Re: Grounded Experimental Delta Printer November 08, 2013 10:36AM |
Re: Grounded Experimental Delta Printer November 08, 2013 11:03AM |
Re: Grounded Experimental Delta Printer November 08, 2013 01:21PM |
Re: Grounded Experimental Delta Printer November 08, 2013 01:29PM |
Re: Grounded Experimental Delta Printer November 08, 2013 04:04PM |
Re: Grounded Experimental Delta Printer November 08, 2013 05:50PM |
Re: Grounded Experimental Delta Printer November 12, 2013 10:18AM |
A2
@ Solidus Labs
A few questions:
- How many teeth on the worm wheel?
- Does the code need the quantity of teeth, or a ratio in order to work correctly?
- I'm curious how rigid the worm drive delta printer is, please make a video.
Power up the bot, and with your hands push on the end effector, does it feel solid?- It looks to me like the forearm is longer than the upper arm.
With unequal length arms, are you making compensations in the software, or is this a non issue?- Interesting use of the FR4 fiberglass on top.
I wonder if you could etch the copper, modify it in some way, and use it as a heater element?- Are you modifying Marlin? If so what version of Marlin are you modifying, can you post a link, and where did you insert the new math?
- I also would like to add encoders to each of the joints to further compensate for backlash.
LoboCNC is working on a design to add encoders to stepper motors.
Do you envision any problems adding encoders?
Closed-loop stepper controller progress
[forums.reprap.org]
Tks!
A2
Re: Grounded Experimental Delta Printer November 12, 2013 04:36PM |
Solidus Labs
1. It's a 90 tooth worm wheel.
2. Since the output of the code is in degrees, the steps per unit in the config are translated into steps per degrees. So 200*8*90/360= 400 steps per degree.
3. I will work on making a video; I have noticed that the rigidity changes depending on its position.
4. The l1 and l2 arm lengths are set in the config. They are handled in the formulas so it is not an issue.
5. I think this has been done, if the heat bed is a single sided pcb, you can print on the back. .60 FR4 is not the most rigid material so it does need some support.
6. I started with the marlin delta branch and replaced the delta formulas [github.com]
7. Closed loop is always nice, I personally prefer the dc servo setup but an encoder on an elbow could help the accuracy.
I hope I can get the calibration finished and start test printing by the end of this week.
Re: Grounded Experimental Delta Printer November 13, 2013 10:33AM |
Re: Grounded Experimental Delta Printer November 23, 2013 04:33PM |
Re: Grounded Experimental Delta Printer November 26, 2013 04:10AM |
A2
I'm just wondering if a few vitamins (end stops) can be eliminated with software.
Bed leveling, and end stops are they really required, or can we with precision manufacturing, and software eliminate them?
Re: Grounded Experimental Delta Printer November 26, 2013 04:46AM |
TheTechnicalNoob
But the software needs to know what position the arms are in.
Re: Grounded Experimental Delta Printer November 26, 2013 04:51AM |
Re: Grounded Experimental Delta Printer November 26, 2013 05:31AM |
Re: Grounded Experimental Delta Printer November 26, 2013 06:10AM |
Re: Grounded Experimental Delta Printer November 26, 2013 06:27AM |
Re: Grounded Experimental Delta Printer November 26, 2013 06:32AM |
Re: Grounded Experimental Delta Printer November 26, 2013 06:56AM |
Re: Grounded Experimental Delta Printer November 26, 2013 07:24AM |
TheTechnicalNoob
Your endstopless calibration method should work, but I think I like endstops better: more precise and less error prone, less work.
Re: Grounded Experimental Delta Printer November 26, 2013 11:09AM |
Re: Grounded Experimental Delta Printer November 26, 2013 11:43AM |
Re: Grounded Experimental Delta Printer November 26, 2013 05:05PM |
GeorgeH
That's terrifyingly large, but I think I can print it if I do it sideways.
Whoo! I'll be printing ASAP then!
Re: Grounded Experimental Delta Printer November 26, 2013 05:22PM |
Re: Grounded Experimental Delta Printer November 26, 2013 05:37PM |
Re: Grounded Experimental Delta Printer November 27, 2013 01:44AM |
Re: Grounded Experimental Delta Printer November 27, 2013 01:55AM |
Re: Grounded Experimental Delta Printer November 27, 2013 01:56AM |
Re: Grounded Experimental Delta Printer November 27, 2013 07:37AM |
Re: Grounded Experimental Delta Printer November 27, 2013 11:05AM |
Re: Grounded Experimental Delta Printer November 27, 2013 11:42AM |
