Rostock Troubleshooting
Posted by m.schmitt
August 11, 2013 07:51AM
Hey 3D friends,
unfortunately I need help ones again.
My Rostock is fully assembled
Extruder and Bed are heating up quickly
Temp sensors and endstops are running good
But Rostock makes bullshit... Sometimes he's/is's homing normal, sometimes not. Sometimes he's driving smooth, sometimes Up and Down or driving 1 Axis down under the extruder ... I tried it with pronterface and repetier and got the same problems.
[www.vidup.de]
[www.vidup.de]
Thanks
Here are some more informations about my system:
Printer Type: Rostock MAX
Arduino 2560 (software 1.0.5) - Ramps 1.3 with 6 endstops
If you need my firmware, I'll upload it for you
Edited 1 time(s). Last edit at 08/11/2013 12:25PM by m.schmitt.
Re: Rostock Troubleshooting
August 12, 2013 06:57AM
hi m,
i Think, that it can be only a bug in your Firmware (maybe Marlin) or the adjustment for your Stepperdrivers.
Better you call me (0049 (0) 1788886712) for Troubleshooting.
Your Informations are to small to analize the error/s...
Have Fun
Angelo
August 12, 2013 11:00AM
1.Check for loose pin connections or broken wires
2. Check the rodlength settings in the firmware(rodlength,delta offset,effector offset etc.)
3. you may be try-ing to print outside the printable area or build dimensions(settings in pronterface and repetier-host)
August 13, 2013 04:59PM
Thanks for your help!
I found a defect capacitor in my power supply. I'll replace it.
@angelo: Thanks, I would call you in a few days if I couldn't solve the problem smiling smiley
