Re: 3DR "Simple" Delta Printer June 09, 2014 07:53AM |
Re: 3DR "Simple" Delta Printer June 09, 2014 03:46PM |
Interesting.Quote
umdpru
My bottom frame took a total of 34 hours of print time for all 9 pieces.
These times are for my machine running at 80mm/s and 500mm/s^2 acceleration settings.
Re: 3DR "Simple" Delta Printer June 13, 2014 12:58PM |
Re: 3DR "Simple" Delta Printer June 13, 2014 02:12PM |
Re: 3DR "Simple" Delta Printer June 18, 2014 01:27PM |
Re: 3DR "Simple" Delta Printer June 18, 2014 09:33PM |
Re: 3DR "Simple" Delta Printer June 18, 2014 10:18PM |
Re: 3DR "Simple" Delta Printer June 19, 2014 02:26AM |
Re: 3DR "Simple" Delta Printer June 26, 2014 03:59PM |
Re: 3DR "Simple" Delta Printer June 26, 2014 06:38PM |
Re: 3DR "Simple" Delta Printer June 26, 2014 08:11PM |
Went so well I've already been asked to give the same presentation at a different library branch!|
Re: 3DR "Simple" Delta Printer June 26, 2014 11:55PM |
RTurnock
@disneytoy
Yes,the motors stop and thehot end drops, all the time, every time, yet this is not important to the results.
when printing the motors are always "on"
when you are leveling the print plane with the nozzle the motors should always be "on" and the nozzle "HOT" because it gets longer/closer to the print bed when hot.
look on Youtube for Jay Couture videos about calibratin and leveling the print bed by printing part of one layer of a square.
This way you can get it down to 0.02mm but only after you have done the paper test with a hot nozzle and the motors on.
Re: 3DR "Simple" Delta Printer June 27, 2014 11:55PM |
disneytoy
RTurnock
@disneytoy
Thank you. A fellow Delta guy was helping a newbe (me) to calibrate my 3DR. The he set it to go to 3mm off the bed. But after a bit of a chat it had dropped. He suggested the problem was my spindles slipping, even though they are amazingly tight, and there was vurtually no forces on the motor. We did change that motor timeout in configuration.adv.h from 60 to 400.
I was concerned that maybe my Spectra needs to be tighter? But if you say that the motor will shift a few degrees upon losing its power, I won't worry about that.
I was told that because it was doing that, he could not calibrate it for me.
So close. I've been working on this thing for 8 months. I figure I'm at 98%. I have a J-head issue to resolve, This calibration and I should be printing soon.
Thanks!
Re: 3DR "Simple" Delta Printer July 01, 2014 03:26PM |
Re: 3DR "Simple" Delta Printer July 01, 2014 07:27PM |
umdpru
Richard,
I found the issue with my 3DR simple, I believe. I gave up on it for a while and built a MK from ultibots that prints fantastically. During that build, I decided to print a "torture test" model on the Cupcake CNC that I had used to print both of the frames on the 3DR simple. Well, after the torture test model was complete, I examined it and found that the square box was out of square. My X and Y axes aren't square to each other. It's a real punch in the gut to know that this has existed. I think I will build a Z-probe for it and attempt to use Rich Cattel's auto calibration firmware. If that doesn't work then I'll print a new frame on the MK and try one last time! IF that doesn't work then the parts are going into a Tantillus!
for what it's worth, I was able to calibrate the MK in about an hour manually. I haven't fine tuned it like you have yours. I just don't see that I have a need to get that good with it.
Re: 3DR "Simple" Delta Printer July 03, 2014 06:22PM |
RTurnock
@disneytoy
Re: 3DR "Simple" Delta Printer July 07, 2014 03:50PM |
Re: 3DR "Simple" Delta Printer July 08, 2014 01:33PM |
RTurnock
umdpru
Richard,
Great! Good to hear your insightful problem solving skills are working for you.
Unfortunately, I don't believe the Auto Calibration will help you with the XY axes being out of square. But I've been known to be wrong. The auto calibration is to make sure you have a level/flat printing plane across the whole surface.
Not being square could be a structural issue, or a steps/unit calibration setting in firmware.
not sure whether to upgrade my Printrbot Simple to XL or to build a new Delta/Kossel with parts from 3DR Simple and new parts, like Azteeg X5, 2020 to go bigger and stronger, sliders by Jay Couture.......
Take Care
Re: 3DR "Simple" Delta Printer July 08, 2014 07:06PM |
Re: 3DR "Simple" Delta Printer July 10, 2014 03:28PM |
Re: 3DR "Simple" Delta Printer August 29, 2014 04:41PM |
Re: 3DR "Simple" Delta Printer September 01, 2014 08:12PM |
Re: 3DR "Simple" Delta Printer September 01, 2014 10:12PM |
Trung
Hi John. Excellent work. Thank you. I may take the plunge soon.
For John or anyone,
I understand the intent to keep things small and "simple", but could this design be adapted to use extrusions to connect the corner pieces instead of the printed mid sections? I am thinking this would allow one to scale the print diameter.
Re: 3DR "Simple" Delta Printer January 22, 2016 11:57PM |
Re: 3DR "Simple" Delta Printer March 03, 2016 12:18AM |
Re: 3DR "Simple" Delta Printer March 29, 2016 10:12AM |
Re: 3DR "Simple" Delta Printer April 02, 2016 01:20AM |
Re: 3DR "Simple" Delta Printer April 02, 2016 01:24AM |
I'm not quite sure what you mean by omitting the smooth rod? I already have the bottom pieces for the 3DR simple printed (9 pieces, I'm not sure where you got 12 from).Quote
ProfessorBean
So some design implements on the Simple Delta, First after printing either set of stl files (6 piece / 12 piece), which are still on John_sl 's github, for the top and bottom, omit the smooth rod, just use the 2020 aluminum extrusion then second, print a set of carriages and effector head for the kossel those have everything needed for the GT2 belts and the rollers ride nice in the 2020 t slots, you can just increase/decrease your arm length accordingly.
