why delta not list on the Build a RepRap page? February 08, 2014 09:47AM |
Re: why delta not list on the Build a RepRap page? February 08, 2014 01:34PM |
Re: why delta not list on the Build a RepRap page? February 08, 2014 02:27PM |
Re: why delta not list on the Build a RepRap page? February 08, 2014 03:05PM |
Re: why delta not list on the Build a RepRap page? February 08, 2014 03:22PM |
Re: why delta not list on the Build a RepRap page? February 08, 2014 04:38PM |
bobc
The link "Build a RepRap" redirects to [reprap.org].
There are several printers on there that are somewhat obscure, very new and not yet released or not even really RepRaps, so I don't think it is because there is a lack of a "go to" delta or because they are too new.
Like most of the wiki, it is a rather arbitrary list of stuff, so lack of Deltas probably just means no one thought to add one. That page could do with some categorization.
Re: why delta not list on the Build a RepRap page? February 09, 2014 11:41PM |
RickM
I hate that page so much, it's so uninviting to a novice user. There needs to be a 'portal' page, that draws new people in, not a wall of text and a few tiny obscure pictures of only cartesian models. I've added a message to the talk page. Realistically all models need correctly categorising on the wiki so people can look through them correctly. Right now a new user will take one look and never visit that page again, it really tells you nothing at all about which reprap to build and why. The wiki structure really doesn't work well for something like this sadly.
Re: why delta not list on the Build a RepRap page? February 10, 2014 10:43AM |
Re: why delta not list on the Build a RepRap page? February 10, 2014 12:30PM |
myohmy11
Hi Rick i'm thinking about building a mini rostock. Why did you say this is not the best choice for most people? the complexity?
Re: why delta not list on the Build a RepRap page? February 10, 2014 04:55PM |
RickM
... For that reason, something like RichRap's 3DR is likely a better 'default' delta option, as it uses lots of printed parts and is quite possibly the only delta that follows the goals of the reprap project.
Re: why delta not list on the Build a RepRap page? February 10, 2014 05:46PM |
Guizmo
RickM
Just a comment. Nicholas Seward GUS is what I and many consider the most reprapable printer at this moment, being a delta variation. Although not a beginer friendly printer at this moment, I just wanted to add to that statement.
We (at least me) are working on some bearingless variations.
[forums.reprap.org]
Re: why delta not list on the Build a RepRap page? February 12, 2014 01:17PM |
Re: why delta not list on the Build a RepRap page? February 12, 2014 03:08PM |
Re: why delta not list on the Build a RepRap page? February 12, 2014 05:42PM |
Not to hijack the purpose of the thread but the gears are only for registration and are pulled together with great force by the string. They introduce virtually zero backlash and even rough looking gears mesh pretty smoothly and can only get better over time. It seemed counter intuitive to me. I tested the design on a whim and was blown away by the result. I would not have used it in my design if it was a problem. (We still have plenty of issues that should give you pause but the gears shouldn't be one of them.)Quote
myohmy11
I checked the GUS design and one thing that concerns me is the printed gears. I think the backlash and roughness of the printed surface might impact the print quality, what do you guys think?
Re: why delta not list on the Build a RepRap page? February 13, 2014 04:51AM |
nicholas.seward
I think we need to standardize our language. Mostly because when people say "delta" they usually mean a Rostock style bot and ignores the pick and place style ones like Rappidelta and the Simpson style bots. I propose the following terms to be used in the wiki and hopefully in the forums.
Column Delta: Rostock, Kossel, LISA, etc
Grounded Delta: GUS Simpson, GDR, etc
Traditional Delta (could use a better name): Rappidelta, etc
There definitely needs to be some sort of categorisation on the wiki. There's so many models that just get overlooked completely due to poor linking going on.
