Power Supply December 30, 2013 07:14PM |
Re: Power Supply December 30, 2013 09:45PM |
Power Supply with diode
If your board has a 1N4004 diode soldered in, do not apply more than 12 V to it. Original flavor Arduino Mega are rated to 12 V input. While Arduino Mega 2560 can take 20 V, it is not recommended."]
Re: Power Supply December 31, 2013 03:56AM |
Re: Power Supply December 31, 2013 05:33AM |
Re: Power Supply December 31, 2013 12:55PM |
Bixx
Hi, thanks for the replies.
@jaydmdigital , I will check but never intended to use more than 12v if I ran in parallel with one of the other supplies.
@RickM, I bought the all the parts ready assembled over a period of time from different vendors.
If I just have the usb plugged in, powered from the laptop, I can cycle through the menu's etc. on the display.
If I switch on the 12v power supplies I can also start the printer running and printing.
However, If I switch off the laptop, effectively unplugging the usb, the display goes off and the printer stops.
Is this normal?
Re: Power Supply December 31, 2013 02:20PM |
