Calibrating Geared Extruder May 13, 2013 08:45PM |
Re: Calibrating Geared Extruder May 14, 2013 02:17AM |
Re: Calibrating Geared Extruder May 15, 2013 06:48AM |
Re: Calibrating Geared Extruder May 15, 2013 07:11AM |
johnpanter
...Not tried to extrude at any speed yet as the extruder isnt calibrated...
johnpanter
Using 'Triffid Hunter's Calibration guide -
After a pronterface manual extrude of 100mm, I get 16mm through the extruder.
Re: Calibrating Geared Extruder May 15, 2013 11:46AM |
Re: Calibrating Geared Extruder May 15, 2013 12:48PM |
// default settings
#define DEFAULT_AXIS_STEPS_PER_UNIT {2*200/1.5, 2*200/1.5, 4*200/1.5, 16*200/(6.69215015*3.14159264)*47/9} // default steps per unit for RILstrap
#define DEFAULT_MAX_FEEDRATE { 70, 70, 35, 25} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {200,200,100,150} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot.
Re: Calibrating Geared Extruder May 15, 2013 12:51PM |
Re: Calibrating Geared Extruder June 12, 2014 11:33PM |
Re: Calibrating Geared Extruder June 17, 2014 12:23PM |
Re: Calibrating Geared Extruder June 18, 2014 02:28AM |
frankenfrankenstuff
OK so the fix I found was.....to just pull the 3 jumpers out from under the driver. 10mm now extrudes a bit over 10mm. Done.
Re: Calibrating Geared Extruder November 26, 2015 09:59PM |
