Need advice on motors for Kossel build
September 01, 2013 04:51AM
Hello!
I'm about to buy motors. I have a RAMPS 1.4 with A4988. My research says:
Nema 17
1 amp-2 amps
60-80 oz hold torque.
Not sure about shaft length.
I'm on a budget and found these motors on ebay. My budget is about $10 a motor. Can anyone with experience let me know if these are powerful enough for my project?
I'm also concerned voltage and amps will be acceptable with my 12volt power supply and a4988s.
really appreciate it.
Here are the links:
5 X Nema 17 Sanyo Denki Stepper Motors
[www.ebay.com]
Stepper motors NEMA 17-DIY CNC ROUTER MILL ROBOT REPRAP
[www.ebay.com]
5 Nema 17 Japan Servo Stepper Motors 51.2oz/in
[www.ebay.com]
A bit more expensive (Is it worth it?)
5pcs NEMA17 BIPOLAR STEPPER MOTOR 76 oz-in
[www.ebay.com]
Re: Need advice on motors for Kossel build
September 01, 2013 08:11PM
Those motors all look a bit under-powered, but may work just fine for a Kossel. I would be a bit worried about using one for the extruder though. Generally you want motors that are less than 3Ohm and rated for 2+ amps. This usually means motors that are rated for 6V or less (our stepper motor drivers limit current, so we can safely run them off of 12V). Running a motor rated at 1 amp at full current will cause it to get quite hot (though still technically within normal operating temperature).
September 01, 2013 08:21PM
Thanks.
So I need to look at less than 3 Ohm and 2 amps and under 6Volts. Isn't the holding torque the important thing?
So many variables to take into account. What is an example of an affordable (cheap) motor with proper specs for a RAMPS 1.4 w a4988?
September 01, 2013 08:53PM
I've built two printers so far with the motors in the first link and they work fine even in an extruder. The only catch is that the shafts are 4mm, so you'll need to make sure your pulleys and extruder gears take that into account.
September 02, 2013 04:29AM
I'm looking at these motors now. Tell me wht you think:
Remember I will be using RAMPS 1.4 and A4988, with heat sink, and I will add a fan.
42BYGHW811
Holding Torque:4800g-cm(70 oz-in) Type:Hybrid Brand Name:Wantai Motor Phase:2 Current / Phase:2.5A Certification:CE,ISO,ROHS Step Angle(degrees):1.8degree
1, Technical Specifications
Part No.: 42BYGHW811
Frame Size: NEMA17
Step Angle: 1.8 degree
Voltage: 3.1V
Current: 2.5 A/phase
Resistance: 1.25 Ohm/phase
Inductance: 1.8 mH/phase
Holding torque: 4800g-cm 70OZ-IN
Rotor inertia: 68 g-cm2
Detent torque: 0.28 kg-cm
Number of wire leads: 4
Weight: 0.34 kg
Length: 48mm
September 02, 2013 06:40PM
Those look perfect.
September 02, 2013 07:51PM
Thanks for your help. I'll order them. :-)
