[SOLVED] RichRap's 3DR-Delta: what size/torque motors to use?
Posted by TheTechnicalNoob
November 07, 2013 06:30PM
Hi guys! I'm building a 3DR-delta printer, this is my first printer so wish me luck!
So far I've made a nice list of things I'm going to need and am slowly getting it all together.
One thing I'm stuck on is that I don't know what size motors to buy.
How much power will the I need?
I think G3D A4988 drivers on a RAMPS1.4 board are a good choice (already got the ramps board still need to buy drivers).
Advice is much appreciated smiling smiley smiling smiley
Edited 2 time(s). Last edit at 11/08/2013 02:10AM by TheTechnicalNoob.
Re: RichRap's 3DR-Delta: what size/torque motors to use?
November 08, 2013 02:09AM
Ok I've answered my own question.
It says to use:
4 x NEMA17 Stepper Motor's - ideally over 1.2M versions (look for 1.7A or 2.5A) max 50mm Long body.
November 08, 2013 11:10AM
I'm using 0.9A motors with 0.149Nm holding torque for motion and the extruder and haven't had any problems with skipped steps. The towers don't require much torque, and with 1.75mm filament and reduction gearing the extruder doesn't either.
Re: [SOLVED] RichRap's 3DR-Delta: what size/torque motors to use?
November 08, 2013 12:46PM
Thats good to hear.
I think I'll go order some motors! Seeing torque shouldn't be an issue I'll go ahead and get some with 0.9 degree stepping. EDIT: No, on second thoughts I'll opt for some 1.8degree steppers.
Edited 1 time(s). Last edit at 11/08/2013 01:56PM by TheTechnicalNoob.
