Re: 3DR "Simple" Delta Printer March 16, 2014 02:09PM |
Re: 3DR "Simple" Delta Printer March 16, 2014 05:03PM |
Re: 3DR "Simple" Delta Printer March 16, 2014 08:43PM |
Re: 3DR "Simple" Delta Printer March 17, 2014 08:34PM |
Re: 3DR "Simple" Delta Printer March 17, 2014 10:58PM |
umdpru
Can someone who has theirs running please attach your Marlin directory and possibly attach their slic3r profile?
Re: 3DR "Simple" Delta Printer March 21, 2014 12:08AM |
The pattern is due to positional accuracy limits, bound by your stepper motors' degrees per step.
Re: 3DR "Simple" Delta Printer March 21, 2014 08:35AM |
Re: 3DR "Simple" Delta Printer March 21, 2014 10:07AM |
Re: 3DR "Simple" Delta Printer March 21, 2014 06:14PM |
Re: 3DR "Simple" Delta Printer March 23, 2014 01:11AM |
Re: 3DR "Simple" Delta Printer March 24, 2014 10:55PM |
Re: 3DR "Simple" Delta Printer March 28, 2014 12:32PM |
Re: 3DR "Simple" Delta Printer March 29, 2014 09:01AM |
PierreB
[*] I seem to be having an intermittent problem with the motor/spool at the rear of the printer. I think it might be that the set screw in the spool keeps working itself loose so the motor shaft is spinning freely inside even though I tightened the setscrew a decent amount. I tried running a 7 hour print two nights ago and happened to have a time lapse video of the failure: [vimeo.com] Maybe it's time for some Loctite?
[/list]
Re: 3DR "Simple" Delta Printer March 29, 2014 09:17AM |
zacbot
PierreB
[/list]
You could use an Aluminum Filament Drive Spool
Re: 3DR "Simple" Delta Printer March 29, 2014 11:59AM |
Re: 3DR "Simple" Delta Printer March 30, 2014 09:25PM |
zacbot
Oh!....then I can t imagine the spool getting loose...
There are still three players in the mechanism.
- The fishing line could be too thight.
- The bearing on the top is sometimes blocking.
- The smooth rods are not perfectly parallel. This will stop or make it hard for the carriage to move to the top causing the motor to skip and loose steps. This will also explain why the problem happens as it moves higher during the print.
- The smooth rod or the bearing could be dammaged
What ever it is, it needs to happen only one time during the print...even for a fraction of seconds...the print is lost.
PS: your smooth rods looks like they have deep-seated rust or is it something else ?
Hope this helps.
Re: 3DR "Simple" Delta Printer March 31, 2014 06:10PM |
Re: 3DR "Simple" Delta Printer March 31, 2014 09:25PM |
Re: 3DR "Simple" Delta Printer April 02, 2014 05:47PM |
Re: 3DR "Simple" Delta Printer April 05, 2014 04:22PM |
PierreB
A few thoughts after having printed a handful of things on the Simple Delta:
- It makes a fair amount of noise when moving the print head around, much noisier than my RRP Mendel or Printrbot Simple was. I think the noise is coming from the LM8UU linear bearings, but I'm not entirely sure. Anyone else experiencing this?
Re: 3DR "Simple" Delta Printer April 09, 2014 02:23PM |
Re: 3DR "Simple" Delta Printer April 09, 2014 02:38PM |
psykhon
Hi everybody!
I started building a 3dr simple some time ago and yesterday it made its firsts couple of prints, post:3DR Simple (warning: its in spanish)
just like to thank a lot to Richard and John for the awesome work they made on the 3DR
Re: 3DR "Simple" Delta Printer April 09, 2014 02:54PM |
Re: 3DR "Simple" Delta Printer April 09, 2014 10:34PM |
RTurnock
Only problem is that I do not have 12volts at the fan pins so I may need alternatives, like direct wiring or desktop fan.
Re: 3DR "Simple" Delta Printer April 11, 2014 11:02AM |
Re: 3DR "Simple" Delta Printer April 11, 2014 10:22PM |
Re: 3DR "Simple" Delta Printer April 12, 2014 10:26PM |
Re: 3DR "Simple" Delta Printer May 03, 2014 06:16PM |
Re: 3DR "Simple" Delta Printer May 03, 2014 09:48PM |
Re: 3DR "Simple" Delta Printer May 05, 2014 06:34PM |
