Re: Grounded Experimental Delta Printer September 22, 2013 08:21AM |
pjoyce42
Actually my original thought would be to use some of the aluminum extrusions from 80/20 or rexroth. I don't know the exact numbers, but I would expect that the torsional stiffness is, at a minimum, comparable to the 3d printed plastic arms of the same cross-sectional area. I was trying to avoid round rods because then you would have to find a way to fix the rod. With the aluminum extrusions, you could print the female profile into the plastic end piece so that it just slots into place. I haven't done any math or modeling yet, so I'm just spitballing right now, but I can't think of a reason that the aluminum wouldn't have the necessary torsional rigidty.
Re: Grounded Experimental Delta Printer September 23, 2013 03:39AM |
Re: Grounded Experimental Delta Printer September 23, 2013 01:31PM |
Re: Grounded Experimental Delta Printer September 23, 2013 05:07PM |
Re: Grounded Experimental Delta Printer September 23, 2013 09:26PM |
Re: Grounded Experimental Delta Printer September 23, 2013 09:42PM |
Re: Grounded Experimental Delta Printer September 23, 2013 09:51PM |
Re: Grounded Experimental Delta Printer September 24, 2013 03:15AM |
Re: Grounded Experimental Delta Printer September 24, 2013 03:18AM |
Re: Grounded Experimental Delta Printer September 24, 2013 03:26AM |
Re: Grounded Experimental Delta Printer September 24, 2013 03:31AM |
Re: Grounded Experimental Delta Printer September 24, 2013 11:02AM |
Re: Grounded Experimental Delta Printer September 24, 2013 01:55PM |
Re: Grounded Experimental Delta Printer September 25, 2013 02:40PM |
Re: Grounded Experimental Delta Printer September 25, 2013 03:20PM |
Re: Grounded Experimental Delta Printer September 25, 2013 03:53PM |
Re: Grounded Experimental Delta Printer September 25, 2013 05:03PM |
Re: Grounded Experimental Delta Printer September 25, 2013 05:28PM |
Re: Grounded Experimental Delta Printer September 25, 2013 06:00PM |
Re: Grounded Experimental Delta Printer September 26, 2013 12:13AM |
Re: Grounded Experimental Delta Printer September 27, 2013 09:28AM |
Re: Grounded Experimental Delta Printer September 27, 2013 09:51AM |
Admin Registered: 13 years ago Posts: 730 |
Ralphxyz
But what would you use for a extruder hot end on a big Simpson?
Re: Grounded Experimental Delta Printer September 27, 2013 10:02AM |
Re: Grounded Experimental Delta Printer September 27, 2013 12:26PM |
nicholas.seward
expanding foam
Re: Grounded Experimental Delta Printer September 27, 2013 03:34PM |
Re: Grounded Experimental Delta Printer September 28, 2013 12:43AM |
Re: Grounded Experimental Delta Printer September 28, 2013 01:08AM |
Re: Grounded Experimental Delta Printer September 30, 2013 12:22AM |
Re: Grounded Experimental Delta Printer October 11, 2013 07:04PM |
Re: Grounded Experimental Delta Printer October 13, 2013 08:23AM |
