i maked larger ROSTOSK but get problem.... pls help
Posted by thong175
August 24, 2013 09:30PM
this is my Delta bot
and parametters
my firmware used: Marlin
this is my config file: (attached)
i get problem:
when i send "G01 X100"
i just see tower_x and tower_y move, tower_z not work and it move not enought 100mm...
i send "G01 XZ100" i see all tower move. But i still not enought 100mm
Pls help me.....
open | download - Configuration.h (24.8 KB)
Re: i maked larger ROSTOSK but get problem.... pls help
August 24, 2013 09:51PM
How much does it actually move? If it moves 50 mm or 200 mm, when you tell it to move 100 mm, you may have the steppers configured for 1/8 or 1/32 stepping.
If it moves something that isn't clearly a multiple of 2, then you may be skipping steps due to reference voltages on your stepper drivers.
Fl0yd
August 24, 2013 10:27PM
it just move 20mm when i tell it move 100mm
i used Toshiba Driver 1/8 with microstep
...confused smiley
August 24, 2013 10:29PM
> stepping.
> Fl0yd
Can u tell me why just tower_x and tower_y when move when i send G01 X100...
August 25, 2013 09:06AM
Start with homing first. Does your printer home correctly when you send G29 command?
When you are moving only in X-axes direction (e.g. from position (0,0,10) to (100,0,10)) then all towers should move.
