Which extruder to choose? March 24, 2014 07:22PM |
Re: Which extruder to choose? March 24, 2014 10:05PM |
Re: Which extruder to choose? March 25, 2014 07:28AM |
Re: Which extruder to choose? March 25, 2014 08:57AM |
Re: Which extruder to choose? March 25, 2014 03:42PM |
Re: Which extruder to choose? March 25, 2014 07:47PM |
Re: Which extruder to choose? March 26, 2014 01:03PM |
Re: Which extruder to choose? March 26, 2014 01:43PM |
If you want something like geared airtripper, then you may want to consider this one too: [forums.reprap.org]Quote
3DRapidClone
I'll look into the berrytripper.
Re: Which extruder to choose? March 26, 2014 07:12PM |
You're welcome.Quote
3DRapidClone
Wow thanks again sheepdog. I'll look into the berrytripper. So many derivatives to look at
Re: Which extruder to choose? March 26, 2014 09:18PM |
Re: Which extruder to choose? March 27, 2014 12:12AM |
Re: Which extruder to choose? March 27, 2014 12:25AM |
Re: Which extruder to choose? March 27, 2014 05:34AM |
Re: Which extruder to choose? March 27, 2014 02:31PM |
Re: Which extruder to choose? March 28, 2014 12:39AM |
You would be doing double duty and getting the worst of both systems, the complexity, ineficiency, and hassle of a geared extruder, and the added cost of a geared stepper all to accomplish what you could do with just a geared extruder.Quote
3DRapidClone
I see! The 5:1 geared nema stepper is a bit over geared right? So it slows retraction a bit? Seen anyone try to gear it down to 3:1 if that's even necessary? Im hoping an astroyn damper will fit too but it probably won't due to it needing to be close together.
I agree 3:1 is closer to ideal, but from a simplicity standpoint, the geared stepper is just so much easier to live with on a day to day basis.Quote
hercek
That is the reason I use printed gears. 5:1 (common for geared steppeers) is too much. Your retract speed will be low (probably below 50 mm/s). My opinion is one should have retract speed at least 100 mm/s for ABS with 0.5 head.
Re: Which extruder to choose? March 31, 2014 10:12AM |
Are you seeing these problems with 3mm or 1.75mm filament? I'm currently building my first printer and I've ordered an EZStruder and a E3D V5 0.4mm hotend for 1.75mm filament. I've bought a 70oz-in stepper for the extruder.Quote
sheepdog43
Ez Struder - LOVE IT! However, I don't recomend it for anything much smaller than a .5mm nozzle, as it lacks the torque for it, even with a Kysan. If you are using a large diameter nozzle though, this is the best extruder in my experience. It's simple, cheap and effective. Don't be fooled, nozzle size is far less important for quality than layer height.
Re: Which extruder to choose? March 31, 2014 04:58PM |
Re: Which extruder to choose? April 02, 2014 08:58AM |
Re: Which extruder to choose? April 04, 2014 03:35AM |
Re: Which extruder to choose? April 04, 2014 07:35PM |
Re: Which extruder to choose? April 05, 2014 04:10AM |
Re: Which extruder to choose? April 29, 2014 10:28AM |
Re: Which extruder to choose? April 30, 2014 01:54AM |
Re: Which extruder to choose? May 06, 2014 09:32PM |
Re: Which extruder to choose? May 07, 2014 05:36AM |
my bulldog lite is working great with both hot E3D Abs that PlaQuote
JBernal
I just wanted to post about my experiences with the Bulldog extruder.
I ordered it through their initial Indiegogo campaign, so I would have a good extruder for my new printer. Not sure if I got a lemon or what, but the extruder I received is a piece of junk. It doesn't have the strength to push ABS or PLA filament through even a basic .5mm hot end even at reduced speed, let alone the tighter nozzles that it included (Merlin and Magma). It fails to maintain a good enough grip on the filament to push it through, and when you tighten it enough that it ought to have enough power, it starts jumping gears in its gearbox.
I have a Wade's Accessible extruder on my old printer and I have never had a single problem with it. It works flawlessly. And so I am putting together another one and scrapping the Bulldog until I can get either a refund or replacement from ReprapDiscount.
Re: Which extruder to choose? March 12, 2015 08:19AM |
Re: Which extruder to choose? March 12, 2015 11:04AM |
Re: Which extruder to choose? March 12, 2015 11:10AM |
Re: Which extruder to choose? March 12, 2015 11:26AM |
StickyLube
@AndyCart
About the Gerg's Wade extruder..do you know if someone is selling an entire kit for assembling it?
Cos all I have found till now are thinginverse designs, and I am not even sure which one is the most reliable for 1.75mm filament.
Re: Which extruder to choose? March 12, 2015 04:00PM |
