Delta-Pi Endstop Problem in Repeteir November 25, 2013 10:39AM |
Re: Delta-Pi Endstop Problem in Repeteir November 25, 2013 10:09PM |
Re: Delta-Pi Endstop Problem in Repeteir November 26, 2013 01:18PM |
Re: Delta-Pi Endstop Problem in Repeteir November 26, 2013 01:54PM |
Re: Delta-Pi Endstop Problem in Repeteir November 26, 2013 07:52PM |
Re: Delta-Pi Endstop Problem in Repeteir November 26, 2013 09:10PM |
Re: Delta-Pi Endstop Problem in Repeteir November 27, 2013 08:12AM |
Re: Delta-Pi Endstop Problem in Repeteir December 01, 2013 11:24PM |
Re: Delta-Pi Endstop Problem in Repeteir December 01, 2013 11:34PM |
G29;HOME G01 X0 Y-50 Z100 F12000 G01 Y50 F1200; Should take 5 seconds to move 100mm G01 Y-50 F6000; Should take 1 second to move 100mm
Re: Delta-Pi Endstop Problem in Repeteir December 01, 2013 11:36PM |
Re: Delta-Pi Endstop Problem in Repeteir December 02, 2013 04:19AM |
/** \brief Delta rod length */ #define DELTA_DIAGONAL_ROD 250.0 // mm /** \brief Number of segments to generate for delta conversions per second of move */ #define DELTA_SEGMENTS_PER_SECOND_PRINT 200 // Move accurate setting for print moves #define DELTA_SEGMENTS_PER_SECOND_MOVE 70 // Less accurate setting for other moves /** \brief Horizontal offset of the universal joints on the end effector (moving platform). */ //#define END_EFFECTOR_HORIZONTAL_OFFSET 33 /** \brief Horizontal offset of the universal joints on the vertical carriages. */ //#define CARRIAGE_HORIZONTAL_OFFSET 18 /** \brief Printer radius in mm, measured from the center of the print area to the vertical smooth rod. */ //#define PRINTER_RADIUS 175 /** \brief Horizontal distance bridged by the diagonal push rod when the end effector is in the center. It is pretty close to 50% of the push rod length (250 mm). */ //#define DELTA_RADIUS (PRINTER_RADIUS-END_EFFECTOR_HORIZONTAL_OFFSET-CARRIAGE_HORIZONTAL_OFFSET) #define DELTA_RADIUS 126.77
Re: Delta-Pi Endstop Problem in Repeteir December 02, 2013 10:26AM |
Re: Delta-Pi Endstop Problem in Repeteir December 02, 2013 03:41PM |
Re: Delta-Pi Endstop Problem in Repeteir December 03, 2013 12:28AM |
Re: Delta-Pi Endstop Problem in Repeteir December 03, 2013 03:08AM |
#define E0_STEP_PIN 26 #define E0_DIR_PIN 28 #define E0_ENABLE_PIN 24
#define ENDSTOP_X_RETEST_REDUCTION_FACTOR 8 #define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 8 #define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 8 #define X_MAX_LENGTH 200 #define Y_MAX_LENGTH 200 #define Z_MAX_LENGTH 344 #define X_MIN_POS -100 #define Y_MIN_POS -100 #define Z_MIN_POS 0 #define MAX_FEEDRATE_X 300 #define MAX_FEEDRATE_Y 300 #define MAX_FEEDRATE_Z 300 #define HOMING_FEEDRATE_X 40 #define HOMING_FEEDRATE_Y 40 #define HOMING_FEEDRATE_Z 40 #define STEP_DOUBLER_FREQUENCY 10000 #define ALLOW_QUADSTEPPING true #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 1500 #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1500 #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1500 #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 3000 #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 3000 #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 3000
Re: Delta-Pi Endstop Problem in Repeteir December 03, 2013 11:11AM |
Re: Delta-Pi Endstop Problem in Repeteir December 03, 2013 02:19PM |
Re: Delta-Pi Endstop Problem in Repeteir December 05, 2013 10:30AM |
Re: Delta-Pi Endstop Problem in Repeteir December 05, 2013 10:11PM |
Re: Delta-Pi Endstop Problem in Repeteir December 10, 2013 01:06AM |
Re: Delta-Pi Endstop Problem in Repeteir December 10, 2013 04:27AM |
Re: Delta-Pi Endstop Problem in Repeteir December 17, 2013 10:21AM |
Re: Delta-Pi Endstop Problem in Repeteir December 17, 2013 02:10PM |
