Can anyone explain how to use M666 Marlins? December 20, 2013 01:24AM |
Re: Can anyone explain how to use M666 Marlins? December 20, 2013 09:28AM |
Re: Can anyone explain how to use M666 Marlins? December 20, 2013 01:26PM |
Re: Can anyone explain how to use M666 Marlins? December 20, 2013 02:10PM |
Re: Can anyone explain how to use M666 Marlins? December 21, 2013 04:09PM |
Re: Can anyone explain how to use M666 Marlins? December 21, 2013 10:29PM |
Re: Can anyone explain how to use M666 Marlins? December 21, 2013 11:41PM |
Re: Can anyone explain how to use M666 Marlins? December 22, 2013 04:36PM |
Re: Can anyone explain how to use M666 Marlins? December 29, 2013 03:28PM |
Re: Can anyone explain how to use M666 Marlins? December 30, 2013 06:33AM |
Re: Can anyone explain how to use M666 Marlins? December 30, 2013 10:21AM |
uncle_bob
The numbers in M666 can go both ways (+ and -). If you have a typical Delta and it homes at max rather than at min, the offsets still work. They just work in conjunction with the settings for bed size (max X,Y,Z vs min X,Y,Z).
Re: Can anyone explain how to use M666 Marlins? December 30, 2013 10:24AM |
disneytoy
M666 Question:
I just measured XYZ and center. The tip just drags on a thick sheet of paper.
(X) G1 X-70 Y-40 Z2.1 ( you will notice I could not get closer to the X tower because of my fan) i hope that does not make a difference.
Re: Can anyone explain how to use M666 Marlins? April 09, 2017 06:16AM |
Re: Can anyone explain how to use M666 Marlins? April 09, 2017 06:26PM |
Re: Can anyone explain how to use M666 Marlins? April 10, 2017 02:43AM |
Re: Can anyone explain how to use M666 Marlins? April 10, 2017 03:41AM |
dc42
The initial endstop corrections are the initial values you used in M666 and saved to EEPROM using M500. So all zero if you haven't calibrated your printer yet. Setting tower angle corrections is not easy in regular Marlin.
Re: Can anyone explain how to use M666 Marlins? April 12, 2017 09:32AM |
Re: Can anyone explain how to use M666 Marlins? April 12, 2017 12:49PM |
DjDemonD
The issue with later marlin firmwares like rc8 is that they have only very few parameters to calibrate a delta with. This will sound crazy but you'll do better with Rich Cattels marlin from 3 years ago either master or testing branch. You can use dc42's calculator to set a full range of m665 and m666 parameters.
Otherwise try repetier firmware, or smoothieware or RepRapFirmware which are all better for deltas than marlin.
Re: Can anyone explain how to use M666 Marlins? April 12, 2017 02:02PM |
Re: Can anyone explain how to use M666 Marlins? April 12, 2017 06:06PM |
Re: Can anyone explain how to use M666 Marlins? April 13, 2017 07:21AM |
Re: Can anyone explain how to use M666 Marlins? April 13, 2017 08:54AM |
Re: Can anyone explain how to use M666 Marlins? April 23, 2017 04:21AM |
Anonymous User
Re: Can anyone explain how to use M666 Marlins? July 15, 2017 01:04PM |
