Re: LISA Simpson February 19, 2014 07:58PM |
Re: LISA Simpson February 19, 2014 08:16PM |
Re: LISA Simpson February 19, 2014 08:58PM |
Re: LISA Simpson February 19, 2014 09:50PM |
Re: LISA Simpson February 20, 2014 06:06PM |
Re: LISA Simpson February 21, 2014 10:06PM |
Re: LISA Simpson March 10, 2014 03:50PM |
Re: LISA Simpson March 10, 2014 03:56PM |
Re: LISA Simpson March 11, 2014 01:33AM |
Re: LISA Simpson March 11, 2014 01:24PM |
Re: LISA Simpson March 11, 2014 04:37PM |
Re: LISA Simpson March 17, 2014 09:26PM |
Re: LISA Simpson March 18, 2014 03:50AM |
Re: LISA Simpson March 18, 2014 08:37PM |
Re: LISA Simpson May 27, 2014 09:07AM |
Re: LISA Simpson May 27, 2014 12:27PM |
Re: LISA Simpson May 27, 2014 12:56PM |
Re: LISA Simpson May 27, 2014 11:39PM |
But there is a free software called "FaceTrackNoIR" that ironically tracks IR diodes on your head using simple point tracking (used to control the view direction of players in video games).
Re: LISA Simpson June 24, 2014 07:10AM |
Re: LISA Simpson June 24, 2014 09:58AM |
Re: LISA Simpson July 12, 2014 04:18AM |
Re: LISA Simpson July 12, 2014 10:17AM |
paddy92
To my understanding, only one type of extruder fits on this printer due to the center pivot. Someone could maybe look into a center plate with virtual pivot point hinges. In this way, a clean platform is available and the arm connections are more symetric. Moreover, fans and lights can be placed which is not easely possible at this moment. Here is a picture of my idea [attachment 36376 Real-and-virtual-pivot-point.png] . The blue block is a third of the extruder platform. At the moment the lisa extruder platform has a real pivot point going through the tip of the extruder. One could create a virtual pivot point around the same extruder tip, But place the hinge further to the side. By using the virtual pivot point, one gains a clean extruder platform. However, three additional linkages will be needed and I have no idea if this complicates calibration of the printera lot.
Re: LISA Simpson July 12, 2014 11:50AM |
Re: LISA Simpson July 12, 2014 12:00PM |
Re: LISA Simpson July 12, 2014 12:36PM |
Re: LISA Simpson July 12, 2014 12:55PM |
Re: LISA Simpson July 16, 2014 02:54PM |
Re: LISA Simpson July 16, 2014 04:56PM |
Re: LISA Simpson July 16, 2014 05:02PM |
Dejay
I've found some rather cheap ball screws on ebay 800mm and 1610 (apparently 10 mm lead), in the range of $60 with free shipping. These have less lead than the high lead screws, but they also have far less friction. Would this work / compensate so that you could use higher RPM on the motor instead of higher lead?
Re: LISA Simpson July 16, 2014 05:05PM |
