Re: LISA Simpson January 26, 2014 09:56PM |
Re: LISA Simpson January 30, 2014 07:51PM |
Re: LISA Simpson January 31, 2014 07:15AM |
Re: LISA Simpson February 02, 2014 10:47PM |
uncle_bob
Do the motors move or are they stationary? [/quote/
Motors are stationary.
If the motors are stationary, the moving racks get pretty crazy.
Yeah, I've been thinking about it. In order to get a decent Z, you would need 2xZ room for the racks protruding through the top.
Either way having the system rotate like the LISA does would be difficult. Once you drop rotation at the arms it's not really a LISA.
There's nothing to stop the arms from rotating, the rack-arm interface will be a bit tricky. Note, I'm only a novice when it comes to designing mechanical systems.
Re: LISA Simpson February 03, 2014 07:48AM |
Re: LISA Simpson February 03, 2014 04:28PM |
uncle_bob
What is the advantage of the racks over the lead screws?
Re: LISA Simpson February 03, 2014 04:38PM |
Re: LISA Simpson February 03, 2014 09:43PM |
SheldonE
uncle_bob
I was thinking about the issue of not using the whole length of the lead screw for the Z height. The suggestion to use rack and pinion was just a "throw it out there" comment. It seems to have more problems than it solves.
Re: LISA Simpson February 04, 2014 10:20PM |
Re: LISA Simpson February 05, 2014 06:24PM |
Re: LISA Simpson February 06, 2014 09:58PM |
Re: LISA Simpson February 07, 2014 05:20AM |
Dannydefe
Correct me if I'm wrong ,but this shouldn't change any of the geometry using the fork design.
uncle_bob
“Since the main impact is from the tan function,”
Hazer
“For LISA, the shoulders and the hub offset stays in line with the arm in the X-Y coordinates.
They can no longer be ignored like the Rostock does. By throwing them back into the equations,
you would need to perform two more squares and one more square-root per motor.
With the threaded rod offset, you would also need to add one SIN/COS equation to compensate the movement of the thread.
That unfortunately is a 4000 cycle hit per motor.
So, Marlin Rostock would be 3120 processor cycles per move at 16MHz would take 195 usec.
Adding LISA calculations to firmware would change to 18480 cycles, or 1.1 milliseconds.
I have no idea what impact that could have.”
Re: LISA Simpson February 07, 2014 09:20AM |
Re: LISA Simpson February 07, 2014 09:54AM |
Re: LISA Simpson February 07, 2014 11:46AM |
Re: LISA Simpson February 07, 2014 12:03PM |
Re: LISA Simpson February 07, 2014 06:42PM |
nicholas.seward
Fork joints are superior. (Assuming that the fins of the forks are thick enough.) I have been considering going that direction. It has a nice side benefit of making the longest part only 125mm (from the model below) for a printer that has a 225mm print diameter. That means you can make a 1.8X LISA on a forked LISA. (If optimization of the macrocreation factor is desired you can even do better than that. I came up with 2.2X with just a little playing around.)
Re: LISA Simpson February 09, 2014 01:16PM |
Re: LISA Simpson February 11, 2014 03:38PM |
Re: LISA Simpson February 11, 2014 08:30PM |
Re: LISA Simpson February 11, 2014 08:50PM |
Re: LISA Simpson February 13, 2014 05:01PM |
Re: LISA Simpson February 13, 2014 05:50PM |
Re: LISA Simpson February 13, 2014 06:27PM |
Re: LISA Simpson February 13, 2014 06:32PM |
Re: LISA Simpson February 13, 2014 07:05PM |
Re: LISA Simpson February 13, 2014 07:29PM |
Re: LISA Simpson February 18, 2014 09:15PM |
Re: LISA Simpson February 18, 2014 09:42PM |
Re: LISA Simpson February 18, 2014 11:27PM |
Dannydefe
I'm not sure if the first photo with shoulders step for the Bearings race might perform better than just straight aluminum plug which is press-fit into the shoulder.
Dannydefe
My goal is reduced weight, zero play and to reduce the width of the shoulder joint so that it doesn't interfere with my carbon corner supports.
