3 || MOTHERBOARD == 33 || MOTHERBOARD == 34
> 8:12:55 PM: N157 G119 *3
Re: Rostock Mini Homing Fail April 30, 2013 09:45PM |
Re: Rostock Mini Homing Fail April 30, 2013 10:23PM |
Re: Rostock Mini Homing Fail April 30, 2013 10:46PM |
< 9:36:02 PM: Reporting endstop status < 9:36:02 PM: x_min: TRIGGERED < 9:36:02 PM: x_max: open < 9:36:02 PM: y_min: TRIGGERED < 9:36:02 PM: y_max: open < 9:36:02 PM: z_min: TRIGGERED < 9:36:02 PM: z_max: open
< 9:36:25 PM: Reporting endstop status < 9:36:25 PM: x_min: TRIGGERED < 9:36:25 PM: x_max: TRIGGERED < 9:36:25 PM: y_min: TRIGGERED < 9:36:25 PM: y_max: TRIGGERED < 9:36:25 PM: z_min: TRIGGERED < 9:36:25 PM: z_max: TRIGGERED
Re: Rostock Mini Homing Fail May 02, 2013 11:05PM |
Re: Rostock Mini Homing Fail June 17, 2013 11:00PM |
Re: Rostock Mini Homing Fail June 24, 2013 09:46AM |
