RepRap 3DR Delta printer Released
Posted by richrap
Re: RepRap 3DR Delta printer Released
January 11, 2014 04:44AM
I have used vanilla ErikZalm Marlin firmware to assure to have the most updated firmware, modifying the parameters that RichRap had on his and using mines when required.
My microstepping setting ("#define MICROSTEP_MODES" at "configuration_adv.h") is set to 16 as I thought it was a parameter inherited from the stepper (Nema 17, these ones) and drivers (A4988, these ones). Should I try 32 microsteps?
HaDe, you said "RUMBA set to 32 microsteps for X/Y/Z"... where in firmware is written that?
January 11, 2014 05:32AM
>> Should I try 32 microsteps? <<
As I just said, I didn't notice much difference. I see you're using A4988 drivers which support only 16 microsteps, so if you want to try 32 you'd have to replace those by DRV8825 types.
>> where in firmware is written that? <<
Look at the line above the MICROSTEP_MODES setting which mentions "// Microstep setting (Only functional when stepper driver microstep pins are connected to MCU.". Which board do you have? The ones I know require setting microsteps via switches directly on the board (check your hardware documentation), so MICROSTEP_MODES will have no effect.
January 11, 2014 11:36AM
I have RUMBA board, I'll check if I should set it manually in the board, I thought it was a firmware config...
I forgot to mention that I also have the Chinese bearing... I feel they are not good quality that's why I want to try with a set of ABS printed ones, in case the vibration and noise are reduced I can think about buying quality bearings.
January 21, 2014 05:27PM
Vibration update:
I checked the stepper driver jumpers of my RUMBA and they are set to (1, 1, 1) so I guess it is the correct position for my Pololus A4988 and 16 microstepping.
I have tried ABS printed linear bearing and they aren't the ones that causes the vibration.
I have played with various Slic3r configs and I think the problem is related with movement speeds:
  • at about 20mm/s I get vibration but above 30mm/s everything goes fine
  • when moving along a line, it vibrates in the center... I thing it's due accelerations but I don't know to to manage this feature. I see how it start the line at a higher speed but it reduces in the second third of the whole line, finally the speed goes higher at the last third of the line.
So, I'll continue trying different configurations but, I think it would be great to have any of your Slic3r config in order to compare with mines and see how it goes. What speeds and accelerations do you use on your 3DR? I know RIchRap is working on a new post about Slic3r configuration and tunning for our 3DR but surely you guys have one working smoothly so that I can try.
One last thing, checking the steppers and its parts, I have seen that the steps per millimeter are set by RichRap on 55.5 but doing a calculation with the spools (in fact, with the .stl provided by him) it goes to 56.588:
steps_per_mm = ((360/motor_step_angle) * driver_microstep) / thread_pitch = ((360/1.8) * 16 ) / 56.549 = 56.588
January 21, 2014 06:57PM
>> would be great to have any of your Slic3r config in order to compare with mines and see how it goes <<
Attached please find my current Slic3r settings (for 0.1mm layers)... and this is the relevant section of my Marlin config:
#define DEFAULT_AXIS_STEPS_PER_UNIT   {110.6, 110.6, 110.6, 230}
#define DEFAULT_MAX_FEEDRATE          {380, 380, 380, 50}    // (mm/sec)
#define DEFAULT_MAX_ACCELERATION      {9000, 9000, 9000, 9000}  // X, Y, Z, E maximum start speed for accelerated moves
#define DEFAULT_ACCELERATION          3000    // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION  3000   // X, Y, Z and E max acceleration in mm/s^2 for retracts
#define DEFAULT_XYJERK               35.0    // (mm/sec)
#define DEFAULT_ZJERK                 35.0    // (mm/sec) Must be same as XY for delta
#define DEFAULT_EJERK                 20.0    // (mm/sec)
open | download - config.ini (3.5 KB)
January 21, 2014 09:40PM
Yesterday I have printed the first object with the 3DR. I started with 50 mm/s and used Repetier Host to increase the speed while printing. I wanted to see where the printer would fail...but it didn t...not after an increase to 300 % of the speed....Yes the speed had its impact on the quality but it was amazing to see how fast this machine could go...if the extruder was also so fast...and the best was, that thet test finished with success.
Without any "big" calibration efforts...Here is a first shot of the first object, it is the torture test you can download from the internet....
The first print...not perfect...but nothing to compare with the printers I have build until now. Talking about vibration, I don t know from where one could get them, there is nothing in this machine that could produce vibrations....A video would be helpful to visualize the problem.
video of my 3DR
January 22, 2014 12:11AM
Hopefully someone can help me out. Not sure what I'm doing wrong.
I'm using Slic3r to complie G-Code and I've tried both Richard's and Andy's version of the firmware.
Using Prointerface I can move x,y and z in the correct directions using the arrow interface on the left. The problem comes when I try to print. See the following video
[www.youtube.com]
In this I am trying to print the RepRap coin linked in second 4 of the guide. As you can see it wants to move my x all the way down. I'm not sure why this is but I have to stop the machine.
In Slic3r I have tried configuring it as was done in section 4 as well as defaults all around.
Anyone have any suggestions?
January 22, 2014 12:26AM
We would but there is a problem with your video....it is private, so no one can see it, please check your publishing settings.
As you write, there is a firmware for Richard, for Andy, for me and for each one. There is no firmware for everyone. You have to tune your machine yourself.
Without looking to the video, this can t have something to do with the Slicer, no matters which slicer you are using.
Hope it helps.
video of my 3DR
January 22, 2014 12:43AM
Not to worry about the video. I grabbed HaDe's Slic3r config file and compiled using that. It works fine. Seems that I need to go over this and learn what I did wrong. Thanks for the quick reply though.
January 22, 2014 02:45AM
caffeinatedsoap
It happened something similar to me on my first prints, it's probably because you set the print center to the half of global printer XY area and in delta machines it should be set at 0 (X = 0, Y = 0). In your video X tower carriage tries to move the extruder outside the print area but, of course, it never reaches the point its wants because of "dimensional limits" of arms... I don't know if you understand me. Anyway, I see you have solved the problem =)
HaDe: thanks a lot, your config is quite different from RichRap one and from Marlin firmware defaults so I think it could work, I'll let you know. Thanks a lot!
January 22, 2014 02:52AM
Ah ok, you are welcome too.
Edited 2 time(s). Last edit at 01/22/2014 03:11AM by zacbot.
video of my 3DR
January 22, 2014 07:12AM
Always nice to see progress with those interesting machines...
Pablo, I ran exactly into the same problem (incorrect settings for the printable area) when I struggled with my own 3DR buildup. In fact, like zacbot said, there's no real turnkey solution for delta printers yet which still require a great deal of experimenting, analyzing and learning. But I think that contributes to the fascination and the satisfaction when we finally get it working the way we want it to.
As for vibrations... I think that the discontinuous operation principle of stepper motors and also the firmware's delta segmenting seem to be the main sources, and I'm afraid we can't do much to eliminate those. Now what we *can* influence is how those sources will propagate & resonate in the mechanics of the printer: eliminating slop and play, increasing stiffness, reducing moving weight etc. - Pablo, here are a few points to look into:
- hot end cooling fan seems quite large and thus heavy, might go for a much smaller fan (like this one: [www.sepa-europe.com])
- guess this has been mentioned before, but the Spectra drive line should be tensioned to produce a high pitched sound when plucked
- an enlarged 3DR using only 3,5mm delta rods (my standard sized 3DR uses 5 mm thin wall carbon tubes)
- using the standard carriage which I feel is just ok for a standard sized 3DR at normal printing speeds, but too sloppy and soft for *precise* printing at higher speed (BTW this is the main thing I'd still like to improve on mine: probably longer bearings, or going up to 8mm guide rods)
January 22, 2014 03:14PM
Sure, all these experimentations increase your knowledge and makes you be prepared for potencial future events, hehehe.
As for vibrations... all are gone with your Slic3r settings!! thank you very much again, it has been a big help. I have tweaked a little bit them to meet my printer, hotend, etc and now I'm printing the first part that I can consider 99% perfect. So, finally I can assure the "3DR with extensions" works fine with no mechanical problems =)
Anyway, the points you have listed seems very interesting and I'll investigate them ir order to improve printing precision.
Other thing I have discovered while testing is that the printable area is squared, I mean, my theoretical printable area is a circle of 26cm of diameter but it takes the circumscribed square, that is a 18.38cm. I have no idea by now if it's a Slic3r limit or if it's "engraved" in the firmware. Trying a Slic3r setting with a printable area which contains a circumscribed square of 26cm goes to 36.77cm but it doesn't works so in my opinion is inside firmware... but, it's strange that Repetier Host lets me move in any position inside this 26cm circle. Any idea?
January 22, 2014 05:38PM
Had fun printing the T800 model in black ABS at 0.2mm, however the bowden tube lag is rearing its ugly head. I can't get the cables to print properly because the filament is not starting and stopping in sync with the hotend movements. It ends up being a partial cylinder for the first few layers and then eventually gets knocked off and becomes a blob. Anybody have experience dealing with this type of issue? Retraction settings don't seem to help much on this... shorten the tube perhaps?
January 26, 2014 09:03PM
If you are seeing the effects of something that looks like vibrations here are some tips I have found with my delta printer (It's a Rostock Max, I've got all the electronics for a 3DR I'm just saving up for the rest of the hardware) that haven't been mentioned.
My Rostock Max is fairly weighty with the melamine and all the electronics inside, I still improved my prints by clamping it down (there are some cork plates between it and the table) to the table it is on. VERY helpful at higher speeds.
Check the carriage arms. Rubber bands tensioning the arms can help remove some slop. Also consider looking into magnetic arms as have been done on some delta printers. They do a fantastic job at high print speeds. I don't know what material you have for the arms themselves, but there is flex the longer the arms are. I did a set of magnetic arms and instead of just using carbon rods I used arrow shafts while picking a set with the stiffest / lowest deflection the store had. I'd have preferred crossbow bolts, but they didn't carry those.
Hopefully those suggestions may still apply when refining your 3DR for high speeds. I hope to join you guys in the 3DR club soon!
January 26, 2014 11:05PM
Everything seems to be working as it should now. The only issues I'm having now are mechanical.
1. Having extruder slippage.
-I've ordered a few different hobbed bolts. I'll report back with what I find.
2. The smooth rods I ordered aren't exactly the same diameter the whole length. This is causing some slop when printing.
-Anyone know a good place to order 6mm rod? Or should I go with V-Slot and the sliders?
3. I am very unfamiliar with PLA.
-This one will take time I assume.
January 27, 2014 02:34AM
Hi masterbinky, thanks for your comments about vibration, I'll add them to HaDe's list and take care of paying attention to them. Anyway, the most notable vibration issue was the loud noise from the steppers and now they are gone when I changed print speed to a higher value (lower than 20mm/s it start vibrating) and acceleration that I had it all at 0.
caffeinatedsoap, I also bought "non calibrated" rods and got the same sloop when inserting the 6mm bearings. I took a time here in Spain to find a decent place to buy the rods, they are not difficult to find and provably you are able to find them at a local store but always ask for "calibrated 6mm stainless steel rods", from that they may ask you about mate or bright, alloys, etc but all of them will fit perfect.
February 19, 2014 06:52PM
A little update... I recently replaced the 6mm linear bearings with rail & carriage guides (similar to what Johann uses on his Mini Kossel):
[flic.kr]
[flic.kr]
[flic.kr]
[flic.kr]
February 20, 2014 01:05AM
Looks good Hade. I have this system on my old Uventorbot printer...It adds weight to the total machine weight...
But why did you use that in this setup? Just to test or is there other reasons ?
video of my 3DR
February 20, 2014 04:35AM
Hi... here are the weight figures:
Non-Moving, original: steel rods 6/420 mm (2 x 94 g) = 188 g
Non-Moving, modified: 300 mm rail (90 g), fasteners (36 g) = 126 g
Moving, original: printed carriage, 2 bushings and magnet = 19.5 g
Moving: modified: linear carriage, printed adapter plate and magnet = 21,5 g
So this nets a substantial decrease in non-moving and, luckily, only a slight increase in moving weight.
You may have noticed that I left the original steel rods in place for added rigidity (even glued them into the printed parts at the bottom) because rigidity of the tower assembly is not quite satisfactory anyway, at least with my 3DR. To check, position the nozzle somewhere close to the bed, grip the 3DR at the top, rock it in all directions and watch the nozzle move about quite a bit horizontally! This doesn't seem much of a problem with low to moderate printing speeds but WILL decrease print quality when trying to print faster (and with high acceleration, as required to mask the extrusion elasticity introduced by the bowden extruder).
>> But why did you use that in this setup? Just to test or is there other reasons ? <<
All things considered, I don't think this is a must-have modification, because I got only a slight improvement in print quality from it. But, as you said, it was for testing, to get rid of the remaining slack of the linear bushings, and to gain some experience with this type of linear guide (DIN standard 9 mm size MR 9NM by taiwanese manufacturer CPC, 60 Euros each here in Germany) for my next printer projects.
How's your 3DR doing? Have you found points and/or solutions for improvements? I still would like to increase frame stiffness, but have no idea how to get real improvements without a major redesign. The main flex appears to be in the top & bottom printed parts.
February 20, 2014 10:24PM
just a curious question..... wont the PLA in the motor base soften with the motor heat in a long duration print ?
February 21, 2014 07:27AM
>> wont the PLA in the motor base soften with the motor heat in a long duration print ? <<
If the motor current is adjusted properly (only little is required, about 1/3 of the maximum setting), the motors only get slightly warm at maximum... they're way overdimensioned for the low moving mass of the 3DR.
At first I was more concerned about softening the PLA base because of the heated bed, but my usual 50°C setting seems too low to cause any problems, and also there's a 6 mm cork insulation between the heater and the PLA base.
February 24, 2014 09:08PM
cant seem to find the source file of the xxl lcd cover in the github... can you guide me to it?
Edited 1 time(s). Last edit at 02/25/2014 01:00AM by ekaggrat.
February 25, 2014 02:41AM
Hi ekaggrat,
It's there but it has a different name so that it's not grouped with the other LCDXXL files. It's called "3DR_Top_Case_XXL_V2_001_RTP.stl".
February 25, 2014 04:34AM
thanks .. but i am looking for the sketchup file...so that i can modify it to fit my lcd buttons... cant source the one from the reprapdiscount store ..
February 25, 2014 04:43AM
Is not possible to import STL files into SketchUp?
February 25, 2014 04:52AM
u can import stl into any thing but thats just a messed up way of doing it.... anyways i will build it up from scratch....
February 25, 2014 07:51PM
I very often import .stl files into Sketchup. Initially they are a mass of lines and triangles but the Cleanup plugin that you can download from the Extension Warehouse fixes all that and they end up looking like any other Sketckup model and are much easier to work with. I would be lost without it!
February 27, 2014 08:29AM
starting to build a version too, i am using the bigger version from JEZZMUND by thingiverse.com.
I am really looking forward to it.
What boards are you using most ? I am still not sure what to use, i prefer the Ramps as i am still using them.
February 28, 2014 09:02AM
How do you print the string spool without getting the ridge line ??
