Re: LISA Simpson December 10, 2013 02:46AM |
nicholas.seward
I actually take it a step farther.
draw a quarter circle.
Pick a point low on the quarter circle and swing an arc to intersect the arc you are on.
To verify you did everything right go to that intersection and make sure you can swing an arc directly through the other two points of the triangle.
Re: LISA Simpson December 10, 2013 10:24AM |
Re: LISA Simpson December 10, 2013 10:53AM |
Re: LISA Simpson December 10, 2013 12:30PM |
nicholas.seward
....... If you bump up to a 1" screw you can make it 8.5' tall. (For fun I priced this last one. It comes to less than $2500 for the whole printer. For 5 times the cost you can make a printer that has 75 times the volume.)
Re: LISA Simpson December 10, 2013 12:44PM |
Re: LISA Simpson December 10, 2013 01:16PM |
Re: LISA Simpson December 10, 2013 02:21PM |
Re: LISA Simpson December 10, 2013 02:26PM |
Re: LISA Simpson December 10, 2013 04:42PM |
Re: LISA Simpson December 10, 2013 05:00PM |
cozmicray
Nick
Got any experience with threadless leadscrews?
Ever experimented with them?
Would like to hear your take.
Sure would make it much cheaper, if it has enough precision.
Perhaps using them long enough they would become threaded leadscrews?
Re: LISA Simpson December 10, 2013 06:41PM |
Re: LISA Simpson December 10, 2013 08:12PM |
Re: LISA Simpson December 10, 2013 08:17PM |
Re: LISA Simpson December 10, 2013 08:31PM |
cozmicray
Nick
Re: LISA Simpson December 10, 2013 08:42PM |
nicholas.seward
@A2: Even with small LISAs it is important to register you screw between the two plates with the coupler on one side and the thread clamp on the other. The stepper should be fastened to the coupler after this. There should be no axial load on the coupler.
I suggest that you loosen and re ighten the coupler every 3 months or so just to be sure that there is no axial load.
Re: LISA Simpson December 10, 2013 09:35PM |
Re: LISA Simpson December 10, 2013 10:55PM |
[www.kickstarter.com]Quote
Hack A Day
the Smoothie uses a 32-bit ARM chip in the form of an NXP LPC Cortex-M3 chip.
Not only does this allow the Smoothie to do some very cool things with your machine – native arcs and circles,
for example, but this better hardware also allows for Ethernet, drag-and-drop firmware,
and exposing the USB port as both a serial port or mass storage device.
The Smoothie comes in three flavors, with either 3, 4, or 5 stepper motor drivers.
These Allegro A4982 drivers are good enough for any 3D printer, laser cutter, or small mill,
but the broken out pins allow for stepper drivers supplying more than 2A of current.
Everything on the Smoothieboard is modular, meaning this board is equally capable of powering a RepRap, mill,
laser cutter, or plotter. There’s even a planned control panel called the Smoothiepanel, making this a great choice for your next CNC build.
[hackaday.com]
uncle_bob
1) Screw at 0.25" pitch (worst one I've found so far)
Do I *really* want to go with 0.25" pitch? .... not if I can help it.
Re: LISA Simpson December 10, 2013 11:15PM |
Re: LISA Simpson December 10, 2013 11:31PM |
Re: LISA Simpson December 10, 2013 11:45PM |
Re: LISA Simpson December 11, 2013 12:40AM |
cozmicray
these massive leadscrews are getting out of hand? ... ... for squirtin plastic?
Re: LISA Simpson December 11, 2013 01:10AM |
Re: LISA Simpson December 11, 2013 08:56AM |
Re: LISA Simpson December 11, 2013 11:49AM |
Re: LISA Simpson December 11, 2013 12:56PM |
Re: LISA Simpson December 11, 2013 01:36PM |
Re: LISA Simpson December 11, 2013 05:07PM |
Re: LISA Simpson December 11, 2013 08:56PM |
Re: LISA Simpson December 11, 2013 09:00PM |
Re: LISA Simpson December 12, 2013 04:50AM |
the bearings are on this impressive speed test of the Mini Kossel printer.
, but I don't know...
