Re: Delta robots
January 21, 2010 12:22AM
im excited, delta robots gonna make everything eles old news.
Re: Delta robots
January 21, 2010 10:16AM
Hey Reinoud,
you sound like an embbeded pro, so please go ahaead.
Could you detail the concept a bit more? Do the values in abc column represent Axis positions in steps? Or does it represent pwm values ( positions ) for servos ?
Cheers,
Torsten
Edited 1 time(s). Last edit at 01/21/2010 02:24PM by energetic.
Re: Delta robots
January 21, 2010 04:50PM
Hi Torsten,
well hardware/software co-design and thus also embedded stuff is my field of expertise yeah. I `normally' also do kernel work for NetBSD smiling smiley So i'm quite used to programming 'C' and producing fast algorithms. Challenging for embedded stuff since memory is tight normally ...
The values are Axis positions in steps yes; the value 0 means parallel to the plane the machine is set on. If you could just feed the values to a loose stepper motor to see if it runs smooth or relatively smooth i'd be most grateful! I'm thinking of creating a interrupt routine that tries to set the pwm's correctly, but i'll have to dig into the internals of the Arduino/Sanguino a bit more...
I'm planning on working on the code this weekend in Meka2010 in Karlsruhe; so i packed my Arduino with me! smiling smiley Hope to have something more working on tuesday!
P.S. do i need an google account to be able to upload svn versions?
With regards,
Reinoud
Re: Delta robots
January 22, 2010 05:22AM
Hi Reinoud,
i don't think you need an google account, but i'm not 100% sure. It should work with just your username and the password.
As far as runing a stepper with the profile is concerned, i think this will not work, it will work with a servo, as absolut position is related to a fixed timeslice, but for steppers i think i need something like delta steps per timeslice ( which should not be a problem to get from a series of absolut position, of course). Correct me if im wrong here.
Cheers,
Torsten
Re: Delta robots
January 24, 2010 03:52PM
Hi there.( This is my first post here)
My name is John i have been in engineering for 15 years, i have a degree in aircraft engineering and i am currently working on my next degree in electronic engineering.
I have been looking into building a 3d printer for some time now that that could be built by the layman, and tried a couple of ideas out. But to be honest i have not been happy with any of them. From trying to source stepper motors to coming up with a very easy mechanical system.
I have how ever read your post here and i like what i am seeing.
I believe this thing has legs a mechanically simple robot that can be made with parts from your local model shop, that can use normal hobby servos, to position the heater element while the extruder driving gear can be positioned stationary above the servos, allowing the bot to be low powered and easily controlled using pwm signals. And best of all i can easily built in a couple of evenings.
Would be even better if it could be fitted with a granule extruder. But any way i go on with my self lol.
I am going to build my self on of these using some hobby servos to try out accurate and methods of control..
Re: Delta robots
January 24, 2010 07:04PM
One of the devs proposed a move to git. Dunno the details.
-Sebastien, RepRap.org library gnome.
Remember, you're all RepRap developers (once you've joined the super-secret developer mailing list), and the wiki, RepRap.org, [reprap.org] is for everyone and everything! grinning smiley
Re: Delta robots
January 24, 2010 09:27PM
so, when the software for this is done, will we all have a basic tutorial to follow for assembaling the delta robot that will fit it? Could we get a how to with a list of parts? or will the software be flexable and be able to change with various designs if you input the diferent dimensions?
Re: Delta robots
January 24, 2010 10:14PM
[www.delta-robotics.com]
check out this delta robot printer! im thinking that increasing weight (while printing) might form problems if the delta robot is wimpy. look at those beefy parts! and check out the extruder lazy suzan
Re: Delta robots
January 25, 2010 04:27PM
Hi there i found this video and thought i should post it. This robot seems very smooth and accurate what do you think??
Video here Delta robot video
Re: Delta robots
January 26, 2010 08:08AM
Hi jhdgkss,
sorry to disappoint you, but unless you know of a way to disable the PID control in the servo's or try out digital servo's, i fear that that road is blocked for now sad smiley The problem is that the PID control works fine with a counter force, but when it has a force in the direction of the movement, it starts to overshoot which results in a very resolution shattering motion.
As for the cardboard one; it moves quite fast, but how accurate is it? Won't the PID control wreak havoc there to?
With regards,
Reinoud
Re: Delta robots
January 26, 2010 08:13AM
As for that delta-robotics url ... yeah, thats groovy, but at micrometer resolution with piezo elements. *glup* thats not going to be easy.... Isn't that for very small, say upto 1 cm stuff?
Re: Delta robots
January 26, 2010 09:56PM
Torsten, what parts are you using for your magnetic joints, and where did you order them from?
I've become disillusioned with trying to model plastic joints with metal rod hinges, and want to see what it would take to use magnetic joints instead. The cost per joint is surprisingly good and I've been wanting to play with designing a halbach magnet array anyways.
Thanks,
Lawrence
VDX
Re: Delta robots
January 27, 2010 03:09AM
Hi Lawrence,
i've ordered magnetic spheres, rings and cubes in different sizes here ...
My magnetic joints were built with two ball magnets, so are a bit more tricky to calculate forward- and reverse-IK than with two cylinders and a simple steel-sphere as rotation center ... but have some nice stability issues grinning smiley
Viktor
Re: Delta robots
January 27, 2010 04:44AM
Hi Lawrence,
i used this part balljoint magnet
Cheers,
Torsten
VDX
Re: Delta robots
January 27, 2010 05:20AM
Hi Torsten,
... have you noticed reduced attracting forces if the angles goes bigger 50°?
I think what could be better for this is using two cylindrical magnets and a steel-sphere between them as joint - so you can bend over the complete angular freerun.
Maybe a PTFE-collar around the cylinders could help adjusting the orientation ...
Viktor
Re: Delta robots
January 27, 2010 11:10AM
Greetings all,
I have a question about sensing and resolution for Delta robots:
What angular sensors are folks considering, and what spatial resolution do those give in/near the "sweet spot" of the mechanism (area where the kinematics are reasonably well behaved?) -- Or are folks considering some other sensing approaches?
The reason I ask is that it looks to me that one needs considerable angular resolution (milliradian or sub-milliradian), to get acceptable spatial rez for a use-ably big sweet spot -- and even more outside the sweet spot, to compensate for an ill-conditioned Jacobian (mapping from incremental angular changes to incremental cartesian changes.) Encoders with (greater than) milliradian resolution get increasingly expensive. An alternative is to gear the encoders (so the encoder moves many revs per one input-axis revolution, but that leads to other problems, like backlash and gear eccentricities. Gearing is not insurmountable, I know of a commercial robot that used geared encoders, but it sure does add to complexity and cost.
What sort of link lengths (and distances between bearing on the moving platform) are people considering for delta repraps?
Larry Pfeffer,
My blog about building repstrap Cerberus:
[repstrap-cerberus.blogspot.com]
Re: Delta robots
January 27, 2010 11:22AM
Hi Viktor,
yes, exactly, i made a workaround, but this works just for having the Delta move the extruder, and if the gravity is not inversed.
Cheers,
Torsten
Re: Delta robots
January 27, 2010 12:30PM
I think the best arrangment is to have the extruder fixed and use the robot as the table. Also increase the base of the bot this should help with resolution.
VDX
Re: Delta robots
January 27, 2010 02:49PM
... i have some high resolution steppers with 50000 steps per rev. or 0.0072° resolution, so i can use them without encoders or other angular sensors with high accuracy.
They have 8.5Nm torque and max. 200kHz stepping rate, so they are strong and fast enough for a basic delta.
... on the other side i want to build a high accuracy CNC-mill and -Laser, so i'll use them better here confused smiley
But then i have some 1/256-microstepping drivers with 10kHz stepping rate too, which runs a 1.8°-stepper with 51200 steps. Some Nema-34-steppers with 4Nm@3Amps should arrive soon, so this is another possible way ...
Viktor
Re: Delta robots
January 27, 2010 03:38PM
Dear folks,
as I have been doing some math and analysis around the necessary transformation and Torstens setup, I'll try to answer the questions.
As for the precision: Torstens designs worst case error rate on position will be around 0.19 mm for the combined error vector length of x+y+z and 0.032 for the `sweet spot'. This error rate is for the combined step angle of 0.1125 degrees; the error is thus approx 1.7 times the minimum combined step angle but in millimeter.
As for the positioning: its never a good idea to integrate the jacobian other than localized; its NOT a linear transformation; at best polynomial.
When the device is calibrated, either automatic by hitting switches or semi-manually by positioning the arms parallel using a jig, the stepper motor counts can be used to move from one position to another if and only if the positioning stepper motors are not skipping steps during the move.
Increasing the base of the bot won't necessarily increase the resolution; it will only create a bigger workspace since the other parameters are scaled too. If not scaled, the build area might actually decrease (its not cubical).
With regards,
Reinoud
Edited 1 time(s). Last edit at 01/27/2010 03:41PM by reinoud.
Re: Delta robots
January 28, 2010 03:53AM
Hi Viktor,
those stepper motors are awesome; but are they (and the micro-stepper controllers) affordable? It would remove the need for Torsten's pulleys, but lets first get Torsten's machine up and running smiling smiley
With regards,
Reinoud
VDX
Re: Delta robots
January 28, 2010 04:07AM
Hi Reinoud,
... i've got 4 of the 8.5Nm-motors+drivers in exchange for some of my spare parts, 3 of the 1/256-microstepping/3A/10kHz-drivers from IMS for 30 Euros each, and awaits 3 highpower-nema-34 1.8°-steppers for 25 Euros each.
This aren't parts from the shelf, but dealing and exchanging in our german CNC-forum.
I've read recently that another guys sells a bunch of motors and drivers from Berger-Lahr and Vexta for around 10 to 20 Euros each ...
Viktor
Re: Delta robots
January 28, 2010 10:26PM
Ok, before I get inundated with more stuff. I need to lay out the entraped magnet arrangment I'm kicking around.
The idea is to use a metal bearing with a low coercivity and to use a strong magnet to attach with, such as soft iron or ideally an iron nickel alloy.
Ball joint using a steel ball to entrap a strong magnet between a lubercating cup
The second idea is to encapsulate a strong magnet in the lower parallel legs and encapsulate a spherical ferromagnetic material with a low coercivity, like iron, in the upper leg. This would allow the minimum amount of motion reluctance while producing an extremely simple joint. The interfacing plastics should be low friction, so the encapsulated sphere and the encapsulated cylendrical magnet should be encapsulated with nylon, teflon, or uhmwpe. Thic can be accomplished by making a plastic cup that is attached to the cylendrical magnet and rests between the iron sphere and the magnet.
Third idea is to use a Dual Axis Magnetic Sensor Breakout - Honeywell HMC1052L, such as the one from sparkfun, such that it rests behind the sphere and records the change in the magnetic field as the magent changes the angle. This would provide angle positioning, acceleration, and general coolness. Only issue is cost.
Fourth idea, is to use a halbach array to maximize magnetic confinment, as having strong magnets on a robot make me nervous. This can be achieved by putting the magnets in a matrix grid, with the non-aligning hole filled with a diamagnetic substance like bismuth. This would provide support as well as better field alignment, I believe.
fifth idea, unrelated to magnatism is to use a optical mouse optical sensor and integrated dsp processor to do acceleration, relative positioning and absolute positioning. A optical mouse chip such as Avago ADNS-2620 is able to export x/y coordinate changes by observing the relative change in position in image features taken by the low resolution, high speed integrated camera. The device can also export the image. Using a circular printed encoder, you could encode a black and white block pattern that is both optically unique and easy to pick up. This would give an extremely cheap high quality sensor option that could cost less than $10 per encoder. The challenges would be to get it integrated into the current software and to make an appropriate circular encoding that is optimized vs. the resolution of the camera.
Once I get some time I'll order some magnets and redesign my joints according to the above. I also apologize for the ms paint diagrams.
Re: Delta robots
January 31, 2010 10:15PM
Ok, so I did some some testing and realized that the parts I wanted don't exist in a cheap commodity form or wouldn't work exactly how I thought they would. What I came up with is this demo setup. The neat thing about the setup is that the plastic cup makes motion very smooth while keeping the ball centered in the magnetic field of the magnet. Without the cup, the ball skips while overcoming static friction. Here is a picture with the separated ball joint and plastic cup.
The problem I was having was how to fix the magnet to the socket and the metal ball to the arm without separating them such that the majority of the holding power of the magnetic field was lost. I couldn't just cover both of them in plastic and assume that they would hold, because the aggregated distance and the exponential magnetic force decay would make it difficult to support a substantial end effector package. So, what i came up with is welding a stub to a ball bearing and covering the magnet with plastic which the plastic cup is a part of. I get greater than 180 degrees of rotation on the joint, as long as the ball is larger than the socket, and I can attach both metal balls together so the forces pulling on them counteract each other.
Also, by using a non magnetic steel/iron/ideally nickel/iron ball I don't have the same magnetic reluctance issues described above. Best of all, the total cost of the joint is under two dollars, and can be integrated with the plastic mechanical arm structure.
VDX
Re: Delta robots
February 01, 2010 03:30AM
Hi Lawrence,
... you can try with the setup i sketched in the added immage - the red-blue should be a disk magnet and the green either a fabbed plastic-part, or a lathed plastic-tube and a cap wit a cavity for the ball ... the cavity preferrable coated or made from something with low friction ...
Viktor
open | download - Ball-Joint1.jpg (36.9 KB)
Re: Delta robots
February 01, 2010 11:35PM
Viktor,
Thanks for the clarifying picture. I had hoped that I was communicating effectively but I'm afraid I came off as rambling.
What you have pictured is what I had hoped to describe above, but I would like to add a few points.
1. By increasing the diameter of the ball sphere, to approximately 1.75 of the diameter of the magnet+housing, you can get a greater range of motion. The trade-off is that the larger the metal sphere the more unstable the joint is. I don't know what the optimal magnet size/strength/shape to metal sphere is.
2. In the test I performed, I used a piece of ABS plastic which I then friction/spin welded supporting plastic around to form the cup. I wish I had a force spring so i could determine the coefficient of static friction, but it appears good. I would much rather use ultra high molecular weight polyethylene, because of its compatibility with HDPE which is cheap, available and its good impact resistance coupled with low friction.
3. My only concern is having strong magnets around the joints of a robot in a work environment. The two fixes for magnetic field confinement is the halbach array magnetic arrangement, or a nickel-iron alloy field routing shield. The same technique is used to isolate the strong magnets in hard drives from the rest of the system by backing the magnets with a nickel-iron alloy.
Also, does anyone know what a magnetic hinge is called in industry or the scientific literature, as I can't believe we are the first to think of using magnets as hinges.
Lawrence
VDX
Re: Delta robots
February 02, 2010 06:55AM
Hi Lawrence,
... look at the image and the posts here - i minimized the outer magnetic field with two spehric magnets as oriented joint and two cylindric magnets in the rods as fixators (the cylinders could have an iron-cup as field-loopback too).
It's working really good with high possible angles, but the PK- and IK-calculations are a bit more complex as the joint-centre is not a point but the connecting line of the two spherical magnets, what's moving with the angle.
And i call them 'spheric-' or 'magnetic joints' winking smiley
Viktor
Re: Delta robots
February 02, 2010 10:58AM
if you used this on a delta bot that is working as the base (opposed to working the extruder), wouldnt weight be a problem with future applications like sintering, or (for me) biological printing? I cant imagine TOO much weight on there, but with the acceleration and such added the idea seems a little sketchy compared to good ol hinges and such.
VDX
Re: Delta robots
February 02, 2010 11:06AM
... it's depending on the size of the magnets - the biggest magnetic spheres i can buy are 19mm in diameter and really dangerous in handling eye popping smiley
But you're right - this magnetic ball-joints can't handle so much load as conventional hinges.
For higher loads and accelerations i'll prefer a crossed bearings setup or a cardanic hinge with ball-bearings, not the common ball-joints ...
Viktor
VDX
Re: Delta robots
February 02, 2010 02:50PM
... here an interesting sample what's possible with servos: - hexapod car-simulator ...
Viktor
