Re: Worm Drive Grounded Delta Printer February 04, 2014 10:03AM |
A2
@Solidus Labs:
It looks fantastic, I'm impressed, and it appears to be round, good job!
It looks like a joint shifted to create the step in the worm wheel tooth profile.
Will the cast resin parts include the extruder?
The standard appears to be RAMPS 1.4, + Arduino Mega2560 R3.
The ramps-fd looks great, but I don't have experience with any of them.
Re: Worm Drive Grounded Delta Printer February 04, 2014 05:20PM |
Re: Worm Drive Grounded Delta Printer February 04, 2014 10:40PM |
A2
@Solidus Labs:
FYI: Black plastic can have recycled plastic in it, never use black plastic for parts of value.
Natural, and white are your safest choices for filament.
A few examples of extruders that I think can be modified for cast resin extruders:
I like this one by the_digital_dentist, it might be the easiest to resin cast:
[forums.reprap.org]
Re: Worm Drive Grounded Delta Printer February 05, 2014 03:49AM |
Re: Worm Drive Grounded Delta Printer February 06, 2014 04:42PM |
Solidus Labs
I have ordered SLA prints of all the parts which I plan on using for master to make casting molds for short run production.
How does everyone feel about crowd funding the production?
Jon – Solidus Labs
Re: Worm Drive Grounded Delta Printer February 06, 2014 09:37PM |
James,Quote
JamesNewton
Solidus Labs
Jon – Solidus Labs
So... this is to be a commercial machine? You are not releasing the files? Or do you plan to do both?
Honestly, the best part of this machine is that you can print so much of it. The original repraps were mostly just hardware store metal held together with a few small 3D printed parts. So this concept of "repraping" really wasn't... real. for the most part. This machine is as close to something you can actually print yourself as I have ever seen. Only the electronics, motor, drive screw and some nuts and bolts required.
The traditional rep raps are "print little, hardware store much" where as this design is "print much, hardware store a little".
casting it seems... well, mabey it will just be "buy a little, hardware store a little" but then I don't really see an advantage to it over e.g. a Printrbot Jr.
Am I missing something?
Re: Worm Drive Grounded Delta Printer February 07, 2014 01:50PM |
Solidus Labs
It is going to be open source. I will release the files when I am confident that the design is solid. Being able to print the printer is great if you have access to a printer. But since not everyone has access to a printer I wanted to use crowd funding to give some economies of scale benefit. Since the majority of the parts are printed, scaling with printing is not easily feasible and would require a fleet of printers. Casting the parts is kind of the middle ground where printing is prototyping and injection molding is long run manufacturing. Sure there are pro's and con's over Pb Jr. and the long list of cartesian bots and delta bots but my goal was to build a printer that was reasonably affordable, easy to produce, and easy to assemble. The assembly time should be somewhere from 1-2 hours. I think a great ancillary benefit is the printer is it is a real life application of trigonometry which fits in with the typical consumers of 3d printers, educators and inventors.
Jon - Solidus Labs
Re: Worm Drive Grounded Delta Printer February 07, 2014 06:27PM |
Re: Worm Drive Grounded Delta Printer February 10, 2014 03:15PM |
I spent the weekend testing, calibrating, and experimenting. I was trying to calibrate my router to no avail. I discovered a major backlash on my y axis so I am unable to cut any baseplates or print surfaces until I get it a new linear movement system.Quote
A2
Springless, drop In ToM MK6+ replacement
[www.thingiverse.com]
This one looks easy to cast.
Split it down the center of the filament guide, if you don't want to deal with an insert, or drilling the filament guide.
I would consider using a rubber tube around the shaft of the idler bearing to give it a spring effect.
I wouldn't print/cast the pivot for the idler, use a bolt.
Re: Worm Drive Grounded Delta Printer February 10, 2014 10:49PM |
Re: Worm Drive Grounded Delta Printer February 10, 2014 11:52PM |
Loctite® Threadlocker Red 271™ is designed for the permanent locking and sealing of threaded fasteners. The product cures when confined in the absence of air between close fitting metal surfaces. It protects threads from rust and corrosion and prevents loosening from shock and vibration. It is only removable once cured by heating up parts to 500°F (260°C). [www.loctiteproducts.com]
Re: Worm Drive Grounded Delta Printer February 12, 2014 09:51PM |
Re: Worm Drive Grounded Delta Printer February 13, 2014 01:47PM |
Solidus Labs
...in scad with nema 17 and machine mounts.
Re: Worm Drive Grounded Delta Printer February 15, 2014 07:50PM |
Re: Worm Drive Grounded Delta Printer February 15, 2014 08:38PM |
Re: Worm Drive Grounded Delta Printer February 15, 2014 08:54PM |
A2
Looking good.
What is the motivation to design an extruder?
Will you be resin casting the extruder as well?
I'm unsure, but it appears that you are using a fixed gap between the idler and hob.
From what I have reviewed most filament drivers are using a spring to allow
the idler to move in-n-out to compensate for variations of filament diameters.
Of the components that are going to be resin cast,
have you allowed for draft to ease removal from the mold?
Looks like a lot of test prints in the background
Videos are always appreciated!
Re: Worm Drive Grounded Delta Printer February 21, 2014 06:07PM |
Re: Worm Drive Grounded Delta Printer February 21, 2014 08:28PM |
Re: Worm Drive Grounded Delta Printer February 25, 2014 12:38AM |
Re: Worm Drive Grounded Delta Printer February 25, 2014 12:56AM |
Re: Worm Drive Grounded Delta Printer February 26, 2014 04:02AM |
Solidus Labs
It will be interesting to see if there is any difference in performance with the added horsepower of the due vs the Mega2650
Re: Worm Drive Grounded Delta Printer February 26, 2014 10:24AM |
Re: Worm Drive Grounded Delta Printer February 26, 2014 03:50PM |
Solidus Labs
It doesn't look like anyone else has put much effort into porting marlin to due because lack of due optimization.
Re: Worm Drive Grounded Delta Printer February 26, 2014 04:48PM |
Re: Worm Drive Grounded Delta Printer March 12, 2014 01:51AM |
Re: Worm Drive Grounded Delta Printer March 12, 2014 08:04AM |
Re: Worm Drive Grounded Delta Printer March 12, 2014 11:47AM |
Re: Worm Drive Grounded Delta Printer March 21, 2014 09:22PM |
Re: Worm Drive Grounded Delta Printer March 24, 2014 10:57AM |
Re: Worm Drive Grounded Delta Printer March 31, 2014 11:25AM |
