I'm stuck: Trying to set up Diagonal Rod Arms December 12, 2013 08:45PM |
Re: I'm stuck: Trying to set up Diagonal Rod Arms December 13, 2013 03:04AM |
#define DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET-DELTA_EFFECTOR_OFFSET-DELTA_CARRIAGE_OFFSET) #define DELTA_DIAGONAL_ROD (2*DELTA_RADIUS)
Re: I'm stuck: Trying to set up Diagonal Rod Arms December 13, 2013 10:34AM |
Re: I'm stuck: Trying to set up Diagonal Rod Arms December 13, 2013 04:42PM |
Re: I'm stuck: Trying to set up Diagonal Rod Arms December 14, 2013 01:22AM |
Re: I'm stuck: Trying to set up Diagonal Rod Arms December 14, 2013 01:27AM |
Re: I'm stuck: Trying to set up Diagonal Rod Arms December 16, 2013 08:22PM |
Re: I'm stuck: Trying to set up Diagonal Rod Arms December 16, 2013 11:42PM |
Re: I'm stuck: Trying to set up Diagonal Rod Arms December 16, 2013 11:48PM |
hercek
[forums.reprap.org]
Re: I'm stuck: Trying to set up Diagonal Rod Arms December 17, 2013 04:39AM |
mikep-nz
hercek
[forums.reprap.org]
... I worked out that a 2:1 ratio was optimal to give you the largest build area for a given rod length.
But there is no requirement that the rods are exactly 2x the delta radius. That is purely a design choice.
Re: I'm stuck: Trying to set up Diagonal Rod Arms December 17, 2013 05:49PM |
Re: I'm stuck: Trying to set up Diagonal Rod Arms December 18, 2013 01:03AM |
Re: I'm stuck: Trying to set up Diagonal Rod Arms December 18, 2013 05:57AM |
KISSlicer allows you to specify STL of your built area.Quote
AndyCart
There must be a way to alter Pronterface, Repetier, Cura, etc to take these weird delta build platform planforms into account to maximise build area safely?
Re: I'm stuck: Trying to set up Diagonal Rod Arms December 22, 2013 03:05PM |
Re: I'm stuck: Trying to set up Diagonal Rod Arms December 22, 2013 04:06PM |
Re: I'm stuck: Trying to set up Diagonal Rod Arms December 15, 2015 11:56AM |
