Re: The "Flying Extruder" Mod December 09, 2015 04:17AM |
Re: The "Flying Extruder" Mod December 09, 2015 04:18AM |
Re: The "Flying Extruder" Mod December 09, 2015 04:47AM |
DjDemonD
Sounds good I see there is a 100:1 nema 11 being offered also why not use that one? Would need much less motor current.
Re: The "Flying Extruder" Mod December 09, 2015 04:49AM |
o_lampe
The idea of the suspension is to enable the extruder to follow the effector moves without adding the mass/inertia to the equation.
How would you build a fixed platform between three carriers that move up and down independently?
-Olaf
Re: The "Flying Extruder" Mod December 09, 2015 05:42AM |
dc42
DjDemonD
The motor speed and therefore the steps/mm would be very high. If your controller has variable microstepping or jumpers to set the microstepping, then you could reduce extruder microstepping to bring the steps/mm down to a value that the controller can handle. However, you might need more drive voltage than the controller can provide to maintain the speed. Using 24V power would help substantially, but even that might not be enough.
Re: The "Flying Extruder" Mod December 09, 2015 06:15AM |
Re: The "Flying Extruder" Mod December 10, 2015 05:29AM |
Re: The "Flying Extruder" Mod December 10, 2015 05:39AM |
Re: The "Flying Extruder" Mod December 10, 2015 05:42AM |
Re: The "Flying Extruder" Mod December 10, 2015 05:46AM |
Re: The "Flying Extruder" Mod December 10, 2015 08:39AM |
Re: The "Flying Extruder" Mod December 12, 2015 08:41AM |
Flex3drive seler responded to my questions:Quote
DjDemonD
I which case I wonder how the flex3drive handles retraction as it is highly geared.
Re: The "Flying Extruder" Mod January 06, 2016 07:49PM |
Re: The "Flying Extruder" Mod January 08, 2016 09:23AM |
Re: The "Flying Extruder" Mod January 08, 2016 09:31AM |
Re: The "Flying Extruder" Mod January 08, 2016 10:20AM |
Re: The "Flying Extruder" Mod January 08, 2016 12:37PM |
Re: The "Flying Extruder" Mod January 08, 2016 05:47PM |
Re: The "Flying Extruder" Mod January 08, 2016 07:39PM |
Re: The "Flying Extruder" Mod January 08, 2016 08:07PM |
Re: The "Flying Extruder" Mod January 08, 2016 11:04PM |
Re: The "Flying Extruder" Mod January 09, 2016 08:09PM |
Re: The "Flying Extruder" Mod January 10, 2016 10:57PM |
DjDemonD
Here is a marvin printed on my kossel at 0.1mm layer height.
Re: The "Flying Extruder" Mod January 11, 2016 05:27AM |
nebbian
Thank you all for posting your ideas and experiences with this system.
I finally put mine together tonight, here's a picture of it:
[attachment 69215 IMG_5147.jpeg]
Haven't had much time with it yet, but I have high hopes. I've hit the limits of a long bowden tube, this one is 5 times shorter than the old system so that's got to be 5 times better, right?
Looking forward to seeing how it performs.
Looks fantastic.
Re: The "Flying Extruder" Mod January 11, 2016 06:23AM |
nebbian
DjDemonD
That's a nice Marvin, well done! I find white models very difficult to photograph well, the detail always ends up being washed out.
Are you using ABS or PLA? Do you have a layer fan? Your keyring seems better than mine, but I think the eyes on mine are better than yours. Hard to tell from the picture.
Re: The "Flying Extruder" Mod January 11, 2016 08:47AM |
Rossini
any chance you release your flying extruder on thingiverse?Looks fantastic.
Re: The "Flying Extruder" Mod February 03, 2016 06:36AM |
nebbian
Rossini
Thanks Rossini,
Here you go:
[www.thingiverse.com]
You'll have to bodge up your own brackets to mount the rubber bands on your carriages, I just used some thin wire I had lying around.
Re: The "Flying Extruder" Mod February 03, 2016 08:20AM |
Re: The "Flying Extruder" Mod February 03, 2016 08:45AM |
Re: The "Flying Extruder" Mod February 03, 2016 12:15PM |
