Re: Worm Drive Grounded Delta Printer December 09, 2013 10:20AM |
Re: Worm Drive Grounded Delta Printer December 09, 2013 06:03PM |
Re: Worm Drive Grounded Delta Printer December 10, 2013 12:03PM |
nicholas.seward
@Jon: I am not sure what is meant by a parallelogram linkage. Are you talking about something like THOR Simpson? It would only work if you do that to two arms. However, I would advise you to figure out what the weak link is and beef it up. (Mathematically, your position should be constrained so it is just a matter of sizing all the components to get acceptable rigidity.)
I know this would be annoying to do but the the worm needs to be registered with a pair of bearings and some thread clamps.
I would also consider splitting the shoulder gear and adding a torsion print as a backlash removal attempt.
Note: My apologies if you have already done some of these things.
Good luck!
Re: Worm Drive Grounded Delta Printer December 10, 2013 12:15PM |
Re: Worm Drive Grounded Delta Printer December 10, 2013 01:17PM |
Re: Worm Drive Grounded Delta Printer December 10, 2013 01:38PM |
*face palm* Ahh you’re right. Without even testing I can tell you it is more rigid.Quote
nicholas.seward
@Solidus Labs: I think I know your main problem.
Test: Move the extruder to about 100mm above you surface. Press down and see if it is more rigid.
If it is more rigid, you just need to move your shoulder joints down so you stay far away from the planar singularity. (Your extruder is much closer to the joints than mine is.) That and beefing up your long arms should get you there. The shoulder looked good to me. Remember you don't need to add much plastic. You just need to add dimensionality to the arms. The rigidity is a function of b*h^3. If you just turn your arm on its side you will get 4 times the rigidity by my estimates. My theory is to go big with low infill.
Re: Worm Drive Grounded Delta Printer December 10, 2013 02:33PM |
Re: Worm Drive Grounded Delta Printer December 12, 2013 09:27AM |
Re: Worm Drive Grounded Delta Printer January 04, 2014 08:47PM |
Re: Worm Drive Grounded Delta Printer January 06, 2014 11:51AM |
AbuMaia
How are things going? How do the new shoulders work out? Did they get rid of that singularity?
Re: Worm Drive Grounded Delta Printer January 09, 2014 04:01PM |
Re: Worm Drive Grounded Delta Printer January 09, 2014 04:47PM |
Re: Worm Drive Grounded Delta Printer January 09, 2014 07:06PM |
Re: Worm Drive Grounded Delta Printer January 09, 2014 07:17PM |
Re: Worm Drive Grounded Delta Printer January 10, 2014 09:44AM |
Re: Worm Drive Grounded Delta Printer January 10, 2014 01:46PM |
double La_1; double La_2; double La_3; double Da_1; double Da_2; double Da_3; double Ra_1; double Ra_2; double Ra_3; Ra_1=sqrt(sq(cartesian[X_AXIS]-V1_X)+ sq(cartesian[Y_AXIS]-V1_Y)); Ra_2=sqrt(sq(cartesian[X_AXIS]-V2_X)+ sq(cartesian[Y_AXIS]-V2_Y)); Ra_3=sqrt(sq(cartesian[X_AXIS]-V3_X)+ sq(cartesian[Y_AXIS]-V3_Y)); La_1=sq(Ra_1-Nx+Sx)+sq(cartesian[Z_AXIS]-Sv+Nv1); La_2=sq(Ra_2-Nx+Sx)+sq(cartesian[Z_AXIS]-Sv+Nv2); La_3=sq(Ra_3-Nx+Sx)+sq(cartesian[Z_AXIS]-Sv+Nv3); Da_1=((sqL1L2-La_1)/theta_CEND); Da_2=((sqL1L2-La_2)/theta_CEND); Da_3=((sqL1L2-La_3)/theta_CEND); if (Da_1 <-1 || Da_1 > 1) { Da_1=floor(Da_1); SERIAL_ECHOPGM("Arm Limit X\n"); } if (Da_2 <-1 || Da_2 > 1) { Da_2=floor(Da_2); SERIAL_ECHOPGM("Arm Limit Y\n"); } if (Da_3 <-1 || Da_3 > 1) { Da_3=floor(Da_3); SERIAL_ECHOPGM("Arm Limit Z\n"); } delta[X_AXIS]= acos(Da_1)*rad2ang; delta[Y_AXIS]= acos(Da_2)*rad2ang; delta[Z_AXIS]= acos(Da_3)*rad2ang;
Re: Worm Drive Grounded Delta Printer January 11, 2014 01:09PM |
Re: Worm Drive Grounded Delta Printer January 11, 2014 01:21PM |
Re: Worm Drive Grounded Delta Printer January 11, 2014 01:36PM |
Re: Worm Drive Grounded Delta Printer January 12, 2014 12:38PM |
Re: Worm Drive Grounded Delta Printer January 18, 2014 04:01PM |
Re: Worm Drive Grounded Delta Printer January 26, 2014 11:45AM |
Re: Worm Drive Grounded Delta Printer January 27, 2014 01:34PM |
Re: Worm Drive Grounded Delta Printer January 27, 2014 03:19PM |
Re: Worm Drive Grounded Delta Printer January 28, 2014 10:44PM |
The shoulder was fairly loose on the tolerances, it was probably 0.3 mm because of the low sub divisions. I was pushing the firmware pretty hard to get 16x microsteps and 50 sub divisions/sec at 60 mm/s. At this speed I was able to see some distortion on the faster curves.Quote
Guizmo
Hello Jon
How precise are the parts coming out of your machine? Are they usable as mechanic parts?
Thanks
I lowered the print head so the build envelope is approximately the same. 180mm diameter x ~100mm z useable. All of the GDR parts will fit in the build envelope.Quote
A2
@SolidusLabs:
You have longer arms now, what is the size of the build envelope?
Can it accurately reproduce the arms, and worm wheel?
What is the print speed, and what do you think the top print speed will be after tuning the software, and calibration?
Re: Worm Drive Grounded Delta Printer January 29, 2014 09:01PM |
Re: Worm Drive Grounded Delta Printer January 30, 2014 11:56AM |
Re: Worm Drive Grounded Delta Printer January 30, 2014 09:51PM |
Re: Worm Drive Grounded Delta Printer February 03, 2014 08:54PM |
Re: Worm Drive Grounded Delta Printer February 04, 2014 02:04AM |
