Re: RepRap 3DR Delta printer Released November 17, 2013 02:28AM |
Re: RepRap 3DR Delta printer Released November 17, 2013 03:40PM |
M666 X-5 Y-5 Z-5(using "-5" as example) but if I then run:
M500close Repetier Host and try a print with a SD (without connecting to the computer) it doesn't remember the M666 calibration.
Re: RepRap 3DR Delta printer Released November 18, 2013 03:55PM |
Re: RepRap 3DR Delta printer Released November 18, 2013 05:20PM |
RepRap 3DR Delta Cover November 20, 2013 03:16PM |
Re: RepRap 3DR Delta printer Released November 22, 2013 09:33AM |
Re: RepRap 3DR Delta printer Released November 22, 2013 05:34PM |
Re: RepRap 3DR Delta printer Released November 22, 2013 05:55PM |
Re: RepRap 3DR Delta printer Released November 22, 2013 07:56PM |
Re: RepRap 3DR Delta printer Released November 23, 2013 08:02PM |
Re: RepRap 3DR Delta printer Released November 24, 2013 05:00AM |
lcd.print('X'); lcd.print(ftostr3(current_position[X_AXIS])); lcd_printPGM(PSTR(" Y")); lcd.print(ftostr3(current_position[Y_AXIS]));
// convert float to string with +123 format char *ftostr30(const float &x) { int xx=x; conv[0]=(xx>=0)?'+':'-'; xx=abs(xx); conv[1]=(xx/100)%10+'0'; conv[2]=(xx/10)%10+'0'; conv[3]=(xx)%10+'0'; conv[4]=0; return conv; }
char *ftostr30(const float &x);
#ifdef DELTA MENU_ITEM_EDIT(float3, MSG_VZ_JERK, &max_z_jerk, 1, 990); #else MENU_ITEM_EDIT(float52, MSG_VZ_JERK, &max_z_jerk, 0.1, 990); #endif
#ifdef DELTA MENU_ITEM_EDIT(float52, MSG_ZSTEPS, &axis_steps_per_unit[Z_AXIS], 5, 9999); #else MENU_ITEM_EDIT(float51, MSG_ZSTEPS, &axis_steps_per_unit[Z_AXIS], 5, 9999); #endif
Re: RepRap 3DR Delta printer Released November 24, 2013 05:07AM |
Re: RepRap 3DR Delta printer Released November 24, 2013 12:09PM |
Re: RepRap 3DR Delta printer Released November 25, 2013 06:23AM |
Re: RepRap 3DR Delta printer Released November 25, 2013 06:41PM |
Re: RepRap 3DR Delta printer Released November 25, 2013 07:05PM |
Re: RepRap 3DR Delta printer Released November 25, 2013 10:45PM |
Re: RepRap 3DR Delta printer Released November 28, 2013 03:10AM |
Re: RepRap 3DR Delta printer Released December 01, 2013 04:43PM |
Re: RepRap 3DR Delta printer Released December 02, 2013 12:07PM |
Re: RepRap 3DR Delta printer Released December 02, 2013 12:37PM |
Re: RepRap 3DR Delta printer Released December 02, 2013 01:00PM |
Re: RepRap 3DR Delta printer Released December 02, 2013 02:33PM |
Re: RepRap 3DR Delta printer Released December 03, 2013 02:38AM |
Re: RepRap 3DR Delta printer Released December 03, 2013 08:23AM |
Re: RepRap 3DR Delta printer Released December 03, 2013 12:58PM |
Re: RepRap 3DR Delta printer Released December 04, 2013 03:43AM |
Re: RepRap 3DR Delta printer Released December 05, 2013 02:04PM |
Re: RepRap 3DR Delta printer Released December 05, 2013 03:44PM |
Re: RepRap 3DR Delta printer Released December 05, 2013 06:14PM |
