What tolerance is there on the angle of the brackets, I'd guess 1-2 degrees? Does that cause issues with alignment seeing as they are so rigidly defined?
Also on this site we tend to know how much things cost and also appreciate people require profit as a motivation, however, 1300EUR is more than a bit steep..
Also - A laser cut acrylic extruder!!
Good luck I hope you find a feature to help you stand above the crowd of delta's!
