Re: RepRap 3DR Delta printer Released November 17, 2013 02:28AM |
Re: RepRap 3DR Delta printer Released November 17, 2013 03:40PM |
M666 X-5 Y-5 Z-5(using "-5" as example) but if I then run:
M500close Repetier Host and try a print with a SD (without connecting to the computer) it doesn't remember the M666 calibration.
Re: RepRap 3DR Delta printer Released November 18, 2013 03:55PM |
Re: RepRap 3DR Delta printer Released November 18, 2013 05:20PM |
RepRap 3DR Delta Cover November 20, 2013 03:16PM |
Anonymous User
Re: RepRap 3DR Delta printer Released November 22, 2013 09:33AM |
I enabled eeprom and can now access those settings from within Repetier Host, but when I change any axis offsets it effects the cartesian positioning and not the individual motors: i.e. when I set the X offset to 10mm I get movement of the printhead 10mm to right of center and not the X tower individually moving as if offset from the endstop as desired.|
Re: RepRap 3DR Delta printer Released November 22, 2013 05:34PM |
Anonymous User
Re: RepRap 3DR Delta printer Released November 22, 2013 05:55PM |
Re: RepRap 3DR Delta printer Released November 22, 2013 07:56PM |
Anonymous User
Re: RepRap 3DR Delta printer Released November 23, 2013 08:02PM |
Re: RepRap 3DR Delta printer Released November 24, 2013 05:00AM |
lcd.print('X');
lcd.print(ftostr3(current_position[X_AXIS]));
lcd_printPGM(PSTR(" Y"));
lcd.print(ftostr3(current_position[Y_AXIS]));
// convert float to string with +123 format
char *ftostr30(const float &x)
int xx=x;
conv[0]=(xx>=0)?'+':'-';
xx=abs(xx);
conv[1]=(xx/100)%10+'0';
conv[2]=(xx/10)%10+'0';
conv[3]=(xx)%10+'0';
conv[4]=0;
return conv;
char *ftostr30(const float &x);
#ifdef DELTA
MENU_ITEM_EDIT(float3, MSG_VZ_JERK, &max_z_jerk, 1, 990);
#else
MENU_ITEM_EDIT(float52, MSG_VZ_JERK, &max_z_jerk, 0.1, 990);
#endif
#ifdef DELTA
MENU_ITEM_EDIT(float52, MSG_ZSTEPS, &axis_steps_per_unit[Z_AXIS], 5, 9999);
#else
MENU_ITEM_EDIT(float51, MSG_ZSTEPS, &axis_steps_per_unit[Z_AXIS], 5, 9999);
#endif
Re: RepRap 3DR Delta printer Released November 24, 2013 05:07AM |
Re: RepRap 3DR Delta printer Released November 24, 2013 12:09PM |
Re: RepRap 3DR Delta printer Released November 25, 2013 06:23AM |
Anonymous User
Re: RepRap 3DR Delta printer Released November 25, 2013 06:41PM |
HaDe thanks for the tips on the mechanical side. I've been using a piece of 1/2" cast aluminum tooling plate for checking calibration. It's spec'd at 0.005" per foot flatness for the the size of the 3DR it should be withing a couple mils. None, the less I check everything and found my plate to be rocking a bit so I glued sandpaper to one side and worked on knowing off the high spots on the 3DR base. I also found I was using a differnet style ball link on the dial indicator holder and this was causing the diagonal rods to be slighly out of parallel with the tower slides. So after making those changes I started again using the M666 command for setting the offsets. I also decided to use a 100mm base circle for all measurements and when I got done everything was withing about 0.1mm (4 mils). If I push the center out beyond a 50mm radius, the flatness gets worse. At least now I am printing some pretty decent parts and can start learning how to operate the machine and see what slicing parameters it likes.|
Re: RepRap 3DR Delta printer Released November 25, 2013 07:05PM |
Re: RepRap 3DR Delta printer Released November 25, 2013 10:45PM |
Re: RepRap 3DR Delta printer Released November 28, 2013 03:10AM |
Re: RepRap 3DR Delta printer Released December 01, 2013 04:43PM |
Re: RepRap 3DR Delta printer Released December 02, 2013 12:07PM |
Re: RepRap 3DR Delta printer Released December 02, 2013 12:37PM |
Re: RepRap 3DR Delta printer Released December 02, 2013 01:00PM |
Re: RepRap 3DR Delta printer Released December 02, 2013 02:33PM |
Re: RepRap 3DR Delta printer Released December 03, 2013 02:38AM |
Re: RepRap 3DR Delta printer Released December 03, 2013 08:23AM |
Re: RepRap 3DR Delta printer Released December 03, 2013 12:58PM |
Re: RepRap 3DR Delta printer Released December 04, 2013 03:43AM |
Re: RepRap 3DR Delta printer Released December 05, 2013 02:04PM |
Re: RepRap 3DR Delta printer Released December 05, 2013 03:44PM |
Re: RepRap 3DR Delta printer Released December 05, 2013 06:14PM |
