Firmware and acceleration October 30, 2013 02:25PM |
Re: Firmware and acceleration October 30, 2013 03:05PM |
Re: Firmware and acceleration October 30, 2013 04:52PM |
Re: Firmware and acceleration October 30, 2013 08:09PM |
). So smooth movement on towers will lead to smooth movement on the effector. Well, except that pesky locations where the speed limiting tower is switched. Speed transformation will not be smooth there, but at least it will be continuous. And this switching has a nice conseqence of avoiding those parts of the cartesian<->delta transformation which would lead to too high speed effector movements.
Re: Firmware and acceleration October 31, 2013 01:42AM |
Re: Firmware and acceleration October 31, 2013 05:46AM |
Re: Firmware and acceleration October 31, 2013 10:35AM |
Re: Firmware and acceleration October 31, 2013 02:27PM |
Re: Firmware and acceleration October 31, 2013 04:00PM |
Re: Firmware and acceleration October 31, 2013 04:17PM |
Re: Firmware and acceleration November 01, 2013 05:11AM |
Re: Firmware and acceleration November 01, 2013 09:05AM |
nicholas.seward
it bugs me that jerk has units of mm/s here.
I am personally investing time into NURBS modeling and slicing with NURBS input.
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Firmware and acceleration November 08, 2013 11:01AM |
Re: Firmware and acceleration November 11, 2013 02:54PM |
Re: Firmware and acceleration November 11, 2013 03:18PM |
DaveGadgeteer
But in physics, Jerk is the rate of change of Acceleration, like Acceleration is the rate of change of Velocity and Velocity is the rate of change of Position.
For example, if you're standing in a street car and there's constant acceleration, you can lean into it and feel comfortable. But if the acceleration changes, you have to lean differently. That's a jerk.
So I would expect jerk to have units of mm/s /s /s, or mm/s^3, not mm/s (a velocity). Something seems confused.
Re: Firmware and acceleration November 11, 2013 04:24PM |
Admin Registered: 16 years ago Posts: 730 |
nophead
I think jerk is the speed below which it doesn't use any acceleration.
Quentin T.
I've heard of the jerk in calculus, which is the derivative of the acceleration. If thats what it is then the jerk would be the rate that the acceleration increases, but that just didnt make any sense to me, and I also didnt know a reasonable value for it. Is 20 a good value?
nophead
That is what jerk should be mathematically but I think Reprap firmware uses the name inappropriately. If your machine can move at 20mm/s with no acceleration without losing steps then 20 would be a good value.
Re: Firmware and acceleration December 16, 2013 12:02AM |
nicholas.seward
Also noteworthy, I am unaware of any firmware that tries to keep discontinuities out of the acceleration graph. In fact, the graph would usually be a bunch of discontinuous horizontal lines. I wonder how useful it would be to smooth this out. It is worth an experiment.
