Need help: Motors go correct direction. HOME is reversed?
Posted by disneytoy
December 09, 2013 04:47PM
Hello!
Kossel running Ramps 1.4. Marlin (for delta) In Repetier Host. My motors will move up and down via the up and down arrows under MANUAL. But if I press HOME for any of the 3 the carriages go down not up? I have mechanical switched at the top of my columns. The switch are working from previous tests.
How can I correct the Homing Direction?
Thanks
Maxi
Re: Need help: Motors go correct direction. HOME is reversed?
December 09, 2013 08:18PM
Try to check this in Configuration.h:
// ENDSTOP SETTINGS:
#define X_HOME_DIR 1
#define Y_HOME_DIR 1
#define Z_HOME_DIR 1
December 09, 2013 11:14PM
So, is Max the top and min the bottom? That wasn't clear. And in printer prefs in Repetier, I did change from MIN, MAX, and 0. But HOMING did not change. Will try again.
December 10, 2013 01:03AM
Thanks, That worked. Had to move my endstop pins over. Now homing works.
What next should I test or configure?
Don't have my end effector attached yet. That's next.
