Re: The "Flying Extruder" Mod May 10, 2017 04:08PM |
Re: The "Flying Extruder" Mod May 10, 2017 04:47PM |
Re: The "Flying Extruder" Mod May 10, 2017 09:11PM |
Re: The "Flying Extruder" Mod May 11, 2017 06:51AM |
Re: The "Flying Extruder" Mod May 19, 2017 06:32PM |
Re: The "Flying Extruder" Mod May 20, 2017 06:46PM |
Re: The "Flying Extruder" Mod May 21, 2017 01:58AM |
Re: The "Flying Extruder" Mod May 21, 2017 05:22AM |
Re: The "Flying Extruder" Mod May 21, 2017 06:52PM |
Lykle
Cable driven setup is when you use a Remote Direct Drive (RDD)
The RDD leaves the stepper mounted on the printer frame somewhere and a drive cable then powers the extruder part mounted directly on the effector or print head.
This makes sure the extruder part is as light as possible, in the Nimble case less than 27 grams, while you still have a direct driven extruder.
Basically, you have all the benefits of both bowden and direct drive, with none of the disadvantages.
RDD is a good alternative to a flying extruder.
Re: The "Flying Extruder" Mod May 22, 2017 04:42AM |
Re: The "Flying Extruder" Mod May 22, 2017 05:25AM |
titeuf007
Lykle
nimble is pretty damn expansive!!! 50euro will be an honest price but 80 for this..
Re: The "Flying Extruder" Mod May 22, 2017 07:30AM |
hercek
You probably can built it yourself. Try a hard steel wire in the range of 1 - 1.5 mm. The wire can be placed in a bowden but it is not necessary. You will need quite a significant gearing (probably in the range of 130-60)) so that the torsion forces on the wire are not too high.
Re: The "Flying Extruder" Mod May 22, 2017 07:34AM |
o_lampe
hercek
Wouldn't that create even more side-forces to the coldend that a bowden tube alone?
I wondered, how spectra line would act in a bowden tube, when it's used as winch drive? There wouldn't be a need for a worm drive anymore, just make the winch pulley big enough.
Re: The "Flying Extruder" Mod May 23, 2017 03:04AM |
Re: The "Flying Extruder" Mod June 08, 2017 12:17PM |
