LISA Simpson
Posted by nicholas.seward
Re: LISA Simpson
November 24, 2013 09:57PM
Six feet of 6063 aluminum tube 2" in diameter is still under $20. I suspect it's a bit more sturdy than the PVC.
[www.onlinemetals.com]
Edited 1 time(s). Last edit at 11/24/2013 09:58PM by uncle_bob.
Re: LISA Simpson
November 26, 2013 11:10AM
Here is a mockup of the scale of LISA. It is bigger than I thought but not so big it can't fit on a desktop. I know a lot of people don't like the PVC but after hammering the PVC into the milled sockets for just one board I get a structure that is good enough for slow printing. Once I get the bottom plate it will probably be good enough for normal printing. With the tension from the screws it will be prefect for fast printing.
The main reason I am using PVC is that it is simple and I have a lot of it laying around. (FREE!) It will be great for this prototype. For those that want to conserve desk space, I would suggest going with a design like Dannydefe's. You could fit everything into a 16" diameter circle easy. Currently, the PVC makes the foot print 21" in diameter.
Re: LISA Simpson
November 27, 2013 07:14PM
Here's the progress I made today, just doing first mock up to see how it looks.
Tomorrow I will start on the side structure and stepper motor placement.
Is there any opinion on how much Z this machine should have ?
Re: LISA Simpson
November 27, 2013 08:00PM
@Dannydefe: I am going to make it as tall as possible. You will need about 1" on each side for the thread clamp and the coupler. I am going to have the coupler double as the bottom thread clamp. Looks awesome BTW.
I got my screws and nuts today and any worries I had about friction, backlash, straightness, etc have gone away. They will be perfect in my opinion.
I am going to add a bottom plate like you have. I will mill sockets for the steppers. I will remove two of the back screws of the stepper and replace them with longer ones so I can bolt throught the bottom board.
Additionally, I am going to get some cheap threaded rod to go through the middle of the PVC columns to make assembly super easy and make everythong very rigid.
Re: LISA Simpson
November 27, 2013 10:00PM
How much Z .... how high is the ceiling ....smiling smiley
More practically - how much money do you want to put into a test machine? Anything above a meter proves it works and then some.
Re: LISA Simpson
November 29, 2013 10:37AM
If the PVC is big enough, the extension below the basalt could contain the steppers. Or use larger PVC just for the 'feet'.
I kinda like the two-sides and a door, though.
Re: LISA Simpson
November 30, 2013 09:37AM
Two sides + door + fan + heater for temperature control would be pretty neat. You could keep the PVC pipe or go to CPVC for higher temps ...
If the steppers are buried in the support structure *and* really go for max torque / speed - they will get pretty hot. This may be a high torque design. You might consider allowing for fan mounts near each motor.
Re: LISA Simpson
December 01, 2013 08:02PM
Maybe acrylic sheets with magnetic corner stubs could be used for simple/easy-access walls? You could include a tab at top/bottom center to secure the acrylic sheet laterally.
Re: LISA Simpson
December 01, 2013 09:27PM
uncle_bob
Yes, I think I agree about the sturdiness. I think PVC tends to deform slowly.
David
Re: LISA Simpson
December 02, 2013 12:05PM
I imagine this design, coupled with the "threadless ballscrew" could be great (e.g, [www.thingiverse.com], I just pulled the first one I found its not the best.) Way to take what first sounds like a bad idea (threadscrews) and turning into a feasible lowcost design. Props!
Re: LISA Simpson
December 02, 2013 12:58PM
@Tomek: That is a great idea. I need to make one of these "threadless ballscrews" and test it. I have no idea if you would get positioning creep without threaded screws. (I expect the rod to form grooves that would make the positioning repeatable.) Anyone have experience with this?
A2
Re: LISA Simpson
December 02, 2013 02:06PM
You need to use a harden steel rod or the bearing edges will wear a grove.
Backlash is about .002, but it depends on how much you load the bearing.
Naturally self cleaning.
Re: LISA Simpson
December 02, 2013 02:08PM
@A2: I know that the backlash is near enough to zero but what about position creep. If you go back and forth 1000 times have you lost your zero?
A2
Re: LISA Simpson
December 02, 2013 02:24PM
It's too many years since I've seen one, I don't know how far off it could be after 1000's of moves, another engineers project.
But they are good for slightly dirty wet environment.
Creep of the plastic housing, and the shaft that holds the bearing would be my main concern for a DIY version.
I've only seen aluminum block used with precision threaded shaft, I forget the name, Carr Lane or another supplier used to have a precision shaft SHCS.
I can't locate it found this: [www.carrlane.com]
Found it: precision shoulder screws
[www.mcmaster.com]
Edited 1 time(s). Last edit at 12/02/2013 02:26PM by A2.
Re: LISA Simpson
December 03, 2013 12:59PM
Sorry, I don't know how far it would be off (I have a lot of leeway on my install and it's just 1 rod for the Z-axis of a cartesian bot.)
Re: LISA Simpson
December 03, 2013 01:08PM
@Tomek: That is smart! A slow one-way axis like the z axis is perfect for this kind of screw. Since you have a setup could run it up and down 100 times or so and see if there is any measurable drift. (I could provide some test gcode if you don't mess with gcode directly.)
Re: LISA Simpson
December 03, 2013 02:30PM
Would a spinning threadless ballscrew work as a filament driver? Or is the diameter of filament too unreliable? The biggest hurtle I can think of is that variation in the filament diameter would cause the ballscrew to disengage.
Edited 1 time(s). Last edit at 12/03/2013 02:49PM by PeteD.
Re: LISA Simpson
December 03, 2013 08:04PM
This is just a preliminary set up to see how it looks. The corner caps were made off a temporary mold and the carbon /Fiberglass was resin infused. I've extended the carbon corners down to cover the stepper installation.
Comments Welcome..
Re: LISA Simpson
December 03, 2013 08:10PM
Here's a photo of my attempt to make a nut from the Torqspline® Screws. I used epoxy and graphite . first waxed and then a couple of coats of spray PVA for release agent. Although the threads turned out perfect, the friction is just much too high. I guess someone could try and use a different type of coating over the threads to build them up but I think I'll just buy the nuts for now.
Another alternative if several of us would like to pitch in, is the purchase of a tap (www.roton.com/page.aspx?id=41) for this particular screw. The tap is quite expensive but maybe if we were going to build several machines it would be worth the cost.
Re: LISA Simpson
December 03, 2013 08:20PM
I will pitch in assuming we like how LISA functions. Love the sides! Can you take a square on view of the nut at high res? I need to trace it to make the thread clamps and coupler.
Also could we make our own taps with a lathe?
Re: LISA Simpson
December 03, 2013 09:12PM
I seriously doubt if these can be manufactured on a lathe without extreme experience. let's produce the first couple of prototypes and if all goes well we can purchase the tap and make a bunch of nuts.
A2
Re: LISA Simpson
December 03, 2013 10:27PM
@Dannydefe
A few ideas:
Graphite loading:
If there is not a heavy loading of graphite at the interface of the nut and thread, it will always be sticky, and require lubrication.
Purchased Tap:
Keep in mind that the tap will in general reproduce the same size of the nut that you purchased.
If you were for an example to use Nylon rod and tap it, most likely it will be undersized, and produce a tight fit.
To compensate for this you will need to increase the hole diameter.
Trade off is you have less surface area in contact.
Thermoforming:
You might be able to heat up the threaded rod and thermoform a plastic nut.
Chrome plate threaded rod:
Another technique is to build up the surface of the threaded rod by chrome plating it.
Then cast your epoxy/graphite over it.
Adjustable nut:
Split the nut with a Dremel cutoff wheel.
Use a metal hose clamp to adjust the fit up between the shaft and epoxy/graphite nut.
Or, in addition to the split nut, cross drill in the region without threads and use a bolt and nut to clamp/adjust tension.
Lapping:
Use a lapping compound and run the shaft back and forth through the nut until if feels right to you.
Homemade tap:
You can make a tap from the threaded rod by grinding out flutes, I've done this many time to clean out damaged threads.
Cut the flutes at an angle so it can shear.
As it becomes dull regrind the flutes.
If you are cutting a hard material, a negative rake might product better result.
Case hardening:
If the threaded shaft is too soft to work as a tap you can case harden it, lots of ways to approach this, here's an old fashion technique.
Wrap a section of the shaft in leather, place it in a crucible (or wrap in SS foil) and heat it.
Time and temperature can be found with a search.
Re: LISA Simpson
December 03, 2013 10:29PM
This is my best stab at reverse engineering the tooth form. After several requests for the engineering drawings, ROTON final told me it was a trade secret. I have no problem with that but a simple no would have been sufficient. I had to write 3 emails to get to that point. One interesting note did come about. They were willing to give me quotes for shaft couplers and thread clamps if I would have provided them with drawings of the blanks. Anyways, I am off to do some printed thread clamp tests.
A2
Re: LISA Simpson
December 03, 2013 10:43PM
PeteD
I had the same idea, and have made paper sketch of it as a reminder.
The main challenge that I see with it is that the filament would rotate with a single drive.
Another problem is when you reversed the drive to retract the filament, the unwinding would work against you.
Couple of ways to work around this:
It would require two sets that counter rotate with opposing complementary helix angles.
Counter rotating would prevent the filament from twisting.
This would require a belt to drive them.
The drive mechanics is not simple, and the support would be rather large.
To eliminate two counter rotating drives, a knife edge roller could be used to prevent rotation of the filament.
The sharp edge would bite into the filament forming a grove to prevent the filament from rotating.
This would be the easiest to implement.
To compensate for variable filament diameter, spring tension could be used.
But you never know, the amount of compression to drive the filament might be enough to compensate for a variable diameter.
Re: LISA Simpson
December 03, 2013 11:11PM
Regarding filament drive:
*For 1.75mm filament you need 604s or smaller.
*Counter rotating could be done with bevel gears.
*You could use the edge of the bearing instead of the flat to increase the grip and remove almost all of the sliding friction.
I really like this idea. I think I can do it with 6 604s and 3 608s and some random bolts. It has enough potential to warrant a mock up and a possible test. I will put it in the developer forum when I get the time.
Re: LISA Simpson
December 04, 2013 05:40AM
Mounting Screws/Stepper
Coupler
Carriage
Thread Clamp
I have to say that everything is coming together beautifully. This design has some promise.
Re: LISA Simpson
December 04, 2013 07:54AM
Here is my updated design.
A2
Re: LISA Simpson
December 04, 2013 08:02AM
The metal screws make this concept a better platform for the globular deposition modeling of metal welding (GDMm), as it could support a lot of weight!
Add a worm drive, and it could really lift/support a heavy weight.
Components are looking good!
What is the fit of the bearing like over the threads (slip, interference)?
Edited 1 time(s). Last edit at 12/04/2013 08:05AM by A2.
Re: LISA Simpson
December 04, 2013 08:08AM
The fit has less play than the balls have.
Re: LISA Simpson
December 04, 2013 01:11PM
I'd add some 1/2" sections of PVC below the bottom plate to act as legs/ supports. They would keep the ends of the thread rod from gouging up the table it's sitting on. I think it would look pretty good done that way.
