Have you seen the Delta-Pi? November 22, 2013 08:01PM |
Re: Have you seen the Delta-Pi? November 22, 2013 08:44PM |
Re: Have you seen the Delta-Pi? November 22, 2013 11:11PM |
Re: Have you seen the Delta-Pi? November 23, 2013 03:37AM |
Re: Have you seen the Delta-Pi? November 23, 2013 03:01PM |
Re: Have you seen the Delta-Pi? November 23, 2013 04:01PM |
Re: Have you seen the Delta-Pi? November 24, 2013 01:25AM |
Please tell me you're using fuses!Quote
Irish_Steve
120 amps would be enough to arc weld with if I want to
Re: Have you seen the Delta-Pi? November 24, 2013 06:49PM |
TheTechnicalNoob
Irish_Steve
120 amps would be enough to arc weld with if I want to![]()
Re: Have you seen the Delta-Pi? December 03, 2013 08:55PM |
Re: Have you seen the Delta-Pi? December 09, 2013 11:25PM |
Re: Have you seen the Delta-Pi? December 10, 2013 07:53AM |
TheTechnicalNoob
I recall reading about someone who reportedly used steel bearings on aluminium extrusions without problems by putting electrical heatshrink plastic around the bearings.
Can anybody confirm that this works well?
Re: Have you seen the Delta-Pi? December 10, 2013 06:27PM |
Re: Have you seen the Delta-Pi? December 10, 2013 06:37PM |
beamsaber
Is the problem with steel bearings on aluminum that the steel will eat it's way through the aluminum eventually?
mikep-nz
The problem with using Aluminium tube as a bearing surface is that the soft aluminium surface is so easily damaged by dust and dirt and once it gets damaged it quickly deteriorates to the point of being useless.
Re: Have you seen the Delta-Pi? December 10, 2013 11:59PM |
Re: Have you seen the Delta-Pi? December 12, 2013 04:07PM |
Re: Have you seen the Delta-Pi? December 13, 2013 01:57PM |
You could make a continuity indicator, or just try using your printer and see if it all works. A multimeter definitely will be handy if you plan on doing any projects involving electronics.Quote
beamsaber
My printer made it's first movements two days ago, and I'm starting on configuring it now. I am starting to wonder if I should invest in a multimeter because I have no clear way to confirm all the lines running to the motors, thermistor, etc are solid, as I've had to crimp-splice each one at least twice.
Re: Have you seen the Delta-Pi? December 23, 2013 05:14AM |
Re: Have you seen the Delta-Pi? December 26, 2013 02:28PM |
A2
TheTechnicalNoob
You either have your stories mixed up, or someone was joking around.
Re: Have you seen the Delta-Pi? December 26, 2013 04:15PM |
Re: Have you seen the Delta-Pi? December 28, 2013 11:16PM |
Re: Have you seen the Delta-Pi? December 28, 2013 11:54PM |
Re: Have you seen the Delta-Pi? December 29, 2013 04:14AM |
Re: Have you seen the Delta-Pi? December 29, 2013 04:58AM |
Re: Have you seen the Delta-Pi? December 29, 2013 07:08PM |
